135
1988 Subaru gl how to lift
el_freddo replied to Jdog2004's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Subarino auto in Perth sells a complete 2 inch kit for the MY and L series. Shipping to you would be the costly bit, no harm in asking about the kit anyway. Cheers Bennie -
Sometimes it’s the simple things that cause the most grief (and wallet pain!). This relay mod is common on the early Liberty/Legacy’s too Cheers Bennie
- 7 replies
- ignition starting not loyale
- collant sensor
(and 4 more)
Tagged with:
Heads and all the associated gear will move over to the replacement block regardless of where it came from. The thing to check out is any differences in the pistons that may affect small things that may or may not become an issue. Sorry I can’t be more definitive on that front, I haven’t played much with the later model engine blocks so don’t know for sure. Cheers Bennie
It would all depend on what info the TCU wants and/or shares with the ECU. If it’s just a matter of throttle angle, speed sensor, engine revs it should be sweet if you wire it in properly. If it wants more from the ECU then it gets more complicated from there… could do a whole body loom swap and drag over the matching engine for the complete setup 🤔 Cheers Bennie
That was one of my thoughts but there’s a captive thread in that so where did the nut come from? I’d double check that you do in fact have the ball joint retainer bolt in place on either side and done up appropriately tight. You don’t want one of those ball joints dropping out and letting your hub take its own unplanned trip! My other thought was also the engine pitch stopper rod, I wonder if this was replaced with another bolt from somewhere else… Being that this was a “we” job - as in we did this and we did that… old mate isn’t stitching you up by placing this Subaru looking bolt in the mix of all your other nuts and bolts? That’s something a good mate might do as a prank! Cheers Bennie
The good news is that I can’t see it being a bolt from a major component like a ball joint or hub retainer bolt as they have captive threads, rendering that nut useless. And it’s too short for a suspension arm bolt. I’ve had this many times without issue. Keep the left over bits aside in a labelled container incase you find a missing bolt. While they’re off the vehicle consider the effort as weight reduction. Cheers Bennie
EA81 misfiring at cruise
el_freddo replied to el_freddo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks mate. Got the starting and idle issues sorted it seems. I think the idle mixture was too lean and driving it around hard for a bit may have moved come internal crud. Who knows?! Good news is it’s running well and seems to be returning good fuel economy. Cheers Bennie- 25 replies
- 1
- ea81 misfire
- ea81 cruise
(and 1 more)
Tagged with:
Worked perfect before I touched the carb. I didn’t strip any of it down and left it as is since the rebuild. It’s also summer down here atm - not very cold for morning cold starts. Cheers Bennie- 25 replies
- ea81 misfire
- ea81 cruise
(and 1 more)
Tagged with:
Ok finally got an update on this one! I bit the bullet on buying a carb kit - for a DC 306 hitachi carb. This was a HTK-421 kit. Apparently for the needle and seat for the float valve I’d need the one from the kit HT432 but I didn’t bother and didn’t swap this bit as it wasn’t flooding the bowl. All went well with the rebuild. I’ve had to readjust my idle since tuning. Other thing I need to look into is why it’s hard to start when cold. The old double pump and crank trick doesn’t get it started. Once warmed up she fired up no worries! It runs well without any misfiring which I’m stoked about! Cheers Bennie- 25 replies
- 2
- ea81 misfire
- ea81 cruise
(and 1 more)
Tagged with:
el_freddo replied to pontoontodd's topic in Off Road
That bar work looks awesome all laid out like that! Good effort creating all of that. Having it painted would have it looking primo! Cheers Bennie -
The revving higher than normal and not the usual power sounds to me like it’s an auto issue. I can’t really help out as I’m not into autos and don’t really know how they work. You might be able to get the transmission serviced or overhauled if you’re wanting to keep the old school rolling for a long time to come. That engine is bullet proof if you look after it. Cheers Bennie
That’s an internet fallacy - there’s known tech bulletins posted around that state conditions that head bolts can be reused and when they should be replaced. If you know the engine wasn’t cooked badly I’d reuse the head bolts. GD talks about cleaning them up of any scale and running a tap (or modified old head bolt) down each thread to remove any gunk in there. As NVU says, if they squeak or squeal while torquing at any stage that head bolt won’t be done to proper speck and you’ll end up with the same issue. I’m not 100% sure on what the required action in this situation is - eg: back off all bolts, replace offending unit then restart the procedure or do that ^ and replace the head gasket you just fitted. I hope this helps. Cheers Bennie
'88 DL Growling(?) front end noise
el_freddo replied to silverbulletwa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah I do! I forgot about that (been too long since driving Ruby Scoo 😢 ). I found out about the kit to refine the diff further after I had the whole gearbox together - I’m not even sure the kit is still available now. Good diff though and I want another one for my brumby build but they’re either hard to find or expensive to land in Oz. I’ll probably try a factory Torsten diff this time around, just need to save some coin. Cheers Bennie -
That’s odd that it’s “between” or most noticeable in 2nd and 3rd gears as they’re in the middle of the gear sets and furtherest away from either bearing sets. I’ve not messed with those bearings before as I didn’t have a press back then. Here’s a pic of the dual range gearbox (EA82 AWD but it’s basically the same) opened up: Only other thing I can think it being is not the bearings but 2nd and 3rd gear wearing out/whining. But that doesn’t fit the bill of what you’re explaining either with the noise being there on start up. It’s a good head scratcher! The “ting” noise is an odd one as everything in the 4wd system is rotating when you drive so I’d think you’d still hear it then too, unless it’s a chipped tooth in the 4wd system in which case you wouldn’t hear it until the gears are loaded and this will be speed dependent - usually sounds like a distinct clicking sound but this one could be reverberating to the tailshaft to make the ting sound. If you tap your tailshaft with a metal tool you’ll probably be able to recreate the sound in the garage. Do you have any issues selecting reverse or getting out of reverse? Asking as I’m wondering if the reverse slider gear is *just* disengaging enough to get another gear but still engaged enough that it’s grinding on the other gears. This would be a horrid noise at cruise! Other thinking is you have a gear selector that’s resting on a synchro creating the grinding sound. But I reckon you’d have a very crunchy gear when selecting it and trying to deselect it could be difficult. Gearboxes are fun and not as scary as ppl think they are to work on. I enjoy it when I mess around with them! Cheers Bennie -
That’s pretty “awesome” that the clutch dropped its guts in your driveway and not ages away from home! I prefer to remove gearboxes from under the car now and I’m well versed at it having done several and each one was slightly different. The last one I did to replace a clutch the gearbox didn’t leave the vehicle, I slid it back as far as possible on some smooth steel tubes so I could access the pressure plate with my tools etc. Worked a treat! Cheers Bennie
