Everything posted by The FNG
Coolant worries
http://s748.photobucket.com/albums/xx125/nickmohrbacher/91%20Subaru/?action=view¤t=IMAG0485.jpg Maybe this pic can help. I did notice that when the engine was hot, it smelled like really hot or possibly burning coolant. Is it possible that the head gasket just has a very small leak and this is what is happening?
Oops! Wiring issue
yes, Cougar, they are in slots 2 and 6, but I am sorry, in real life they are black/white. Please just take my word for it, I am not color blind. As for AK_kev_007, I agree, I think they may do something similar to that.
Oops! Wiring issue
I edited the pictures to point out the wires. They are both definitely black/white with no other colors and are both the same gauge. I could always assume this means they are the same thing, but chances are they are not and therefore, could be incorrectly connected. 50/50 chance of getting it right the first time though.
Coolant worries
I have a 1991 loyale that I bought recently (5spd man, pb 4x4, 220k). I recently did the timing belt kit along with oil pump seals, camshaft seals, crankshaft seals, ac and ps belts, and water pump. Since I removed the radiator to do the belts, I had to fill it back up. I used the procedures that miles fox has on youtube. Generally speaking, everything seemed to be fine at first. I drive about 90 miles round trip in my soobie to work, the store, etc. It seems like I am loosing coolant every time I drive the car. The overflow tank is at the full mark and I burp the lines every time I fill the radiator. When I turn the car on at first, I usually hear some gurgling from the heater core (air in the system) if I don't fill it up. Sometimes the car acts like it is going to overheat, so if I turn the car off and let the temp gauge fall and start it back up, everything is fine. I don't see ant bubbles in my coolant and I can't really tell, but it doesn't seem like there is any oil in the coolant, it kinda smells a little funny in the overflow tank (maybe like gas, but like I said it is hard to tell, very faint). I definitely don't have any white exhaust, and there are no puddles under the car. I do have a little bit of milkshake under the oil cap, but when I change the oil, it looks completely normal. Other than that, I have been throwing an egr solenoid code and have a little bit of a rough idle at running temp (around 500 rpms). Oh, it seemed to have this issue when I bought it, but not as bad. I have no idea where to start, I just hope it's not HG's or worse. I heard it may be intake gasket, but my luck in life says otherwise...
Oops! Wiring issue
Hi, I decided to fix some wiring issues in my 91 loyale. Some of the wires on this connector http://s748.photobucket.com/albums/xx125/nickmohrbacher/91%20Subaru/?action=view¤t=IMAG0480.jpg were messed up, so I went to the junk yard and clipped a new one. I made sure that the new one had all the right wires on it and everything, but what I didn't notice was that there are 2 wires that are colored the same until I cut the one off of my car. I don't know if you can tell, but there are 2 black/white wires on this connecter. I was hoping someone could help me identify what they were and where they go to. The connector is located behind the fuse box on the driver's side. The wire that was goobered up was the large green/yellow one. Anyway, I made a best guess as to which wires went where and the car runs, but now the CE light just blinks non-stop and the ECU gives a 5 light flash (Vehicle ID?). It seems to run fine, so I don't plan on changing anything unless I find out I'm tricking the computer or something. http://s748.photobucket.com/albums/xx125/nickmohrbacher/91%20Subaru/?action=view¤t=IMAG0481.jpg
MAF Questions
First of all, I've really learned a lot for everyone on this forum and really appreciate all the help you all have given me. Thanks for putting up with the endless array of newbie questions, which can get quite frustrating. So, I am having some hesitation issues with the 91 loyale that I bought a couple months back. I want to try to clean the MAF and have used the search button to find that it can be cleaned with MAF cleaner from the auto store. This is great! The only problem is that I can't find a picture of what and where it is. So, I took a picture of what I thought it was and it is in the link below. Could you help me out here? http://s748.photobucket.com/albums/xx125/nickmohrbacher/91%20Subaru/?action=view¤t=IMAG0478-1.jpg
Trouble code troubleshooting
I think I may have found the issue. My "header" studs are actually stripped all the way around. Somehow they are still jammed in there and holding the exhaust in place, but not tight making an insane exhaust leak and an incredible ruckus. So, once I fix that, I will see if my EGR code is still there.
Howdy, I just finished doing my t-belt kit install including new seals on main shaft, camshafts and oil pump, new water pump, and oil change. I got rid of a few trouble codes by doing that, but now, I have two new ones! I have a 1992 Loyale SPFI btw. So, I read the codes as 12 and 34. I looked them up and found that the codes are starter switch constantly on or off and EGR solenoid constantly on or off. So, are these a big deal? Any help or quick solutions would be awesome! thanks.
Timing belt, what else?
ya, it cam in a kit from rockauto.com, a great site for parts. I bought the Dayco kit. It was $100 plus $12 for shipping, so it was a good deal. check the site though, best prices for quality parts, not the crap ITM stuff from ebay for $65. As far as your belt, I have heard the edge of the gear for the oil pump can cause belts to break, bad tensioners (spinning like a skateboard wheel), or maybe to were too loose or tensioners weren't tight enough.
http://s748.photobucket.com/albums/xx125/nickmohrbacher/91%20Subaru/?action=view¤t=IMAG0467.jpg This is what caused my belt to break. The idler pulley bearing blew up. No Bueno:mad:. But it was definitely time to replace tensioners, shaft seals, o-rings, water pump, oil pump seals, etc. so, I guess it was imminent that something would happen. 230k and some original seals still.
