134
No idea on price over there or what’s considered terminal or bad rust in your neck of the woods. What I do know is the rims are from the L series models, possibly the RX turbo but not 100% sure on that. Tyre size looks to be correct by eye. Couldn’t tell you the actual size though. Has AC but no AC pump. Just having the rest of the gear is a good thing as it gives you options depending on what you’re wanting to do. All the best with the purchase decision! Cheers Bennie
1986 XT Rear Brake Calipers
el_freddo replied to Anssi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Apparently there are some 80’s Nissan units that are basically the same but have a handbrake integrated into them. There could be some Honda units that are about the same too. Cheers Bennie -
Good time to paint your rims if getting new tyres - do it with the old tyres fitted so you don’t need to stress about overspray on the tyre itself. You should know glamour shots are ALWAYS welcome/appreciated! Cheers Bennie
I assume you remove the dip stick, wipe it then replace and remove to get the most accurate reading? If you’re not wiping before a dip to read the oil level, you’re not getting an accurate reading. If it’s still super high, are you sure you drained the engine sump and not the gearbox oil? An old mate of mine did this back I our uni days. Cost him a new gearbox plus fitment. There’s a dipstick on the RHS of the gearbox for the gearbox oil level, it’s worth checking it out assuming you have a manual. The auto has a front diff oil dipstick, I can’t remember what side of the auto it’s on though. And I’m digging the 14 year thread dig! Cheers Bennie
I know which one is pick out of that bunch! And your worst nightmare - filling that thing up with fuel must cost an absolute packet! Plus it’s not where near as cool as the BRAT! Cheers Bennie
If only we carried knives like that… once upon a time in remote areas maybe, hence why he took his stateside (doubt he’d actually get it in the country these days if ever), but creative licence with movies! And that’s a classic movie - I haven’t seen it in ages but I still love it! Cheers Bennie
And you’re about right with the cow catcher. I’m sure the five poster came from mustering cattle in old jeeps and land cruisers way back in the day - then they made their way to the front of road going vehicles. You can buy them for newer model vehicles too. I’d love a set of scrub bars for mine that then drop down below the door sill. And it looks heavy, but it’s not. I’d say several kg heavier than an alloy bullbar that’s commonly seen on Brumby’s over here. Cheers Bennie
You guys got all the cool colours over there! We got white, red, beige and a silver one that I believe was a limited run. Also interesting to see you have a bumper mounted side indicator rather than having it in the front guards/fenders. All of ours are in the guards. Very tidy looking unit! I love that desert fox decal down the side. Cheers Bennie
- 5 replies
- 1
- dual range
- gl
(and 7 more)
Tagged with:
I forgot to add that the brake sponginess is most likely due to the rear brake shoes needing adjustment. They’re manually adjust via a small square headed boot on the diff side of the backing plate, under the bearing. If you’re really lucky you’ll have the factory rubber cover on them still. If not no stress. Spray them with some penetrative lube and let them sit, repeat several times of they’re stuck good. You can adjust the brakes with the wheels in the air, this will let you know if they’re too tight or not. The bolt will roll over with a lumpy feel to it. This ensures the bolt can’t back out and loosen off your brakes. That will make a huge difference to the feel of your brake pedal. It could be worth removing the drums to clean out the years of crap that will be in there. Also a good time to inspect for slave cylinder leaks and the general condition of the brake shoes. Cheers Bennie
What you need to look for is a flat mark on the lip of the cam wheel. Do not use the arrow on the arm of the cam wheel - this is used to indicate which cylinder is at TDC depending on where it’s pointing. You should be able to rotate the engine by hand easily enough. Make sure it’s not in gear - and if the cam wheels are in a free position, where they can be easily turned back and forth freely, this indicates that the valves are in the closed position and there’s no way you can hit pistons and valves when in this position. If you still can’t rotate the engine you might have bigger problems at play. Hopefully this isn’t the case! For the crank there is a mark on a tooth at the back of the crank timing gear. All the best with it. Cheers Bennie
