General chaos
About General chaos
- Birthday 03/01/1963
Location
Missouri
Vehicles
I Love My Subaru
General chaos's Achievements
USMB is life! (4/11)
0
one thing i just thought of. alot of building contractor just take the lumber prices and double it . and keep the rest for labor. maybe i should do that. i saw a timing belt kit minus the water pump for 169.00 on ebay free ship. it doesnt take very long to do the pump and all of that to my 2.2 so a 2.5 couldnt take very much longer. and i pulled the radiator the first time. all the other times i had the fan out of the way instead. but the radiator being out would be easier to drain the coolant. for the pump.
this bull happened to me too. i had everything lined up and everything but i had no spark. it turned out my wiring under the dash had become loose and wasnt getting a good connection. i could see up in there very well. so ai got mad and grabbed the harness and started shaking it back and forth and the connection came back together. and i got spark back. mine was on a 93 legacy. the power for spark came from the alt to the fuse then on to the main power for the ignitier. it hasnt failed since i shook it.
that sounds like a housing change to me. i think i have to decide if i just want this transmission now. the fluid looked ok. but smelled of clutches. i have been looking at the wiring plugs o fboth cars. they both seem to have the same number of wires going into the plug from the main harness. so maybe its ok and they just used different colored wires from 93 to a 95. 150.00 and its local. but i have to pull it out in this heat in a field.
wait i was coutin the letters wrong. the first letter a is correct. but the second letter is a A which doesnt corespond with the year 1995. my transmission is a 2 in that position but the car is a 93. so i have a 91 transmission in a 93. but both transmissions are multi plate transmissions. now i have to findout about the wiring and the year code of that right hand drive transmission.
all your searches. end up with that link to the parts diagrams. i am not intersted in that. i am interested to see if this right hand drive awd 95 trans will fit in my left hand drive awd 93. both legacys. i looked at the plugs they are both square. i didnt trace any wires on either car to see if i needed to do any rigging. which i would not be able to do anyway. because i dont know what rigging would need to be done. the decode pages i have seen dont match up with what i am seeing and knowing about the car this is in. the first A in that code about says 2wd. http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/engine_&_trans_decode.jpg wrong. this is defently a awd. it has a rear edn under it. with axles. but that is not what worries me. i am worried about the wiring. i found apdf file. but the code wasnt in that pdf i found either.
