Everything posted by Prwa101
There just about the same cost, Subtle wants 399 for ironman springs and Primitive wants 439 shipped for king springs. I run king springs on my forester and i love them!
Scored a lift kit the other day...
Prwa101 replied to d8usti5n's topic in Historic Subaru Forum: 50's thru 70's
Absolutely! Will do! -
Its to bad your so far up there or id say bring it to me and id build you a custom lift for it.. Im working on getting one from a freind so i can build them for people like your self.. Hope you didnt pay much for the kit... http://www.ultimatesubaru.org/forum/topic/148582-anderson-design-fabrication/ Patrick -
Hate it kill your dream... But that's a ea81 lift kit not a ea71... First gen brats are build different and require more spisific blocks.. SJR hasn't build a lift kit for one as far as I know. Thats a second gen brat lift kit for sure.. -
Hey Barty, you can email me here and we can figure something out for you! Prwa101@gmail.com i can ship to Ausi but it may be a little costly (ofcourse i havnt gotten a quote yet) and if you knew other people over there to make a larger order that would cut down on cost for shipment. PRWA
So my XT's grow! My wifes forester just got fitted for a custom UEL header, down pipe and midpipe, from infurno fabrication! Should be all done next week!! going to sound amazing! My FXT just got some 215/70/16 Discover cooper AT/3's. and soon to have a 2" lift from Anderson Design & Fabrication! shes going to be a monster!!
This is understandable, I updated my Specs on my first post. As far as photos of my welds the next set i made ill post pictures. The kits i already have made are painted so the next set i make ill be sure to post pictures for anyone who's wondering how good i weld, and get penetration to the max. But i can insure you that my kits are build for what ever you can throw at them. I weld my strut tops all the way around the tube, unlike others, (excepts around the bolt holes so you can install the nut better). As far as posting my PDF of my install, im working on my web site to have it on there for accsess. But for now i prefer to send them out with each kit along with the invoice. If you have anymore questions feel free to ask, Patrick
Hey Danny, it's the stander heights ones on there. You can contact them and get a propor quote though for the springs, just tell then your make and model. And they'll set you up. Patrick
Sent you my reply. I'll send it when I get home later.
King springs are stiffer and have a higher load cappasity than stock. You'd have to run them to know, you'd never go back though there's pretty amazing springs. Yes, if you do th 1.5" subframe drop you will need to extend your steering shaft. Or find a 90-94 legecey in a junk yard and grab one off of that. With all my kits send a PDF Of detailed instructions for installation which includes the subframe drop. Happy to answer any more questions! King springs are here, http://www.get-primitive.com/ Patrick
Thats my goal! I personally wouldnt say its not necessary, as long as you dont mind changing axles frequently? haha. Jean the camo wagon on here blew both of his out the other day, blowing by a Prius doing 80 haha. he only has the 2" suspension lift. I could do that, 100$ shipped for the front blocks. But what rear suspension are you planning on running? If you running accord springs, you will lose uptravle in your rear because the shock is maxed out and wont compress as much. If you want to improve your ride quality, i would highly suggest getting a set of king springs for there car and installing a full 2" lift. The photo of the white wagon on here has the same build and can go places where lifted rigs cant get. On top of king springs being amazing! The front will only be 1/2" off stock axle geometry with the full drop. The rear axles only travel in the Y direction (up and down), the front travel in both X and Y (up down, left right.) The front axles take a lot more stress because there under more loads and stress causing them to go out more frequently. As far as the rear 2" dosnt affect them at all, ive seen people run 4" and only time they had any problems was only under full exstention and pulled the CV out of its cups. and the other time i saw one break he was bulling a fordranger out of a hole going full bore on a 3" in the rear, and broke the main shaft in half. No problem at all! Its my pleasure! Patrick
2 inch lift & 6 lug swap
Prwa101 replied to dannycisneros's topic in Old Gen.: 80's GL/DL/XT/Loyales...
^ I told you early legecey steering would work haha. Patrick -
Depending on which rear top hat you have I may have a 1" spacer that'd work for you. Prwa
NOW OFFERING EA-EJ ADAPTER PLATES!!
Thank you Numbchux. This is not smart. It'll be cheaper in the long run to buy a aluminum adapter plate. But if you serious about this plastic, I will gladly give you my PVC printed adapter plate, I made a while back. Just need to glue each piece together. Lol. Make sure you take a lot of photos after words, I would love to see the after math!
How Does Subaru 4X4 Work?
Prwa101 replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Theres a third option for thous who are willing to wait. This locker will replace your existing spider gears in your R160 differential. Lets hope i get one in application sooner than later... :D :D :D :D :D :D My pride and joy haha only about 200 hours of designing. and this is a working model -
Absolutely, I would like to hear them! Always open to new ideas. If your in Oregon city that's pretty close, you should pm me and get your contacts. Patrick
It's not worth the swap. Easy and more productive to swap a ej22. The ea82t heads tend to crack and are becoming harder to find. And if you want boost find a ej22t that'd be fun! Prwa
I can get the aluminum EA/EJ addapter plates for 100$ untapped. Pm me. It's worth your time to just buy one. Plastic isn't hard enough and won't last long enough with the heat I would say. Prwa
I've got kits ready to mail out!! AND!! Waiting for interest for 2" lifts for the EJ serious! Take me about a week to have them cut out! Let me know if there interest! Patrick
mechanic in Vancouver/portland
Prwa101 replied to yiannib's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Superior Soobie and import in Milwaukie Or -
1988 subaru turbo GL, EJ22 and 4" lift, plus 6lug swap build!
Prwa101 replied to Prwa101's topic in Subaru Retrofitting
Yeah I found that out after reading up on it. One reason why I just put another ea dual range back in. This one has 180k but was owned by an older guy so she should hold up for much longer. Actually your build a while back is what I read, along with others though. Sad that didn't work for long. I'm tempted to build what Pooparoo has in his brat. That would be a beast! Need to get my lathe so I can mod and build an unstoppable ej/ea tranny lots of time and work but would be worth it in the long run. Haha. Prwa -
dropping the drop tranny agin.... Just me and my trusty box! New one goes in tomarrow!! my new 3ton jack will help a lot this time haha! -
Jean from Tacoma just got his 2" lift kit on! Thanks for the pictures Jean!