Looks good l75eya! Bit of rust that us Aussies baulk at but seems to be no issue on your side of the world. I’ve not seen a rear bar like that before, looks tidy even without the bumperettes to finish off the sides. Good score on the targa top too - not really a targa as I found out last year but that’s what they’re know as over here. If you’ve still got the instruction sticker on the roof lining panel the roof glass is referred to as a “fun top”. And I have to say it - modifying a classic quote from a classic Aussie movie you guys would probably know… “That’s not a bullbar… …THAT’S a bullbar.” I’m sure if you can weld in new panels to fix that rust you could weld up one of these five posters while you’re at it I’m looking forward to seeing where you go with this one! Cheers Bennie
Awesome score on the brat! How long before the legacy drivetrain ends up in the brat?? Enjoy it, but don’t overload it or throw crap in the back if you want to keep it in good condition. You’ve got the fun top version too, the best! Cheers Bennie
el_freddo replied to pontoontodd's topic in Off Road
Good detective work! How’d that sort of wiring damage come about? Hopefully you’ll get this thing tuned properly now and have some real fun with it! Cheers Bennie -
Fuel delivery issues, loud fuel pump EA82T
el_freddo replied to derburger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I’m hoping there’s a reply answer! I’m enjoying some of the thread digging going on - it’s good to see ppl doing searches on the forum, via google or otherwise. Cheers Bennie -
Underpowered Ignition coil ea81
el_freddo replied to b.gregorich's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well done! Glad it’s sorted and I hope it stays that way for a long time to come! Enjoy the snow. I’m trying to savour what’s left of the relatively wet and cool summer we had down here! Cheers Bennie- 9 replies
- ignition coil
- ea81
(and 1 more)
Tagged with:
I hope it’s the fix! Looking forward to hearing how the new ignition switch goes. Cheers Bennie- 9 replies
- ignition coil
- ea81
(and 1 more)
Tagged with:
Ignition switch should be held in by two Phillips head screw/bolts opposite to the side that the key goes into. You should only need to remove the steering column cowling and maybe drop the steering column off it’s mount bolts to get more access. You don’t have to pull the ignition barrel out to replace the ignition switch! That has the funny looking bolts without a head on them. They’re designed to snap off once torqued up so the ignition barrel can’t be easily removed by thieves. I’m not sure that the starter relay mod will dive this issue since you mentioned it cranks over fine and will run in the start position but die in the ON position. You’d only need a 30a horn relay - same as what you hook driving lights up with. Cheers Bennie- 9 replies
- 1
- ignition coil
- ea81
(and 1 more)
Tagged with:
My first thought is what voltage are you getting at the ignition switch when in the “ON” position? By running the wire from the positive of the battery to the coil you’ve effectively bypassed the ON setting of the ignition switch. This to me suggests an issue with the ignition switch. It’s possibly over 40yo so it’s done well! You could do this test twice - once just using the factory wiring as is, if that shows a low voltage reading then hook up that positive wire between the battery and coil then see what the voltage is at the back of the ignition switch, I’d expect it to be back feeding 12v if you got a low reading the first time. Cheers Bennie- 9 replies
- ignition coil
- ea81
(and 1 more)
Tagged with:
1988 Subaru gl how to lift
el_freddo replied to Jdog2004's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Subarino auto in Perth sells a complete 2 inch kit for the MY and L series. Shipping to you would be the costly bit, no harm in asking about the kit anyway. Cheers Bennie -
Sometimes it’s the simple things that cause the most grief (and wallet pain!). This relay mod is common on the early Liberty/Legacy’s too Cheers Bennie
- 7 replies
- ignition starting not loyale
- collant sensor
(and 4 more)
Tagged with:
Heads and all the associated gear will move over to the replacement block regardless of where it came from. The thing to check out is any differences in the pistons that may affect small things that may or may not become an issue. Sorry I can’t be more definitive on that front, I haven’t played much with the later model engine blocks so don’t know for sure. Cheers Bennie
