el_freddo
    126
  1. There will most likely be a black box in the drivers kick panel area, six plug from memory. These can become faulty. Although I’ve not personally experienced this. One way to tell if you have this box or not - when you turn the ignition on, does the pump usually run for a few seconds then turn off, OR does it run all the time? If it runs all the time you do not have this box. If it shuts off, you’ve got this box. Also ensure your fuel filters and lines are not blocked. Cheers Bennie
  2. Depends on what you put in. The EA AWD box will bolt straight in but will need MPFI shafts for the larger diff stub output shafts. EJ box will need custom crossmember, tailshaft, possibly gear selector linkages and matching rear diff ratio of swapping ratios. And you’ll need the MPFI drive shaft for the larger diff stub output shaft. When you say “go up the mountains” - does this mean offroad or on the black top through the twisties? Cheers Bennie
  3. Shame you have to move this on. Such a unique car! Cheers Bennie
  4. Correct. Trans swap is involved either way you go. Cheers Bennie
  5. You guys are kind of stuck in America if you like the dual range. With those wheels you should be alright to pull that speed. For a period of time it probably won’t be fun. You could drop in the RXII AWD dual range box, swap the low range to the good L series version, swap the diff output stubs while you’re there too. Fourth ratio can’t be swapped without swapping 3rd as well. One side of the gearing (I can’t remember off the top of my head if it’s the top or bottom set) are cast/“stuck” together. 5th gear is a Lone Ranger and can be swapped independently - and the EJ phase 1 5th ratios are a direct swap. In the RX box you might find those ratios a bit more user friendly for what you want. These ratios are “wide” as opposed to the NA set that are “close”. The AWD box has the same internals as the EJ internals with the exception to the dual range - which makes single and dual range internals NOT interchangeable. I’ve got the RXII AWD box behind my EJ22, 4.111:1 diff ratio (not an easy swap but possible with a machinist!), turning 27 inch diametre tyres, matched speedo. I put in a different 5th ratio that turned out to be too short (same as what you’re running now - 0.87:1 - I wanted 0.78 from memory, the box I think came with 0.73:1 - which I should’ve just tried in the first place.). So you’ve got some options, but they’re limited if you’re married to the dual range. If dual range doesn’t matter, you’ve got loads of options from the EJ box series. Cheers Bennie
  6. This is happening Stock brumby dash up top. This is the ONLY factory available dashboard and instrument cluster for the brumby in Australia. The lower dashboard and six gauge analogue cluster is from some touring wagons (most are digital), Coupés and the GL sedan. And of course it’s all Lego So this will be in soon. EJ wiring loom is being laid out for future use too Cheers Bennie
  7. The ‘99 still had the EJ22. But with a small change in the valve setup it became interference. Externally the engines look the same. Cheers Bennie
  8. Yep, same boot, almost the same issue as what you have there. A few more months (maybe) and it would’ve gone the same way as yours. The other three boots up front are fine - because they’re not located near the exhaust! I’m lookig at making a heat shield for the boot to help increase its life expectancy. I hope that repaired shaft does the job for you Cheers Bennie
  9. There’s a permanent power wire, then there’s an ignition “ON” wire. You now need to find and check that ignition wire. Some of the SPFI conversion documents could provide you with the ECU pinouts to help find the ignition wire. I can’t remember if the SPFI ECU has one, but the ignition relay could be dead too. Worth looking into anyway. Cheers Bennie
  10. Correct. The blown fuse you found - has it blown again? If so I’d start looking for any wiring that’s “aftermarket” that could be creating a short. It could even be the ignition switch shorting out and blowing the fuse. There are many reasons why your engine isn’t running, and that blown fuse is a good place to start interrogating the wiring. I really hope it’s an easy fix. Make sure the fuse you’re using is the correct rating. Anything more and you could be in for trouble. Cheers Bennie
  11. Another solution for the manual: http://subarugears.com/ I’m thinking there’s a reason why no one has a reverse cut gear for the auto. Either no one has worked it out (not possible) or there’s a very simple solution that doesn’t require modified parts. The reduction gear on hub idea is probably going to be the best option after working out the rear section of the auto box as FerGloyal discusses in previous posts. Cheers Bennie
  12. I would say the issue is the O ring in the head gasket that holds the oil pressure to the head has let go, it’s now leaking oil into the coolant gallery. That’s a head gasket job to fix that issue. Cheers Bennie
  13. If you’ve done the preventative maintenance on the EJ it’ll give you no trouble and you’ll love it. Have you got your adaptor plate from Subarino Auto Electrics? Hit him up if you haven’t already. You can find him on gumtree or PM me and I’ll send you his details Cheers Bennie
  14. I’d say it’s rings. If you had them out to inspect the rings you should’ve replaced them. I would’ve said valve stem seals, but since it’s longer in duration than just initial startup it seems like oil is allowed past the rings on shutdown. Have you overfilled the oil to compensate for the oil use? This could be exasibating the oil burn on start up and initial running. Cheers Bennie
  15. If a bearing fails in an idler or a tensioner the belt tends to melt and make a huge mess rather than freying and snapping. Cleaning the melted belt from the teeth of the oil pump, crank and cam wheels takes ages, not “the usual” 30 mins on the side of the road. Cheers Bennie
  16. Haha, the infamous Weber upgrade! Best upgrade IMHO. I saved coin and never did the Weber carb Cheers Bennie
  17. Love the fix! And you’ll love the EJ in there. I’m guessing you’ve got a front wheel drive gearbox? You’ll want to upgrade that to an AWD box to help get the power down to the road Cheers Bennie
  18. We still love pics! Mine are nuggets too - “good from afar, but far from good”! ^ I’ve had Ruby Scoo for well over ten years, I think I’m coming up on fifteen years. She’s got a computer but that’s never given me any trouble and I love the reliability, power and “starts every time” factor that came with the ECU and EJ22. Mid you’re willing, I’m keen to see pics of yours, as I’m sure others are (or start a thread in the members rides subforum). Cheers Bennie
  19. Noise/rattle at the back of the car could be a muffler that’s broken down internally. Cheers Bennie
  20. It could be the clutch cable chewing into the metal outer casing, or it could be an issue with the pressure plate. Also check the retainer pin at the top of the clutch pedal - mine recently “dropped” out. I replaced it with a pin from the brake pedal, there’s a plastic safety clip and a metal circlip that holds the pin in rather than just that pushed on inverted star clip. Mine feels much better now that the pin is intalled correctly. I don’t know how long it was only holding by one side of the clutch cable U piece that the pin passes through on both sides. Cheers Bennie
  21. While you’re at it get an EJ to help drag all that extra weight around reliably! (It has to be said!) Cheers Bennie
  22. There are alternator upgrade mods documented on the forum, they might be worth looking into as a supporting mod for your audio. Wysubey is correct, you need a spacer block for a CD head unit. I used a piece of wood that was shaped to fit, it’s temporaray I said as I fitted it over 10 years ago! You can buy plastic professional looking spacers, they should still be available but I haven’t looked in ages. Cheers Bennie
  23. The coil the dude mentioned is used with points. If you have electronic ignition in the dizzy (eg no points in the dizzy) then you don’t need this coil thingymajiga. Cheers Bennie
  24. Ramps will be fine as you’re not playing with the suspension or wheels. I’d recommend lifting the engine out to do the work. So much easier! Cheers Bennie
