Prwa101
Everything posted by Prwa101
  1. Glad to still see this build is still alive! Much inspiration to be had here!
  2. I think there pretty much the same just different gear ratios much higher than the older one
  3. The difference there is the newer R160 and the older R160. Newer being the weird tribecas and ascents. Older being everything else. The vLSD housing didnt allow for enough room and has a different inner one spider dosnt come out like the others.
  4. Spot on! ^ "Will this fit my Subaru?" As long as its not an STI lol R160 is in almost every Subaru out there
  5. All you guys who have been around for a while have seen my old work on the R160 ratchet locker. Sadly never got any further on it due to funding and machine limitations. But! ADF and Torqmasters has teamed up to make this happen! 400$ a unit roughly should be completed and may/June! Big news for almost all Subarus out there as the R160 was used thought the years. If any one has any questions let me know!
  6. That thing looks awesome man!!!! Glad it worked out for you! Patrick Anderson Design-fab
  7. I make a product for this, 2.5" lower lift brackets. But if im under standing you right this has also been done before. http://www.newenglandsubarus.com/forums/showthread.php?t=6312&s=e6c2e2cb443e2768956c3738e9c7e9ab This is a 98 forester on king springs, 2.5" lower lift brackets and a 2" subframe spacer.
  8. Try using a sledge hammer? I used a 8lb one last time. Another option is to take the hub off and press it out
  9. Hit me up a message i build but i have a buddy that has one of my old ones for sale!
  10. ^^ thats me all right, all camber offset lift blocks so stock camber can be achived after install (as long as you mark your camber bolts) This is one of my 2" kits on an 03
  11. You'll prolly lose 2-3mpg with the larger tire becaus of the larger mass
  12. But the way my lift is built I can run up to 30's ish depending on how much I wanna cut. I think the next tire I get will be a 225/75/16 copper STT Pro
  13. I get from 17-21 depending on where I am an hoe I'm driving. I'm in 215/70/16's as the newer forester allow for a slightly larger tire.
  14. Maybe a hair in the front on the mud flap. Buy easily trimmed. Most of the time it's only in full lock.
  15. Haha max tire is 215/75/15's. i love my copper at/3's, general grabber at2 is a good tire. Heard some of the dump pro mt's are pretty good. If you go much larger you'll rub if the spring perch. The 75s are pretty close. 70's will fit like a glove.
  16. I get mine on amazon! Free shipping always wins out.
  17. Camber offsets are build in, ive had sevral people go in for an alighnment and not even need one. lol. Stock struts are fine but if there wore at all, i would recomend replacing them with KYB GR2's. I personly dont like king spings, they limit travle and are very stif for offroad... seen may cases when theyve causes broken struts and top hats. hahahahah!! The title is killing me.
  18. Look for rust, prolly the biggest concern when lifting. If the main body mounting points are shot the left blocks won't be sturdy and down the trail could cause issues. Check out my Facebook page, I got some good shots of lifted GL's and Loyales. Facebook.com/adnfab
  19. Sweet! Looking forward to talking to all the people I've met on the board over the many of years!!
  20. here's a good video on how to drill the hubs. Now to drill the rims, punch 2 studs out of a hub and bolt it up to the 6 lug wheel and punch the centers through the hub onto the rim. Then drill the 2 holes in the rim. For those 2 hold its best to flip your nut over because more of the steel wheels have a slight ( to them. It help the nut sit better flush with the rim.
