Prwa101 last won the day on May 8 2014
Prwa101 had the most liked content!
About Prwa101
- Birthday 04/21/1992
Contact Methods
Website URL
https://m.facebook.com/adnfab
Gender
Male
Location
Sandy, OR
Interests
SUBARU's Cars and Truck 4X4ing, my Women
Occupation
Student at PSU
Ezboard Name
Ej22 Harness Junki
Biography
Owner of Anderson Design & Fabrication
Vehicles
88 Gl,69chev, 00 forester
Recent Profile Visitors
Prwa101's Achievements
Certified Subaru Nut (8/11)
94
Prwa101 replied to pontoontodd's topic in Off Road
Glad to still see this build is still alive! Much inspiration to be had here! -
I think there pretty much the same just different gear ratios much higher than the older one
The difference there is the newer R160 and the older R160. Newer being the weird tribecas and ascents. Older being everything else. The vLSD housing didnt allow for enough room and has a different inner one spider dosnt come out like the others.
Spot on! ^ "Will this fit my Subaru?" As long as its not an STI lol R160 is in almost every Subaru out there
All you guys who have been around for a while have seen my old work on the R160 ratchet locker. Sadly never got any further on it due to funding and machine limitations. But! ADF and Torqmasters has teamed up to make this happen! 400$ a unit roughly should be completed and may/June! Big news for almost all Subarus out there as the R160 was used thought the years. If any one has any questions let me know!
That thing looks awesome man!!!! Glad it worked out for you! Patrick Anderson Design-fab
I make a product for this, 2.5" lower lift brackets. But if im under standing you right this has also been done before. http://www.newenglandsubarus.com/forums/showthread.php?t=6312&s=e6c2e2cb443e2768956c3738e9c7e9ab This is a 98 forester on king springs, 2.5" lower lift brackets and a 2" subframe spacer.
Try using a sledge hammer? I used a 8lb one last time. Another option is to take the hub off and press it out
Hit me up a message i build but i have a buddy that has one of my old ones for sale!
You'll prolly lose 2-3mpg with the larger tire becaus of the larger mass
But the way my lift is built I can run up to 30's ish depending on how much I wanna cut. I think the next tire I get will be a 225/75/16 copper STT Pro
I get from 17-21 depending on where I am an hoe I'm driving. I'm in 215/70/16's as the newer forester allow for a slightly larger tire.
Maybe a hair in the front on the mud flap. Buy easily trimmed. Most of the time it's only in full lock.
Haha max tire is 215/75/15's. i love my copper at/3's, general grabber at2 is a good tire. Heard some of the dump pro mt's are pretty good. If you go much larger you'll rub if the spring perch. The 75s are pretty close. 70's will fit like a glove.
