128
Subaru brat rear differential question
el_freddo replied to Atteblo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You’re talking about 4wd bind. Since there’s no centre diff to allow differences in front and rear axle rotation, the gearbox and pinion shafts are effectively working against each other. With all four wheels on the ground the inside wheels will try to spin to reduce the stresses on the drive train. If you try to drive up an obsticale that compresses the suspension ina diagonal fashion - eg: front left and rear right, the front right and rear left will loose traction and both wheels will spin, losing much of not all of the vehicle’s momentum. This is due to two open diffs and a locked centre between the two axles. If you have an LSD in the rear, you’re more likely to power over the obsticale until a rear wheel is lifted, at which point the LSD won’t be useful. Cheers Bennie -
84 gl turbo wagon temperature hot.
el_freddo replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Normal operating temp where the thermostat is not fully open, so it’s monitoring the temp as such: Thermo fan kick-in/ON temp: Looking at your pic in comparison, it’s right on the same mark for thermo fan ON. I haven’t looked to see at what point on the gauge that the fans turn off. And don’t worry about my oil pressure, I need to put the sender unit on and hook it up as this is a relatively fresh dashboard conversion in my Brumby. Cheers Bennie -
1985 GL EA82 manual choke swap
el_freddo replied to Turkeyberry's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did something similar for 18months until I was forced to swap inlet manifolds due to a cracked thermostat base. It used to need a shot of fuel down the carb and a good, strong battery to get it started (lots of cranking and hope!) After swapping the intake manifold to an auto choke unit it started and ran ace every time! Then it was EJ’d and I’ve never looked back since. So much better!! Cheers Bennie -
That’s a normal level of operating temp - it’s the point where your fans kick in. My brumby does the same, and with the mid 30*C weather we’re having already atm, it’s there all the time when sitting in traffic, once moving it usually drops back down. I’ll grab a couple of pics over the next few days to show normal running temp and thermo fan kick in point. Cheers Bennie -
Clutch pedal very hard to start pushing in...
el_freddo replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You won’t fit a LHD cable to a RHD subi. What you have there is a DL L series or Leone wagon. They’re like the black sheep of the Subaru family in a few ways, are parts interpretation books quite often mix them up with the MY and the Liberty models. With the pressure plate yours will be the larger one for the 4wd gearbox. The 2wd gearbox uses a smaller clutch pressure plate and disc - at least that’s what I found with the series 1 fwd sedans, I’m not 100% sure they kept this setup in the serie 2 fwd L’s. Cheers Bennie -
If that was a historical code I’d be clearing that ASAP. The crank angle sensor could cause a cut out issue, I’ve not know them to create a hesitation, just loss of all power/rpm until the engine stalls. The crank angle sensor could be the issue, while rare, it could be a good avenue to look into. Go second hand. Cheers Bennie
88 gl wagon spfi stalls after fully warmed up.
el_freddo replied to KE7CWO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was going to say new fuel pump required, same line as naru2 is on with the fuel pressure. Cheers Bennie -
ea82 lifter tick & bubbles in oil
el_freddo replied to wysubey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My take on the TOD. Air or lack of oil pressure in the HLA’s allowing the piston/knob (part that the cam follower sits on) to bottom out internally in the HLA. This eventually wears out the base of the HLA where this piston/knob piece sits, allowing oil to pass freely out to the open space of the engine’s internal area, thus not maintaining pressure or keeping the HLAs pumped up and doing their thing. Best solution to this is an EJ. Worked for me. My EJ has a quieter “TOD” when the oil level is at the low mark Cheers Bennie -
83 GL Automatic runs rough until warm
el_freddo replied to Scoby4wd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I’m with DaveT on this - it’s an issue with the auto choke. Cheers Bennie -
Sick looking hatch! I’d have one if they were available over here. Same for the L series RXII coupe! Cheers Bennie
1984 GL Wagon 4wd needs radiator
el_freddo replied to markjs_pnw's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Stick with anything EA81 and it’ll fit. As for junkyard item vs chain store vs quality radiator builder, I’d go the builder if possible. You might be surprised with the cost they could build a radiator for. They usually need your old one as a template if the vehicle is not staying with them. Cheers Bennie -
rear drive loyale conversion?
el_freddo replied to jaytee5211's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They were developed by some members from the board from memory. It was a very interesting process! I don’t know if any are available these days though. Someone will know the dude’s contact details. Cheers Bennie -
Put an EJ engine in with the EJ gearbox and you’ll have some of the usual fitment mods to do as required when doing the L series 5 speed. Some required mods will be more involved than others compared to the usual L series 5spd conversion. And I highly doubt you’ll find a dual range EJ box at a parts yard in the states. All the best with whatever you decide. Cheers Bennie
NEW Brat Tailgates available!!!
el_freddo replied to skishop69's topic in Old Gen.: 80's GL/DL/XT/Loyales...
International shipping from Oz is the killer bit. Cheers Bennie -
@oczuk32 - correct. Chrome strip (plastic) is separate to windscreen rubber. Cheers Bennie
- 64 replies
- Ea81
- windshield
(and 8 more)
Tagged with:
That sounds like a dead cam belt tensioner. Removed LHS cam cover and check if the tensioner is bouncing. There are plenty of YouTube videos about this. If you can’t see it, it doesn’t mean it’s good, use the above link to the stethoscope and use this to properly diagnose the issue. We had one go bad on our EJ251 and it looked fine while running but the stethoscope pinned the noise with the tensioner. Swapped for OEM and no issues since Cheers Bennie
Yeah they’ve been on the market for a while now, probably a bit over a year. I’ve toyed with the idea of getting one for the shelf - waiting for the day my beloved ute gets a respray after all the dents are pulled out. I believe they ship international Cheers Bennie -
84 gl turbo wagon running rich
Which then equates to about $4.11 US. So we’re better off by a bit of a margin. Who would’ve thought?? (That is provided 91 is their highest rated fuel for domestic use) Cheers Bennie
