I would agree that the oil pump, oil gasket, and cam seals all need to be replaced soon. Do you think that I need to repace lifters as well as the pressure relief springs in the cam spray bar banjo fittings even if the tick is only an issue after sitting for prolonged periods of time?
I understand that a repair in a bottle is not a solution for the long run, but I was curious if the thining of the oil in conjunction with a weak oil pump could have possibly resuled in "better" performance from a old pump.
My train of thought is: If the tick was gone when I thinned out the oil with the Seafoam, and there is no tick when the oil has warmed and has become less viscous, then I should try to using a oil with a lower initial (cold) viscosity.
Any thoughts?
