There was some squeaking when turning to the extreme. Especially first starting out. Someone else found no prob. These guys found no prob....put in a synthetic lifetime ps fluid. Still have the prob.
Look closely. I know nothing about cars. Looks liks an air intake. That "pipe" goes to the air filter in the back. There is a little tub on the left middle...which it is now not connected to...my guess is that "hose/pipe" is supposed to be connected. Don't understand the function.
About 3 weeks ago had an O2 sensor replaced on the passenger side (think they called it something else)...had the oil changed and they replaced my ps fluid. Since then I have had a buzzing/rattle on the passenger side. Have not been able to get back to the shop to check it out. Today i saw something that look suspicious....first pic is to give you the area...left side as you are looking at the engine.
Now closer....can you see the part that is separated?
That eventually goes to the air filter. Did the mechanic break this? I assume this is supposed to function as 1 piece.
What is this?
