Jessekrs123
Jessekrs123 last won the day on July 9 2024
Jessekrs123 had the most liked content!
About Jessekrs123
- Birthday 08/21/1992
Location
Oakville
Occupation
Student/Assistant Dairy Manager
Vehicles
I Love My Subaru
Jessekrs123's Achievements
Advanced Member (3/11)
3
Hey guys, Got this all figured out- all good info above. I ended up going with a Ø3" 1/8" thick Viton disc that I was able to get from McMaster: Gasket Material Disc, Chemical-Resistant Viton® Fluoroelastomer, 3" Diameter, 1/8" Thick | McMaster-Carr Matched up pretty well with the diameter and thickness of the old gasket, and you don't have to try to cut a perfect circle out of a sheet with an exacto. (wow I remembered how to use photobucket- blast from the past in some super old albums) I used an exacto and some hollow punches to recreate the hole pattern and the center opening for the fuel send unit (far from perfect) Cleaned up the fuel sending unit flange the best I could Aaaaannnddd... was still leaking. So, I noticed that the little G10 (maybe?) board where the leads are soldered in was rusted good all around, and probably the original source of the leak. Take the sending unit in and out a few times, agitate it, flake off what little rust is holding it all together and more leaking. So, I took some Tank Weld and filled around the outer perimeter of the board Been running it like this for a couple months now with no signs of leaks. I can fill the tank all the way up and accurately track fuel mileage now (~ 26 mpg highway with the 3AT, 65 mph ~ 3800 rpms - better mileage than my 94 GT wagon) Side note- replaced the rear fuel filter this morning (started getting some bucking going uphill- classic symptom of fuel filter clog) and found this Looks like sand. Was originally a Florida car. Been dailying it since Spring started.
Necro bump. Couldn't find any additional info on this. Long story short, recently acquired an 82 GL wagon, and this sending unit flange is leaking. Couldn't find part 7850 25000 or 25020 anywhere so I figured I'd have to make my own. What do you guys think, maybe get some NBR rubber sheet and cut it out ?
Jessekrs123's 1984 Subaru BRAT
Jessekrs123 replied to Jessekrs123's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Replaced the distributor today in a last ditch effort before ripping out the harness. Fired up like it had never stopped running. Had to sand down the shaft on the distributor before it would fit into the hole without trouble, but everything is all set now. I'll need that 4WD once it starts snowing. -
Hey guys, been a while since I've posted, just been driving her everyday. Recently did brake pads/shoes. Ran into a bit of a problem though. My ignition keeps cutting out randomly. I seem to have narrowed it down to there being something wrong with the signal going to the tach. When it loses ignition, the tach does not move. Check for spark and nothing. Usually the tach will bounce even a little bit while cranking. And I also sat there and watched the tach drop to nothing while the motor just died out. I don't know if this is significant or not but recently Fuse 13 the 15A fuse for the ignition coil has been blowing out I'm assuming because of my push button start I have wired to an ignition source. When this fuse blows, no dash lights or gauges work. Usually I just pop in a new fuse and I'm on my way. I've also noticed when I pull that fuse, the fuel pump clicks. Is this normal? My relays sound to be working fine when the ignition is turned to on. Checked my wiring diagrams and see that with the positive terminal on the coil is tied in with all the dash lights/tach and the negative terminal is tied in with the tach/fuel pump. Would my problem lie within the negative termianl/signal from the coil? Just picking my brain here, your help is greatly appreciated. -
Had some fun at work today with the BRAT. The trailer's battery died, so we tried jumping it but just a bunch of clicking. Oh well, that is what happens when you don't run the unit for 4 months and expect it to work perfectly... Jackasses... -
Got this thing running good again! Turned out either the fuel filter or the vapor separator was clogged, because I replaced both of those today and now it is running like new! Quick vid. -
Drained out the gas completely and put in fresh new gas. Still bucking. The disty I got is not the right one, the shaft is too thick, it won't fit in through the hole................. I'm thinking about removing the carb and cleaning it out and see what happens even though the thing is brand new. -
Thanks Todd, I already ordered the disty, all the parts on the motor were factory and getting old, just a safe measure to tune up and get some new ignition components while I'm at it. I'll drain out the gas once it gets warmer, sometime next week. -
Coil has been replaced with a new unit, still bucking... I have a new distributor on the way... Hopefully this will do it. -
Lol thanks for the tip moosens, but all that crap on the drivers side of the engine was deleted when I got rid of the EGR system. Yes, I need to get this thing running well soon and make my way out to a car show... -
I put seafoam and drygas through the tank today and still no change. I also pulled the vacuum advance going into the dizzy, and it ran the same, no better and no worse... -
New wires put on today. Pulled the plugs, everything checks out rather good and it is still bucking. It bucks really really bad when going up hill, fuel issue perhaps? Water in the fuel? Checked both fuel filters for any debris floating around and got nothing. -
Oil Pan Removal on Brat???
Jessekrs123 replied to Dinky26's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I got mine off and on no problem, but there are two bolts on each side (one circled in the above picture) that you have to approach at an angle. I'd use RTV or something to seal the new pan on, the factory cork gasket was hardly accurate and took a lot of fiddling to get it to fit right. -
Put on a new cap and rotor this evening. Still bucking... I have new plug wires on the way, I hope this will do the trick! -
Thanks twitch, I'll definitely be looking into welding up a new exhaust once the weather warms up. But right now I'm having some issues with the car. I've noticed sometimes it likes to buck quite violently in third gear at like half throttle, and sometimes at WOT. It will also buck violently when going up a long, somewhat steep hill. The Weber is new, distributor cap is new, and I have all new plugs and wires. All of the vacuum lines have been re-routed and plugged as well. I have tuned the Weber as per the directions it was sent with. Perhaps it is time for a new distributor? The only few things I can think of that would cause this issue would be a lack of air, fuel, or timing. It is definitely getting enough air, the fuel pump was replaced about 1,000 miles ago along with both filters. Distributor is probably still factory, and I'm pretty sure I routed the correct vacuum advance into the disty. I've read around that if you set the timing a little more aggressively for the Weber, there is a little gain. Let me know what you guys think, thanks in advanced.
