128
EJ swap wiring harness question
el_freddo replied to bratboy1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The only wiring diagram you really need is the ECU pinout. The main power relay diagram can be useful to actually (for your first cut down), but really the big yellow wire is power and the little yellow with a stripe (from memory but can’t remember the strep colour). The large black trace red wire is fuel pump power wire. Cheers Bennie -
21 = fuel pump relay. 22 doesn’t look familiar. 8 = igniter. 11 will be clutch and brake switches for cruise control The others I don’t know. The best way to do it is to unwrap the wiring, then trace all wiring from the ECU and tape these wires together as you fish them out from any unwanted wires. Once you’ve got all of these wires taped, find where any tee off to other things and what they’re for - eg: fuel pump relay or sensors on engine. Anything you don’t need (once correctly identified!), cut and remove from the loom. You should end up with: - ignition power - permanent power - backup power - starter wire (for ECU to richen the mixture for cold starts, references the start wire to the starter motor) - fuel pump wire - temp and oil light wires (use the EA wiring for this). - vehicle speed sensor wiring It’s best to have the wiring diagram to get your head around it. The Haynes manual has a good diagram of the ECU pinout with wire colours that’s generally easier to read than the FSM wiring diagrams. Put a fuse panel between those power wires including the starter reference wire and the EA loom. You will only need the vehicle speed sensor wire to tap into your factory L series loom. If MY another vehicle speed sensor source needs to be made. Cheers Bennie -
It’s been suggested that the wobble feeling from the front left is a driveshaft. While the box is out I’ll swap the driveshafts over and see if the issue moves with it. Gearbox looks really good. The old one had a dead bearing in the upper shaft between 4th and 5th. I’ll throw some new front diff bearings in while the box is apart. I can’t see any damage to the diff bearings or anything abnormal. They do look well worn though, no noises at all in the <30km I’ve driven with this gearbox in the car. Cheers Bennie
Ouch. Never throw anything away until a week after the job is done. Then you’ll need something the week later Murphy’s Law. I believe there is only two types of crank and cam pulleys, but I could be wrong. Best bet is to find the same model and year build as your subi in the parts yard, then pilfer the crank sprocket and camwheel. Cheers Bennie
Sounds like a money grab to me. I’ve never heard of this happening. But then again, I’ve only ever heard of brake lines being flushed with fresh brake fluid until it comes out the other end clean. I’d also look up symptoms of gelled brake fluid and compare that info to what you’re experiencing. All the best with it. Cheers Bennie
A windscreen place over here had no issues getting a new windscreen and windscreen rubber for my brumby three months ago I think you can also find them on eBay.com.au Cheers Bennie
- 64 replies
- Ea81
- windshield
(and 8 more)
Tagged with:
84 gl turbo wagon running rich
el_freddo replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Correct. I should’ve said I meant under boost conditions. That’s the ECU’s job. Non tunable so you’re stuck with the factory tune unless you go aftermarket management. Our task is to ensure all sensors are working correctly so the ECU can do its thing correctly. Cheers Bennie -
The patient: 1999/2000 RX Liberty wagon (EJ251) 5spd manual. Issue: swapped in second hand gearbox (pick a part special!) only to find the vehicle now has a wobble like feeling from the front left when under acceleration, becomes worse with heavier acceleration. All other times the vehicle generally feels unsettled. Both of these issues were not present with the last gearbox. The other issue is that I have that totally awesome “catch-let go-catch-let” go feeling or experience when turning tight such as when performing a U turn - classic symptoms of a dead centre diff.Questions: 1) can a stuffed centre diff create the issue with the front end that I’m experiencing?2) can the viscous gel stuff leak from the viscous LSD housing, and if so, what does it look like? Question 2 was asked because after stripping down the old box that was replaced, I’ve found a ball of what looks like silicone near the front diff area, and in between the drive and output of the centre diff is the same sort of material. It does seem like silicone but it’s just odd. This gearbox has presumably done over 400k km now - if it hasnt been changed at some point. It was swapped because of a bearing noise and it was slipping out of gear (possibly due to shot pitch stopper rod and gearboxs mount).Upon rotating the centre diff it seems the noise is in the rear bearing. This centre diff is good so itll end up in the wagon either way - unless that grey material is the viscous gel stuff. The plan is to build one good box from the two. I’ll be replacing the front diff bearings, all seals and most likely use the centre diff bearings from the replacement box as there’s zero noise from this box, other than the noise when performing a U turn. Cheers Bennie
'91 Loyale Front End EA82
el_freddo replied to 5MileDrive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Link didn’t load for me, but the answer is no, justy parts will not fit your L series. Cheers Bennie -
XT rear crossmember interchangeability.
