126
The hard start and rough idle could be too much fuel. I suspect you’re using the injectors from the EJ25, on start up a rich fuel mixture is used to help aid starting. This extra shot combined with the smaller engine capacity could cause an over fuelling situation which wouldn’t be great when starting. As for the codes, if the temp sensor was dropped or knocked when swapped with the coolant crossover pipe it could’ve died, especially if it was already hanging in there by a thread so to speak. The other codes, best of luck with those I’m sorry. Sometimes you might get lucky and have one code sorted and the rest follow suit... it doesn’t always happen, but it can at times. Cheers Bennie
New to me 1990 Loyale
el_freddo replied to IFlyS5's topic in Meet n' Greet. Your USMB Welcome Center
And a lack of need for more speed/power! Cheers Bennie -
As for the air compressor, you might find one in an early legacy that has air suspension, even if it has coil springs - many ppl don’t remove the compressor. And I believe it’s the same unit between the L and the Legacy, maybe with a different mounting plate. It’s in the same location too - front left guard Thinking about it, your air system probably has leaks that lead to the air compressor burning out due to being overworked/worked too long too often. Cheers Bennie
Fuel stink and bubbling after parking XT-T
el_freddo replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All rubber EFI fuel lines in good condition? The only time I’ve smelt fuel is when I had a perished rubber fuel line that was leaking fuel... It’s odd that you can smell fuel too. Cheers Bennie -
I should add that the rear end is different for 2wd vs 4wd too. The swnig arms have different setups for the bearings - 2wd has a fixed stub axle, 4wd has a rotating stub axle. The K frame has a tab for the rear diff’s front mount with 4wd, the 2wd frame does not This mount can be welded in place and swing arms are interchangeable Cheers Bennie
My EJ22 has lifter tick when the oil is low. It’s like a built in indicator! Lifter tick is very different to knock in sound. Tick is a higher pitched frequency than that of knock which is a much lower tone sound. And knock from a dead/dying bearing sounds like it’s deep in the engine too (which it is). Cheers Bennie
Suspension parts are interchanageble. If your XT is 4wd/AWD, you’ll want the rear struts from a 4wd L series sedan or wagon. Front struts are a direct swap over, as are the rear swing arms and “K” frame, and the front control arms and radius rods. The engine crossmember is turbo specific, but the NA unit can be swapped in and modified for the turbo up pipe. Cheers Bennie
Welcome to the forum Ifly! Thats one super clean L series! What are your plans for her? Cheers Bennie -
I don’t think it’s just the XT-t Jono. My L series with EFI fuel tank and EJ22 does the same. Not all the time though. I haven’t looked into it as there’s no change in performance etc. Cheers Bennie -
You should be able to get a seal kit and install that on your current calipers. From memory there’s an O ring with a square cross-sectional shape (as in, if you cut the O ring it’s a square-ish shape rather than a round shape - clear as mud?), this may need to be fitted with a particular orientation. Do your reading/research! I’ve done my L series front calipers in a campground car park before we went bush once. It helps to have all the parts and tools on hand Cheers Bennie
Diff lock might not lock while idling if the dog gears aren’t aligned. Jack up a wheel, idle the car (properly chocked), flick the diff lock switch to locked, rotate lifted wheel until the centre diff is locked - or until it’s obvious there’s an issue with the diff lock actuation system. If you’ve got vacuum to the solenoids and they click as they should, the next thing to check is the diaphragm actuator. You could do this by disconnecting the diff lock arm on the RHS of the gearbox, then use the switch with the engine idling to see if the cable moves. It’s a pretty simple system really! Cheers Bennie
I’m very happy with this engine. The reason for the HG swap this time is to upgrade to the HGs with the part numbers as recommended by GD. I’m hoping this kills those stupid external leaks! Thanks @Numbchux! This puts me back at ease with reusing the bolts. This vehicle is a country cruiser - it eats kilometres! So it’s not an all out powerhouse. Cheers Bennie
- 3 replies
- ej
- head bolts
(and 1 more)
Tagged with:
Yeah sorry I was talking replacing the plastic cam wheel on the phase two EJ. This was in reply to my own post above asking whether the phase one RHS can wheel is interchangeable in the Gen3. It’s not, even though it’s got the key way and timing mark in the exact same location as the plastic phase two unit. Cheers Bennie
- 17 replies
- timing belt
- timing belt cover
(and 3 more)
Tagged with:
Simple question: If the EJ head bolts are in good condition, haven’t been over heated etc, how many times can they be reused before new ones should be sourced and used? Engine in question is an EJ251 at the moment. Cheers Bennie
- 3 replies
- ej
- head bolts
(and 1 more)
Tagged with:
And for the record, earlier phase1 EJ metal cam wheels don’t fit due to the shape of things from the head behind the wheel. Cheers Bennie
- 17 replies
- timing belt
- timing belt cover
(and 3 more)
Tagged with:
Hey Art, Welcome to the forum. Again (if you’ve seen my other post), best to post this in the relevant sub forum - being the 90’s to present forum. Cheers Bennie
Probably best to post this in the EJ post 90’s section since it’s a Forester in question. But i believe the clutch can be replaced without removing the compressor. I’ve never done it though... Cheers Bennie
That “new” piston in arm tensioner does the knocking noise all the time, some you can see the tensioner bouncing up and down with the cam cover removed. Ours required a stethoscope to properly diagnose as it passed the visual inspection. The other thing that could be rattling is the dust cover under the bell housing. Cheers Bennie
Subaru EA82T compression comes and goes
el_freddo replied to K-dog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When you say timing is correct, how was the procedure done/how do the cams and crank line up? If it’s correct, all EA82s will have one cam in the 12 o’clock position, crank in the same and the other cam at 6 o’clock. I say this as my first thought was that both cams and crank were lined up at the 12 o’clock position then the belts were fitted. This produces an engine that runs only on one bank. To check this theory you can either check the timing, or get it running and pull the leads on one bank, if it stalls, restart with all leads connected then try the other side. If one cam is out, it will continue running exactly the same with the leads pulled on the bank that has the cam out of sync. Lifters will not hold a valve open unless there’s something majorly wrong with it, in which case you’ll have other issues. @Steptoe - the NA MPFI runs 20deg BTDC, so it’s really only 2 degrees advanced on the NA block. And what you found with the valve spring tension was quite the find and not something I’d ever look into! Cheers Bennie -
Yeah it didn’t run well at all. Half way to dropping my wife off at work one morning I thought I was running out of fuel (had just done a 600+km round trip the day before on one tank), I put my jerry can in, no change, limped it home about 2km. After setting up the shed I got her started, drove her in and found this after tearing down the front end. Glad the EJ22E non interference, any more of a change in timing and it would’ve been a different story with any other EJ... Cheers Bennie
