el_freddo
    128
  1. You should be able to get a seal kit and install that on your current calipers. From memory there’s an O ring with a square cross-sectional shape (as in, if you cut the O ring it’s a square-ish shape rather than a round shape - clear as mud?), this may need to be fitted with a particular orientation. Do your reading/research! I’ve done my L series front calipers in a campground car park before we went bush once. It helps to have all the parts and tools on hand Cheers Bennie
  2. Diff lock might not lock while idling if the dog gears aren’t aligned. Jack up a wheel, idle the car (properly chocked), flick the diff lock switch to locked, rotate lifted wheel until the centre diff is locked - or until it’s obvious there’s an issue with the diff lock actuation system. If you’ve got vacuum to the solenoids and they click as they should, the next thing to check is the diaphragm actuator. You could do this by disconnecting the diff lock arm on the RHS of the gearbox, then use the switch with the engine idling to see if the cable moves. It’s a pretty simple system really! Cheers Bennie
  3. I’m very happy with this engine. The reason for the HG swap this time is to upgrade to the HGs with the part numbers as recommended by GD. I’m hoping this kills those stupid external leaks! Thanks @Numbchux! This puts me back at ease with reusing the bolts. This vehicle is a country cruiser - it eats kilometres! So it’s not an all out powerhouse. Cheers Bennie
  4. Yeah sorry I was talking replacing the plastic cam wheel on the phase two EJ. This was in reply to my own post above asking whether the phase one RHS can wheel is interchangeable in the Gen3. It’s not, even though it’s got the key way and timing mark in the exact same location as the plastic phase two unit. Cheers Bennie
  5. Simple question: If the EJ head bolts are in good condition, haven’t been over heated etc, how many times can they be reused before new ones should be sourced and used? Engine in question is an EJ251 at the moment. Cheers Bennie
  6. And for the record, earlier phase1 EJ metal cam wheels don’t fit due to the shape of things from the head behind the wheel. Cheers Bennie
  7. Don’t forget that aftermarket units are gas filled, OEM are oil filled Cheers Bennie
  8. Hey Art, Welcome to the forum. Again (if you’ve seen my other post), best to post this in the relevant sub forum - being the 90’s to present forum. Cheers Bennie
  9. Probably best to post this in the EJ post 90’s section since it’s a Forester in question. But i believe the clutch can be replaced without removing the compressor. I’ve never done it though... Cheers Bennie
  10. That “new” piston in arm tensioner does the knocking noise all the time, some you can see the tensioner bouncing up and down with the cam cover removed. Ours required a stethoscope to properly diagnose as it passed the visual inspection. The other thing that could be rattling is the dust cover under the bell housing. Cheers Bennie
  11. When you say timing is correct, how was the procedure done/how do the cams and crank line up? If it’s correct, all EA82s will have one cam in the 12 o’clock position, crank in the same and the other cam at 6 o’clock. I say this as my first thought was that both cams and crank were lined up at the 12 o’clock position then the belts were fitted. This produces an engine that runs only on one bank. To check this theory you can either check the timing, or get it running and pull the leads on one bank, if it stalls, restart with all leads connected then try the other side. If one cam is out, it will continue running exactly the same with the leads pulled on the bank that has the cam out of sync. Lifters will not hold a valve open unless there’s something majorly wrong with it, in which case you’ll have other issues. @Steptoe - the NA MPFI runs 20deg BTDC, so it’s really only 2 degrees advanced on the NA block. And what you found with the valve spring tension was quite the find and not something I’d ever look into! Cheers Bennie
  12. Yeah it didn’t run well at all. Half way to dropping my wife off at work one morning I thought I was running out of fuel (had just done a 600+km round trip the day before on one tank), I put my jerry can in, no change, limped it home about 2km. After setting up the shed I got her started, drove her in and found this after tearing down the front end. Glad the EJ22E non interference, any more of a change in timing and it would’ve been a different story with any other EJ... Cheers Bennie
  13. My experience too: But that was caused by this and another 3000km: Cheers Bennie
  14. That’s not a drift. That’s a loss of control for reasons we can’t see off camera. They’re bloody lucky they didn’t hit the car with the camera or the wall. I wonder what was the real cause of their stack - high speed traffic weaving gone wrong? Cheers Bennie
  15. That is definitely a dowel pin from the engine/gearbox. You can easily tap that back in where it should be - if it's not the result of being pushed out to make way for another dowel pin from an engine swap. Any play in the rack can make some noise and give you the feeling of knock through the steering wheel. Clear up that slack and you might find your issue is sorted. Cheers Bennie
  16. Anything good to report? Pics were awesome, “report” was a bit “meh, it goes” Cheers Bennie
  17. @GeneralDisorder what’s the life “expectancy” of the plastic can gear? Mate they interchangeable with the older metal units? I only ask as I have a spare one I could use on my sister’s Gen3 that I’m about to do the HGs on. Cheers Bennie
  18. The VIN is used to identify the correct parts for your vehicle. It’s an awesome system to use! You can use it to look up part numbers etc from online sites too Cheers Bennie
  19. You need to ask for a pcv valve for a 2011 Subaru Forester! If the parts interpreter can’t work it out then they shouldn’t be in that job!! Don’t forget to say hello and the usual polite mannerisms etc Cheers Bennie
  20. New member chasing some numbers on their post count?? I too thought the same about the age of the thread. It’s a shame to OP never reported back as to what the issue was. Cheers Bennie
  21. The EJ makes these things wicked rides! Mine can be daily’d If I want it to be. And I have no issues jumping in it for off-roading or a full day of driving, eg batting out 800km isn’t though about from a reliability point of view, I just know it can do it and it’s got some power for taking off at the lights and for passing when needed - yet if driven nicely I can still pull in under 10L/100km Cheers Bennie
  22. Series 1 or series 2? This matters as the bonnet design was different between the two series - series 1 had the bonnet drop down a little over the grille, series two had a clean line right across the front of the bonnet. Hence both series grilles are different to each other. Got a pic of the front of the cut it came from? Cheers Bennie
  23. Bumper will be too wide and not look “nice”. Cheers Bennie
  24. That can also be wheel bearings - one side of the car becomes loaded with the vehicle’s weight, noise increases. It’ll also be speed related noise. I’ve never heard of spider gears making noise, even in corners. They’d have to be very well abused to make noise when cornering. Cheers Bennie
