125
Brat LHD to RHD conversion?
el_freddo replied to Ritchie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the update Ritchie! Glad it all went well! My brumby is currently dash-less and is RHD so I could’ve got the required pics for you. But I’m a little late to the party for that! Cheers Bennie -
Get on it Jono! Now is the time to be collecting bits for the Gen1 Liberty in my opinion. They’re still available in the yards, can be had for cheap on gumtree too atm. But like the L series, this is the death-nell for these vehicles being common and real easy to get parts for! I ran the engine today to show my dad. It’s sat for a week - and started no worries AND without any lifter tick. I’m pretty happy with it. The oil is milky so there’s a head gasket to be sorted but I was going to do that as a matter of preventative maintenance anyway. It didn’t take a lot of water, the sort of amount you’d expect for a cooling system that’s just been filled and run for the first time. Cheers Bennie
- 17 replies
- 1
Brat jump seats for sale
el_freddo replied to old sub freak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey Tod, are you willing to post international? I know a guy that’s after a set, somewhere in Europe. Cheers Bennie -
Ruby Scoo - the whole story! Loads of pics! Australian L series build
el_freddo replied to el_freddo's topic in Members Rides
Lastest video of a bit of fun out bush earlier this year: Need more trips! Cheers Bennie -
Title of the thread updated to reflect this. Cheers Bennie
- 17 replies
Cool video @Numbchux - how'd you get it to embed like that? Cheers Bennie
- 17 replies
The difference is mainly in wiring and compression ratio. You’ll find this EJ22 is a lower compression ratio than that of your ‘96 unit. So you might expect a small drop in performance. If you snap cam belt with this EJ22 it’s happy days for the valves - this engine is the last non interference engine that Subaru produced. Cheers Bennie
You won’t get that off without machining. Block deck needs to be cleaned so there’s no old head gasket material left. I use a flat blade to do this. Once you’ve done the blade work and are satisfied that you’ve got all the gasket off, I then wipe down with a white spirit like metho. Then assemble. Cheers Bennie
"Bugger!" At least there was a positive in it! Upgrades are always good! Cheers Bennie
For all of those out there contemplating an EJ conversion, this is one of the reasons why buying a donor vehicle can be easier - especially for the first timer. But with that said, this is how I've gone about it twice now - building a conversion from parts of several cars - why? Mainly because I've been given parts from some good mates which only require me to get the main bits like the engine and some supporting pieces that are needed for all conversions. Space constraints of renting can be prohibitive to having a donor vehicle on the property too. So this is how I "bench" test my engine and cutdown loom (plus it's good fun). Loom was cut down last week and the test done this weekend gone. Everything wiring wise checks out. Engine wise I have a code 35 (purge control solenoid valve) and no knocking on start up Now it'll get some preventative maintenance such as head gaskets while it remains out of the vehicle. https://youtu.be/vBXrmIzWiZY I reckon @sparkyboy will wet his pants at this and I kind of hope a few more of you will too (and be inspired to do your own conversions!). I've since fitted a radiator and run it for a longer period of time. I'm hoping to do this again later in the week, not that I have to, but I would like to see the light for the fan trigger to come on... This will end up in my Brumby once both engine and vehicle are ready. Cheers Bennie
- 17 replies
- 1
What I don’t understand about this issue (the 2009 one) is that the fans were NOT running and a new coolant temp sensor “fixed” it. If there’s an issue with the coolant temp sensor, or the circuit, the ECU runs the fans full time and the check engine light will illuminate. @1997reduxe - the best way to see the coolant temp sensor is from behind the intake manifold on the RHS of the engine. Cheers Bennie
Subaru GL-10 Classic Car Licensing
el_freddo replied to Nowah9's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I should add this is for the state of Victoria. Other states differ. I believe ours used to be very strict - to/from mechanics or club events. It was very difficult to take a Sunday drive for yourself from what I understand. But that’s all changed now and for the better. Over here in all states our plates don’t change. We used to have windscreen stickers but now we just pay our rego and it’s done. Police can check rego on their systems now rather than relying on the sticker - but it’s easy to miss your rego payment. Club rego is good because regular use rego is over $700 per vehicle annually. Club rego I think is about $70 a year! But your vehicle has to be a minimum of 25 years old. Dad argues with me all the time that my subi’s aren’t a true classic... Anyway, I can’t wait to get my subi on club rego. My other ones need to be engineered to transfer to club rego. Cheers Bennie -
Over here we have to be a member of an approved car club, and keep a log book of days driven. You can get a 45 or 90 day registration. After 90 days you can’t drive the vehicle any more. And if you crash without the log book filled in for that day your vehicle is effectively not registered - and thus, you’re not covered by the compulsory road authority insurance. I’m hoping to get my first car registered on these club plates later this year. Just need some shed time! Cheers Bennie -
Good effort Nico! Will all the glass be removed before the respray? And any spray work happening under the vehicle? Mid love to do the same to my L series but time, money and space are at a premium these days ;( Keep up the good work! Cheers Bennie
Cabin fan turned on? If not then try that. Otherwise it could be a wiring issue behind the dashboard or an issue with the relays (RHS strut tower). Or as Naru2 said - not gassed enough. Cheers Bennie
Careful what you wish for-89 gl 3 door
el_freddo replied to sparkyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No, definitely without AC. @carfreak85 - The turbo one won’t fit as that is based on the EA82 setup. The EA81 doesn’t have the ability to bolt anything to the water pump pulley. I’m starting to think this fan was an Australian only thing - but I find that hard to believe. ^ This is what I’m talking about. Mover here, if you’ve got AC fitted this fan is removed for a second electric fan that’s run by the AC wiring loom. Here’s a pic of the stock electric fan with the AC (top unit): If you can’t find a mechanical fan, I’d be using all of that available space for a larger thermo fan or two smaller units. I’ve got 2x 12 inch on my L series from memory - these cool the EJ just fine, so cooling the little EA81 would be a breeze. Cheers Bennie -
Clutch/flywheel/forks - all interchangeable. I’ve got an EJ22 (4 bolt) bolted to an SG (8 bolt) cased L series dual range AWD locking centre diff gearbox with a Gen1 flywheel, pressure plate and cable clutch fork - in an L series Gearboxes, externally, the phase two boxes all look the same, but internally they have different gear ratios, diff ratio and speed sensor drive gear. Same goes for the phase1 gearboxes but externally they’re different to the phase two box. Internals are not interchangeable due to a change in the reverse gear setup/size. If a legacy box was put into the forester and the rear diff wasn’t swapped to the matching diff ratio you could have other issues with the gearbox. Keep us posted Cheers Bennie
