electronic instruments not consistently working
Dunno mate, you’d have to look into it. Is the thumb wheel for the cluster illumination lights plugged in? If so, do you have a second one to swap in and try? Cheers Bennie
(UPDATED pics and vid) Help! Newbie with 1994 EJ22 in van. Won't start. Skipped a tooth??
el_freddo replied to SubVAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI reckon that particular tensioner is not a genuine item. I’d be very surprised if it is. If genuine, you should see the Fuji Heavy Industries logo cast into the side of it. It’s a boomerang looking logo (did I get that right @Steptoe ) I’ve compressed them using a G clamp as previously mentioned, always on their side. An Allen key or a nail/pop rivet (used pin or new unit) works a treat to hold the tension! Cheers Bennie
88' EA82 Transmission Compatible With 83' Ea81??
Will definitely need mods to fit: - new tailshaft or use the ‘88 unit with the centre bearing mounted to the floor somehow. - if the output stubs are 23 spline count, this will use the factory shafts on your EA81 vehicle. - flywheel needs machining to change the height of the step, this gives the correct space to clamp the clutch disc. Use the EA82 clutch pressure plate, throw out bearing and clutch fork. - shifter linkages: can fit the EA82 units with the matching console, OR use the gear lever from the EA82, and mod the EA81 4wd lever to mate to the EA82 gear under the car. This retains the stock interior. Do a search on here. Plenty of threads about it. There are several ways to do the gearbox mounts from what I’ve read Cheers Bennie PS pls use capital letters only at the start of sentences, and for names etc. It will make it easier to read your posts
Could be a dodgy earth, or a loose connection behind the instrument cluster. The back lights could be the dimmer wheel not plugged in, faulty or set to the lowest setting (off!). Cheers Bennie
ER27 durability + performance build
Maybe one that didn’t come back? Cheers Bennie
el_freddo replied to SubVAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing wrong with these tensioners. Just make sure it’s genuine. If you want to swap over to the later tensioner, you’ll need the matching mounting plate. And also check out YouTube videos of their knocking tensioners when the seal breaks on them. Always go genuine with the tensioner for this reason! Cheers Bennie
el_freddo replied to SubVAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah wow, I’ve never seen a tensioner like that before! I’d get a second hand one. Install it, reset the cam and crank timing, and get the engine started. THEN look into buying a full cam kit. Don’t get the kit until the engine is running, otherwise it’s a potential loss of money in the event you can’t get the engine running. Cheers Bennie
New XV owner
Welcome to the forum MM. Not too many XV owners around on the forum - maybe you’ll be the start of that trend?? Cheers Bennie
el_freddo replied to SubVAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse the crank key way as the reference. From memory it’s 180* out from the timing mark on the crank timing gear. If the keyway is at 6 o’clock and the cam markers don’t line up, you’ve found your issue. Make sure you use the little line on the cam wheels to line things up, not the arrow! Cheers Bennie
Radio turn in when opening doors.
PS: actually, grounding to the door switch wouldn’t work I don’t think. I’ve confused myself on this one now...
Have you grounded the radio to a door switch wire? If that switch is dicky, it would explain the way it randomly turns on. Easy check is to open the door, have the radio turn on and push the door switch button and see if there’s any change. I’ve got a Liberty that does the opposite - open a door and the radio turns off. Same deal I’m sure, just wired differently. Cheers Bennie
Made by Nike! I love it. That’s actually the Fuji heavy industries logo, they’re the parent company or something that owns Subaru I believe. The EA82 was closed deck too. It didn’t do much for the cooling system, and any strength gained wasn’t worth it really. Pretty cool looking engine though. Are the exhaust ports singles or Siamese and a single? Cheers Bennie
What color is my Subie?
Radiator upper support panel or the “walls” of the engine bay back from the radiator up to and including the strut tower is where you’ll typically find your colour code. If you’ve got the original paperwork in the owners manual I’m sure you’ll find it in there. Cheers Bennie
Roof rack placement
Well there you go. I just learned something new. Cheers! Bennie
‘83 GL wagon (manual) 4x4 needs transmission work!
I should add (because I missed it yesterday) that the pinion shaft end nut is hard to get to because of the casing you’re trying to remove - the casing obscures straight line tool access to the end of the pinion shaft. And how you stop the diff from rotating is something I haven’t worked out. Cheers Bennie
Roof rack placement
I don’t think there ever was a stock one - they’re an after factory item, possibly added by the dealer as an extra. Cheers Bennie
Roof rack placement
Place them evenly on the roof where you want them - ensuring the cross bars still fit (probably best to have them fitted to the rails so you can get them square on the roof). Be sure not to drill your holes “too deep” - aka don’t let the drill bit sink into the roof, otherwise kiss your headlining goodbye. Also rust proof the holes before fitting the rivnut. You’ll thank yourself later for taking the time to do this! Cheers Bennie
Good luck with it mate. The EA82 five speed is DIY-able. But I found the old EA81 four speed a pain in the arse and I really don’t know how ppl do it. I only needed to open the old box and an angle grinder was involved in the end... Once you’ve got the rear extension housing off, the pinion shaft end nut seems to be required to be removed to get the mid/rear housing off. I gave up and introduced it to the angle grinder. A 5spd conversion would be easier and make the vehicle more enjoyable to drive long term. Cheers Bennie
RX Struts
@carfreak85 - what a tease mate! You’ve got the rates right? Could you post them here? Many would be interested and some might even order a custom set of springs/shocks as per the old specs. Cheers Bennie
Newbie from TN
Welcome. And a targa to boot too! Cheers Bennie
Will an EJ251 shortblock work with EJ253 heads?
el_freddo replied to billyedtimmy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe heads will bolt on. You’ll have to investigate the differences in the piston if any. Other than the piston question, it’ll bolt together etc. Cheers Bennie
request for advice re: electrical problem
el_freddo replied to doris's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd make sure the switch is compressed otherwise the circuit is closed, same as if you have your foot on the brakes. With a second switch plugged in you can at least have someone manipulate it while you check the tail lights out Cheers Bennie
“BRU” Our new workhorse.
There’s definitely a difference in the rear. It should be good for what you’re after Cheers Bennie
el_freddo replied to doris's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAn auto sparky is basically an electrician that is specialised in automotive electricals. They’re completely different to domestic electricians that work on houses etc. They can usually do more but aren’t full blown (qualified) mechanics. I hope for you that it’s an easy fix! Cheers Bennie
Looks good mate. Beefier rear outback struts makes sense to me - more rear overhang on the outback and possibly a heavier body too. You need to to a whole car pic to show the after effect. Cheers Bennie
