el_freddo
  1. I would say it’s @ShawnW at a guess. Maybe try making this a private conversation via PM, otherwise hopefully he’ll respond for you with a public reply to clean up this matter. It’s all very one sided! Cheers Bennie
  2. Through the torque converter? I can’t see how this works. Cheers Bennie
  3. Me too! Even in $US!! Only if it’s the L series one though. If it’s the EJ dual range forget it, we’ve got plenty of them cheaper than $200. Cheers Bennie
  4. Can’t happen at idle. Are your valve clearances correctly adjusted? Cheers Bennie
  5. Yep, start at the compression check. I’m still yet to do mine. Also check the shaft play on the throttle body of the carb. I reckon this can easily mean out the mixture by sucking in air after the Venturi, leading to predetonation. Cheers Bennie
  6. Not consider, DO! And not “should” either. Nike Cheers Bennie
  7. I’m putting money on wheel bearings. The cv shafts shouldn’t be giving you any trouble since they’re generally ever used - if you don’t fit into this category, then they could be a possibility. Cheers Bennie
  8. Diff ratio swap. 4.44 is the shortest you can get. Good luck fitting this to a PT4wd EA 5spd box, the pinion shaft in these gearboxes is part of the lower gearset. In the AWD EJ gearboxes the pinion shaft lives in a tube that the lower gearset is fitted to. Major mods needed. Match the rear diff to the front diff or just run in 3rd on the highway? Cheers Bennie
  9. I’d reuse the belt unless it is damaged during removal. Best of luck with the replacement tensioner, I’m also glad to hear that’s what it is and not bottom end knock. Cheers Bennie
  10. Try doing it up tighter I give my 17mm spanner a good double tap with my hand to “hit it home”. Cheers Bennie
  11. Over here the go to tube to use is called “bunny tube”. It’s the standard for fixed lines. Since we don’t have snow and salt on our roads, copper brake lines are illegal due to the ability of the copper tube expanding the blowing out. For the flexible lines braided is the way to go. Our ADRs dictate that braided lines must be covered in a plastic like liner, basically a tube laminate. That’s what I got when I asked for braided lines. Any good brake shop will point you in the right direction for what you need. Cheers Bennie
  12. Got nothing on Melbourne/Victorian weather - winter in the morning, spring by mid morning, summer in the arvo and autumn coming into the evening. The last week we literally had all seasons in one day that also included hail. The day after it snowed down to 700m - a pretty rare event for winter let alone near the end of spring. Going back to the ignition switch - I agree with Numbchux - the starter switch is designed NOT to have power to accessories when in the start position. Thus without a power connection in the start position, there can never be power to accessories unless something went massively wrong, in which case you’d have larger issues at hand too. You could test the wiring and the inhibitor switch by putting 12v to the starter wire, try in park and neutral. If both work, the issue points at the ignition switch. Cheers Bennie
  13. What nvu said. Or buy several washerswhile at the dealership Cheers Bennie
  14. From memory it was $AU220. It was up there with a main radiator replacement but after doing three dash pulls to install second hand units (that all blew in a short amount of time), it was a good investment and it continues to be. Cheers Bennie
  15. Take your old unit to a radiator specialist and have them make one up. Years ago I lashed out on a new all copper/brass unit and haven’t looked back. The rad shop was able to order one in. No idea on part number though I’m sorry. Cheers Bennie
  16. Like any engine conversion - wiring conversion, dash out... it’s been done before so nothing new there. Aftermarket engine management is another option - then there’s the cost of tuning etc. Not for the faint of heart! And as GD said above, it’s costly if you’re not doing a DIY job (and know what you’re doing). There are two H6 conversions getting around Oz that I know of. Both used to be in our off-roading group, the first was a Gen2 Liberty, the other is a SG Foz (from memory). The Liberty was sold on, no idea where it is now. The forester is still owned by my mate, but he now lives interstate. Cheers Bennie
  17. If you have issues with your cam or crank sensors, you’ll usually experience engine cut out or loss of power. It would not be nice to drive if you could get it out of the driveway. If the code is actually the O2 sensor, you need to check this out. It’s located near the RHS driver shaft’s inner joint, but in the exhaust in front of the cat. You’ll see what looks like a probe with wires coming from it. That’ll be the O2 sensor. As for the timing belt. A visual inspection would be good. If you’re really worried just do it. Cheers Bennie
  18. Next step is obviously to read the codes. Record the codes, then systematically check/clean (if appropriate) each sensor. What was the main relay part number in the end? Cheers Bennie
  19. Carpet is available on eBay. Dunno if you can get it in the states. It’s about $AU200 delivered here now. It’s a nice update to the interior as we only got vinyl floors in ours. Dunno about seat covers. You should track down an interior upholsterer and see what they can do Cheers Bennie
  20. I’ve had that happen on my L series too. I replaced the tailshaft/prop shaft with a unit from the wreckers (got lucky with that!) when interstate. Fitted it and drove 800km home from interstate Cheers Bennie
  21. Dead ignition module in the dizzy. Replace this AND the coil. If a coil dies it takes out the expensive ignition module. You wont have spark. No spark, no fuel pump operation due to the fuel cut relay doing its job. Cheers Bennie
  22. Do a cold start and see if you can hear any knocking. I would say there isn’t any. What I think you might be hearing is actually pre-detonation. This can be due to lowered compression, poor timing, worn plugs, oil mist (from blow by pressurising the crank case), worn rings. If you do hear constant knocking at cold start up, even after oil pressure is built up, you’ve got rod knock. Unlikely in these engines unless constantly over-revved, and/or starved of oil. Cheers Bennie
  23. By clutch cover do you mean the clutch pressure plate? Cheers Bennie
