About Whitehog
- Birthday 05/28/1977
Location
Tucson
Vehicles
79 wagon
Whitehog's Achievements
Member (2/11)
0
Self help advice. The motor is bleeding.
Whitehog replied to Whitehog's topic in Historic Subaru Forum: 50's thru 70's
Anyone know torque specs for an EA71 oil pump? -
Custom Shifter Boots - Have extra
Whitehog replied to danrenfroe2016's topic in Historic Subaru Forum: 50's thru 70's
Used to be able to buy rubber insert flooring for a lot of vehicles, you might find some that would fit close from small pick ups. I had a friend with an s10 with rubber lined floors. -
Take out your seats, trim, and console and put bed liner on it. Its pretty easy to apply,and not to expensive, its not gonna come off though. I hear it cuts noise a bit. Gotta lay it on thick. not sure about heat resistance. -
Sounds good. So, check by phone? ha ha, send me a message or let me know how to buy for the manual, never done this bit,or much else on a computer before the USMB. Do many Gen 1 owners find much from vendors or wheel and deal on the historic page? I am seriously hard up for a drivers door window regulator, the metal stripped away on the back of the gear. -
gasket kit will be here along with a '70 to '79 haynes book this week. Gonna go at it Satuday. Any non basic tools I might need? -
That's what i thought, at 94 bucks after shipping. Trying to keep this thing runnin till next year when it will become a project instead of a driver. Where is the best place to find a chiltons book? Even if i screw it up i'm only out gasket cost. I'm millatent about doing what i can, and determand to learn, in spite of my lack of drunkin spelling capabillities. I LOVE WEEKENDS! Don't worry, most of the secondary fundage is devoted to the Groundhog. -
Quality is a good point. I had it looked at when i got tires, at least 3 leaks, its pretty messy. If the average gasket is 20 bucks, it's not much more to get a whole kit. I think valve covers are ok but wanna get compression check/valve adjustment sometime soon as it seems to have a lack of power,(aside from its obvious small engine). -
I'll see if i can order or find a chiltons right off. gonna order gasket kit tomorrow. -
I have a few leaks(oil pan,oil filter unit thing, maybe main) Debating on trying changing them myself. I'm inclined enough, I've just never changed a gasket. Clean the metal, keep out the junk, obvious. RTV or not? Torque settings for Main and oil pan online? Possible valve adjust while i'm in it? I heard the pressure gauge is cheap and info seemed simple. I suppose EA71 specific info/advice would be the most helpful, and/or I need a little nudge to pick up a wrench.
My 79 Groundhog 4wd. Just tested the 4wd on some rocky hills, sucker didn't slip once, on road shoes no less. Stock EA71, 150 or 250 thou, $1300 bones about three months ago.
I tried hitting the insert image button but i dont know what to do from the little http box. Gotta get on that roll call. hey just got the thumnail figured out!
Can brat lifts be used on gen. 1 wagons?
I'll probably try to pop an old one off and compare when i purchace. it'll be within a few weeks so i'll post up as soon as i know. By the by, is my 79 wagon a gl or what? Title says g4d but that isnt on any model choices for parts lists.
Need new shocks for gen. 1 wagon
Thanks , gotta do some diggin and fittin, ill post results. -
Good lookin out, sounds like one of the tougher parts to find. Wondering if some new similar shocks could be rigged in with some part sharing? Gotta be somethin to put in it.