Gonna get this done tomorrow: camshaft seals, crankshaft seal, idler pulley, timing belts, timing belt tensioners, v-belts, water pump, oil pump seals, remove/reinstall/flush radiator, change oil and filter, air filter. Estimated time: 4hrs, Reality: 6-8 hrs. haha, first time always takes longer, plus I have to clean everything. Thanks for the awesome videos Miles. I seriously would have been very lost without them.
I'm not sure I understand you. My dash is analog. The thing I took a picture of I thought was an oil pressure sensor. It has no wire attached to it. The picture looks like there is, but that is just the wire for the electric fan. So I want to know how I am able to read oil pressure if I am not sending a signal through a wire.
So I will be getting my new timing belt kit and camshaft seals tomorrow, already have the new water pump and gasket, oil pump seals, and oil filter:banana: So my question is now, what is the part in this picture? http://s748.photobucket.com/albums/xx125/nickmohrbacher/91%20Subaru/?action=view¤t=IMAG0461.jpg#!oZZ2QQcurrentZZhttp%3A%2F%2Fs748.photobucket.com%2Falbums%2Fxx125%2Fnickmohrbacher%2F91%2520Subaru%2F%3Faction%3Dview%26current%3DIMAG0462.jpg I think it is an oil pressure sensor, but I don't know if it is. I tried to look at this part at a junk yard, but all 4 cars were missing it. As you can see, there is no wire attached to the little copper tab. Is there supposed to be one? If so, exactly where is it supposed to be/ where does it go?
Ya, nevermind. I went to rockauto and bought the dayco kit for $100 bucks. I don't even want to take a chance. If I'm going to do this, I may as well do it right. Although Dayco may not be as high a quality as gates, I think it is still good stuff. I think I will keep a set of gates belts on hand for backup though. I think the extra $40 is well worth making it home every night so i dont have to listen to the wife's bs about my pos car.
Have you ever had experience with an ITM kit or any of their parts? Since I bought the kit, I've been hearing horror stories of their belts breaking after only 300 miles or so. I am wondering if I could just use the main parts and get some better belts.
Here is the kit I got on ebay. It comes with 1 crank seal and 1 cam seal. By the sounds of it, I need to order some more seals. I would need 2 cam seals and orings and 1 crank seal, right? do I need an oring for the crank? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400176384460&viewitem=&sspagename=ADME%3AL%3AOU%3AUS%3A1123
Ok, so I have the timing belt kit, oil pump kit, water pump, water pump gasket, and new oil filter. I think that should do it. And I assume there are procedures for component replacement and timing on the site.
So my timing belt broke the other day while I was driving leaving me stranded (with a pissed off wife-says I never shoulda bought that piece of S***). Anyway, I haven't torn it apart yet, but I have a timing belt kit on its way. The kit includes left and right side belts, two tensioners, idler pulley, and I think two cam shaft seals (not sure). I was looking at some other threads and saw that replacing the oil pump gaskets and seals as well as the water pump seal were recommended while doing timing belts. Now, I have no idea why my belt broke, but I have heard of cam shaft seizure and oil pump seizure that could cause this. I will not have the luxury of pulling the motor and hope to not pull the radiator. Are there any other things I should look at doing while changing the timing belts, etc? Also, If my oil pump is seized, can I rebuild it or do I need a new one? How does replacing the seals make a difference in its operation? If the cams are seized, where do I go from there?
Help with new stereo install
ya, I wasn't sure about that one. It comes in green on the stock harness, and was never really referenced. I just blew my timing belt (hopefully that is the only issue) so this project will be on hold for a week, but thanks for the inpput.
broke the timing belt, parked her on the side of the road, waited a day, then loaded her on the car hauler and brought her home:(
so how would I work out a common ground system? I guess I am confused a little. I attached the Sony wiring diagram. Do I wire it like that, with the ground attached to the car body? or do I give each speaker its own ground? Sorry, it is just a little confusing to me.
Thanks, and the fuse is not blown. It was, but I changed it. So, should I just use the stock harness for the power supply and wire the speakers directly to the head unit harness? I will try switching the red and yellow wires tomorrow. Also, what about the other plugs/connectors on the harness? are these just left out?
I decided to pull the crappy non-working aftermarket stereo out of my 91 loyale and install a sony xplode cd player. I pulled the old stereo out and saw a terrible mess of wires where only about half were connected, so I went to a junk yard and picked up a stock Subaru stereo harness. I also got the metra harness that fits 90-94 loyales. So I connected the stereo harness to the metra harness and then plugged the metra harness into the stock subaru harness, and nothing happened. So, my question is can someone help me? I have attached 2 pictures. One is of the sony to metra harness and the other is of the subaru harness. The subaru harness has 3 connectors and the metra came with 2. I have no idea what to do with any of these connectors except the big one. Please help! I did also read this http://www.ultimatesubaru.org/forum/showthread.php?t=50840 but it doesn't seem like it tells me everything I need to know.
More battery issues
My bad...my baja lights were on, but the covers were on too, so I couldn't see them:banghead:
Lovin my soobie...
I wish I felt the same way right now....
