el_freddo
    128
  1. Yes. That’ll work. The trick is not to crack the windscreen upon removal. And you’ll need that glue stuff you apply to the windscreen and put a current over the wires to heat it up. I’ve always had a pro fit my L series windscreens. Cheers Bennie
  2. Surely someone has a spare 13 inch steel rim to throw your way! Peugeot rims also fit (the 4x140 PCD). Just make sure you have the imperial rim size. If you get the metric rims you’ll be up for big dollars for a tyre that’ll fit - if you can find one! Cheers Bennie
  3. What sort of wear were you getting? I’ve had two rear tyres chew out the inside edge. That was partly due to worn bushes. I’ve since replaced them and need to have this setting adjusted properly. Cheers Bennie
  4. I need to do this too but have put it off due to the hassle of this job... Cheers Bennie
  5. No mechanical clutch fan - just a direct drive. It requires a different alternator bracket with it and this doesn’t work with AC. Cheers Bennie
  6. Maybe not, but can easily be retro fitted: You might remember those pics Jono - from Sunnie the Brumby’s build. Still going strong! And the gauges are “modular” - they can be removed. Only issue then is how the wiring behind the cluster’s “motherboard” lines up. So you have a total of five gauges and not six as shown above? And I wonder what sort of switch is used to determine how much boost that loose gauge displays, it’d have to be some sort of adjustable resistance type like the oil pressure gauge setup... I think the one Jono talks about is just a switch for a light. Cheers Bennie
  7. Hmmm... I want that turbo gauge! What are the other gauges on the other side of the dash? Our Aussie units have volts, temp, fuel level and oil pressure. And of course tacho and speedo in the middle part. Cheers Bennie
  8. Got oil on the brakes? It could be a good idea to hit them with some brake cleaner - but make sure it’s specifically for brake cleaning. You don’t want any residual left after you’ve done the work. Otherwise you’ve got some old rubber hoses that need replacing. These are most likely expanding. A visual inspection of all rubber hoses while someone holds their foot on the brake pedal will reveal the offending line(s). It could be all of them too. I’d replace them as a matter of preventative maintenance with a quality part. Cheers Bennie
  9. One of those relays behind the strut tower is probably the AC compressor clutch power relay. On the older models (BRAT/Brumby) if you’ve got the headlights on it will cut the second relay to save power - and is possibly designed to suspect that it’s cooler during the time of day when lights are needed. Not always the case in Oz! Cheers Bennie
  10. Some recent shots of Redback, new boots and some 14 inch scorpion rims (the originals) And after some rain, looking roughly east over the centre of Bendigo: looking roughly North: I added some square IPF driving lights. One spot, one flood. Awesome lights and suits the front of the brumby well! I’ve got a set of Integra DA9 front seats fitted. Very comfy! I’ll have to get a pic of this at some point to share. They look right at home in the brumby! A few things will be happening to ol’ Redback over the next month or two. I’ll have to remember to update this thread more often! I’ve also got a detonation issue I’m battling with. It’s got the factory spec carb on it, that’s not going in the bin, so no need to suggest a Weber... I need to test the compression as this could be a major issue causing the detonation - this happens: - under light load at proper running temp at highway speeds (then under load like a decent hill) - under load when the engine is headed towards the thermo cut in temp and you’re pulling away at the lights from a stand still. Frustrating! EJ conversion with AWD box is in the wings at some point! Cheers Bennie
  11. Welcome to the forum! Why did you replace the radiator? If you’ve been for a drive at highway speeds this will sufficiently bleed the cooing system if you’ve got enough coolant in the system already. When you top up the radiator, run the engine up to temp with the cap off, then watch for bubbles in the radiator. If these show up there’s a high possibility that you’ve got a blown head gasket. Cheers Bennie
  12. My call is the early signs of a dead head gasket. If you got to them early enough you’ll not have warped heads - saves on having them skimmed. These engines are known for leaking oil through the bottom of the head gasket. Read up on the recommended replacement part number. I’ll be pulling my sister’s Gen3’s EJ251 for a head gasket replacement due to the oil leaks. Cam belt etc will be done as well. Get on it early, this way you can choose when to do the HGs, not be forced to deal with them at the most inconvenient time possible which is usually the case! Cheers Bennie
  13. @lmdew - thanks mate, that’s be awesome! @Mike104 - The EJ20 is the same as the one I’ve already got. I’m looking for details on EJ22t specific parts and know some sites that use the VIN to track down part numbers with exploded diagrams to boot. My AUDM RS equivalent of the SS is already on the site I use, but that engine doesn’t have the bits I want to look at. Cheers Bennie
  14. Get a CV band tool if you don’t already have one Cheers Bennie
  15. Easier than an EJ conversion but not as good. It shouldn’t be too hard. Someone who’s done it will chime in no worries. Cheers Bennie
  16. The wash and wipe without turning the wipers to the Lo position is standard Jono! I’ve not tried the ignition in the ACC position, but I’d say the wiper’s function when doing the same thing is wired up for ON ignition position only. Cheers Bennie
  17. I love that colour! Cheers Bennie
  18. Welcome to the forum 3crows. Sounds like you know your way around already. Got any pics of your subi(s)? Cheers Bennie
  19. Hey guys, I’m hoping someone might help me out. I’m requesting a Legacy SS VIN for the purpose of looking up parts. We didn’t get the SOHC EJ22 turbo in Australia, we got a DOHC EJ20, so parts or diagrams don’t suit what I’m looking for. If anyone can help me out that’d be awesome. Feel free to PM me. Regards Bennie
  20. That’s awesome news! Time to fit a taser into the seat for anyone not authorised to drive the vehicle. Or an air horn and strobe light for maximum sensory overload I’m really stoked for you getting your ride back! So, did you ditch the crack, smoke (dumb idea!) or sell it?? I vote ditched it. Cheers Bennie
  21. Welcome to the forum Mitchy! Post somempics of your subi’s when you get a chance. We all love pics around here Cheers Bennie
  22. Get into it before you seriously overheat the block. This reduces the hardness of the alloys used in the block, and thus, it’s not as good as it was in the past, even with a new HG. Cheers Bennie
  23. If it’s a dull clunking sound - and heard on “smooth” roads with tiny bumps or undulations in the road surface, it’ll be your struts that have worn. If it’s an easily audible clunking sound do as Lucky Texan said and re-check the work you’ve done. Cheers Bennie
  24. Nice wagon. Shame about that body damage. Seeing that must’ve been gut wrenching. I look forward to seeing the recovery of your damage. Cheers Bennie