el_freddo replied to Inclement's topic in Old Gen.: 80's GL/DL/XT/Loyales...
L series 4wd sedan (rare!) or wagon will be a direct replacement. Put your swing arms on for the swaybar and rear discs. The L series 2wd will fit but needs the front diff mount welded on. Cheers Bennie -
New owner for 2001 LL Bean Outback
el_freddo replied to Phermenter's topic in Meet n' Greet. Your USMB Welcome Center
Welcome Mike! Seems like you’re pretty sorted Cheers Bennie -
How do I put this moulding back on?
el_freddo replied to Zip Tie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine is the same! New clips would be a good idea. Cheers Bennie -
EA81T boost sensor location?
el_freddo replied to Datnastybrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You shouldn’t. It’s there to only indicate you’re on boost. If you want accuracy get an aftermarket boost gauge that actually plugs into the intake manifold Cheers Bennie -
I used an external efi fuel pump. Over here the VN commodore 5L V8 unit does the job easy. I’m sure stateside has something very similar. I enlarged my fuel line with the use of a supply line from another L series - the MPFI vehicle’s already have a larger return line, so the carb supply line fits the bill well as a return line. Most getaway without doing this though. Cheers Bennie
You’ll either find valves that “sit” lower than the rest (bent) or you’ll find nothing. I reckon two teeth out wouldn’t do anything nasty physically. But for engine operation it might just be enough to upset the apple cart. I can understand why you won’t sleep well tonight, but I reckon you’ll be fine. Cheers Bennie
Ea to Ej swap advice
el_freddo replied to Arsenal25boy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Keep your current trans if you want the dual range 4wd. If it’s on road traction you’re after and not 4wd capability, then go the AWD gearbox. Read up on the EJ conversion document that’s floating around here. Really any EJ engine will do the trick. Pick one that does NOT have factory security where the ECU talks to the key fob (for the want of a better description). This will make the wiring cut down so much easier to do. You’ll love the EJ! Cheers Bennie -
Convert FWD to RWD and keep 4x4 Brumby
el_freddo replied to Cinereus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I see you’re in Bendigo. We should catch up and talk shop. You can check out Ruby Scoo too - once I get her back from my folks who are dailying it while they get a new vehicle. They’re “loving” it You don’t need the wrx box, it’s just as strong as every other box out there in the EJ series (except the 6 speed). Get the SG Foz box from a 2L - a good start to build on. Cheers Bennie- 11 replies
- convert fwd to rwd and keep 4x4 brumby
- fwd to rwd
(and 2 more)
Tagged with:
And any OEM L series parts are basically NLA - it’s believed that the tsunami that took out the Fukushima nuclear power plant also took out the warehouse that had all the MY and L series parts. A guy in our car club got a new facia for his Vortex, ex Japan. After the tsunami he’s had zero success in getting other trim pieces that were listed as available pre tsunami. I’ve also not come across this issue and our Aussie sun is pretty harsh on car components. Cheers Bennie
And for melting pistons. Hence why the rich mixture - helps cool the piston. Cheers Bennie -
Simply put, no. But if you could work out how to fit floating front hubs that are manually engaged, then yes. But you’ll always be powering the front diff. Once you’ve done the front end, you’ll need to stiffen up the rear end to make it go the distance and last for a long time. Cheers Bennie- 11 replies
- fwd to rwd
(and 2 more)
Tagged with:
