22
Everything posted by czny
Ea82 stock spring height.
czny replied to charles_thomas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
From bottom edge of top hat to bottom edge of strut spring perch is 7 inches on my 87 GL. These are Monroe 4WD EA82 struts. Springs are Moog and I don't recall the part number. Here's the list in pdf. moog-spring.pdf- 11 replies
- oem
- suspension
(and 2 more)
Tagged with:
1982 GLF Suspension Questions
czny replied to Evinrude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
https://www.ultimatesubaru.org/forum/topic/150805-ea82-front-struts-fit-ea81/ I have a L & R pair of good used KYB FWD ea82 struts complete with springs & mounts you can have for price of shipping. I cut the brake line tab to make removal easier - just bend it back. PM your address & I would prefer PayPal if you have an account. (Lower 48 US states only - in case someone here asks.) -
Yeah, higher the lumens the higher the price too. "Diamond plate" shop lights of advertised 10k lumen 4 footers: https://www.ruralking.com/4-led-shop-light-10-000l-chrome?utm_medium=email&utm_source=2018-10-07+Whats+Hot&utm_campaign=27100044&utm_contnet=27100044&_bta_tid=32259870115476410414092769077956769598026446718742119450761235058598424239696786977331067106111512431209 And advertised 4500 lumen 4 footers: https://www.ruralking.com/4-led-shop-light-4500-lumens?utm_medium=email&utm_source=2018-10-07+Whats+Hot&utm_campaign=27100023&utm_contnet=27100023&_bta_tid=00379131375476410414092769077956769598026446718742119450761235058598424239697096462340888451180237212265 I'm betting I'll still need drop lights for under carriage work with these aging eyes. Ha ha!
Some comparative figures for you https://greatercea.org/lightbulb-efficiency-comparison-chart/
It'll be a couple weeks before I can try them out. I'll try to get before & after pics - if I still remember to.
Needed some better lighting for my new garage. As it yet only has 4 overhead screw-in lamps, opted to upgrade to these: https://www.northerntool.com/shop/tools/product_200679033_200679033?cm_mmc=Housefile-_-RECEIVED-_-707-_-CONF
Brake master cylinder replacement
czny replied to Dee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Drum brakes should always be adjusted first before bleeding, as I surmise you just found out. Adjust & try again Dee. Tighten until they're locked up then back off until they drag lightly. By the time you get done here you'll qualify for your NIASE patch on your service jacket.... -
https://www.amazon.com/gp/product/B000MXW2EM/ref=od_aui_detailpages00?ie=UTF8&psc=1 While you may not be seeing air when you get back to each wheel, air could be rising up the bleeder hose & remain trapped in caliper/whl cyl on last up stroke of brake pedal. -
You did use a check valve type brake bleeder at the wheels, right? Try bleeding the MC this way then..with all MC lines tight but no too tight, crack one front line loose at the MC then allow it to gravity bleed until fluid is dripping. Then tighten that line. Go to one rear line, crack it loose at the MC & allow it to gravity bleed until it is dripping. Tighten all MC lines. Now go to each wheel in criss-cross pattern & bleed them. Do all your bleeding with the engine off - no booster so you can get a solid feeling pedal first. You must have a solid pedal with no vacuum boost first or its pointless. Other things to check: Pull down your lower kick panels & check out the clevis pin in brake pedal lever & the brake rod. Look for loose/worn parts. While you've got the dash panel down check out firewall to see if fluid had leaked down inside the cabin. -
1982 FSM SCAN (anyone need?)
czny replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Worked for me. Used the free download with sign in. No problem. Some pics of your left thumb too And thank you for doing this. -
Looks to be a common problem on those CRXs: https://www.ebay.com/itm/88-91-HONDA-CRX-Si-Driver-Left-Rear-Interior-Trim-Side-Panel-sms/132781334941?hash=item1eea62619d:g:pbIAAOSwDYBbnCcH $125! Ouch!
Might be able to reinforce the backside with some 1/4" or finer mesh screen then apply your bonding epoxy. Use some clips to hold everything in place then bond it. https://www.amazon.com/J-B-Weld-50139-Plastic-Adhesive/dp/B01IBOK7FE/ref=sr_1_3?ie=UTF8&qid=1538053852&sr=8-3&keywords=jb+weld+for+plastic
Not no, just undecided if........ How else are you gonna share this? Google drive? Dropbox? Etc? Dropbox free acct has a 2 GB limit. -
This term, CVT, had me scratching my head so I searched: Now that I've seen it I can't help but think of old machinery vari-speed drives married with silent chain instead of a wide rubber v-belt. Twisting & bending torque on that CVT belt must mean its a wear service item along with those pulleys. Vari-speed has been around for decades. How do I know of variable speed drives - production metal turning & milling machines. http://www.lovejoy-inc.com/products/variable-speed-drives.aspx You'd think they could've put that internal filter element in a more convenient spot........
Glad you could make it back. Take good care of your Mom. Mine was bedridden from 2004 to 2011 when she passed.
Good day & welcome to USMB. Another, err, 'heavyweight of horror' saying "good evening".
- 1 reply
- 1
Especially when old brake hoses skive layers internally leading to a bulge. Lose pedal firmness when this happens then later on they burst. Definitely helps speed things up with a pedal operator behind the wheel. Then can pump it up a few times, hold down pedal hard & blow last of air out at the bleeders. -
Method 2 for bleeding: Install the M/C & connect all lines tight, but not too tight. Fill M/C resevoir to top line. Crack all connecting lines loose 1/4 turn. Go inside & pump the brakes slowly full strokes for 6-8 pumps. Go refill M/C & do it again until you can hear fluid squirting. Tighten up the lines then go thru bleeding at the wheels with a check valve bleeder tool into a soda bottle with some brake fluid in it. Fluid in bottle is to keep bleed tool from sucking air back up into system. LF whl 1st, RR whl 2nd, RF whl 3rd, LR whl 4th, until no more air. May take a big bottle of fluid to get it done. One man operation. Done it for years this way. Just for giggles, check your brake proportioning valve under the car for leaks. DS under the back seat area. My 87 GL valve leaked so had to improvise with aftermarket proportioning valves up front in engine compartment. See my czny member car build. -
NAPA bench bleed video: Beck-Arnley products are generally good choice: https://www.rockauto.com/en/moreinfo.php?pk=485051&cc=1270055&jsn=372 Raybestos is usually my first choice: https://www.rockauto.com/en/moreinfo.php?pk=309748&cc=1270055&jsn=381 Get a bleeding kit from NAPA or HF with universal fittings x 2, cheap clip set & a cheap wire separator set & make your own bleeder setup. -
Ea82T Vacuum line troubles.
czny replied to Awdsome001's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, there's supposed to be a plug in there with a metal sealing washer. Look at your passenger side to give you an idea what it looks like, if its there. -
https://www.ebay.com/itm/R-12-Refrigerant-3-National-R-12-Can-Usa-made-genuine-12oz-Can/222647142150?epid=0&hash=item33d6cdc706:g:l9oAAOSwj9dZvXqR If its all leaked out, find the leak with dye & a black light, fix it. Then remove the compressor, drain the mineral oil & refill it with fresh oil before you recharge it with R-12. Four Seasons website has fill capacities for oil & R12. Oils can hold contaminants in suspension for a long time.
Broken timing belt leads to low idle?
czny replied to Brianmitchtay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There are 3 marks on the FW for cam timing. Use the middle mark only for L or R cam timing setup. Ignition timing marks should be obvious. I painted my 20* & middle cam marks with a silver paint marker for clarity. Any light color paint will do. Yup, the split where the VC meets the cam tower is a good reference for cam sprocket lineup. Those videos kinda got buried in the last forum update I guess along with some great old threads about Frankensteinian transmission mods, etc. Time for new bookmarks. -
Start with basics. Unplug, clean & re-connect your engine harness connectors a few times to make sure they are making good contact. 5V sensors can't have any resistance lowering signal voltages to ECM. Get undet the dash & make sure ECM connectors are good. Especially check that white translucent connector to left of ECM with all the shielded wires in it. That's your sensor nexus to ECM. Check all your chassis & engine grounds. Eliminate any poor electrical connections before you start swapping out MAFs, etc because I've been a victim of that myself. Search for bucking, stalling problem thread. Poor sensor connections can seem like failing sensors so any weak link in harness chain can cause a problem. -
700 rpm + / - 100 rpm. According to tuneup decal under my 87 5MT D/R GL hood. So 650 Rs is OK.
