23
Everything posted by czny
Official 6-Lug Re-drill Thread: Now in the USRM!
czny replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's my 87 with b2300 mazda wheels. One with the wheel fully stuffed - mounted everything but the spring & jacked up until it lifted both wheels. 4" SJR lift, 27x8.50x14s OOPS! No pics! -
While cleaning out the garage I found a very used Powertrax locker for a C10 Chevy PU. If you're interested I'll mail it to you - send a PM with your name & address.
Rust in the gas tank of my L series....what to do?
czny replied to fishboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Remove the tank, drain it & take it to a radiator shop to be boiled out & soldered if there are any pinholes. Surest way other than a new tank to get rid of rust & scale. And have them pressure test it. -
Sets from 1/2 to 1" are also available like Model #831-0102 from enco.com, for $47. -
Sounds like you've got a cracked distributor cap & it's cross-firing some cylinders. Check the inside of the cap & rotor for tracks.
Don't know what manufacturer you prefer but here's a link to the Empi site for catalogs & silicone vs neoprene boots: http://www.empius.com/2004_ab_joints_rpcomp/2004_ab_joints_rpcomp.html
87 GL wagon spfi ea82 with intermittent stalling when you come to a stop. Replaced vacuum lines, breather lines, cleaned the maf, checked timing & idle adj. Still there. Today while cleaning out the idle air valve found insulation on one of the solenoid wires was cracked shorting to the little clamp on the solenoid - just bare enough to short when braking hard so the connector pulled on the wires. Wouldn't have noticed it if I hadn't been checking the solenoid resistance to make sure the coil was OK.
Currently there are some street trolls testing car alarms around my area.....hitting cars to test the motion detectors. Common trick to keep wearing down the victim so the alarm stays off. And then..... Granted some lurkers will be reading this thread...... Infrared camera(s) pointed & ready......
Proximity switch & a relay also works for fuel pump/starter defeat. Epoxy a large steel wash to the back of the plastic dashboard & the proximity switch in the middle of the washer hole. Position your favorite fridge magnet to start & run the car. A few washers in other places might help confuse the uninitiated.
Real random question. At some points along the line it looks like the Dual range trans reduction gear ratios changed. Some were 1:59 some were like 1:19 or something? When was/were the changes? Any way to tell from the outside which gear set it will have? (in case someone did a swap) From my copy of 87 FSM it appears the d/r turbos had different gear sets & reduction gears. Begs the question if the lower ratio gearsets could be combined with the 1.59 reduction set? Anybody else? http://s1261.photobucket.com/albums/ii590/kazinski5/?action=view¤t=87MTtransspecs001.jpg Edit: Sorry for the small pic but when will it be possible to upload pdfs?
I opted for the 14x6 Mazda truck wheels which have a smaller center hole(hub centric). Mounted the hubs on outer axle stubs & turned down the 4 nubs to fit on my bench lathe. Drilled starter pilots with a 9/16" bit from the wheel lug holes then drilled 3/8" pilots thru. Machined flats from the other side with a 7/8" counterbore & 3/8" pilot(enco.com). Then increased the hole to 35/64" in steps. Built up 3 short beads of weld around the hole with a MIG then cleaned up with angle grinder & die grinder. The hubs are steel & weld easily(Just not too much heat to warp them.) Used 610-322 Dorman wheelstuds(rockauto). Pressed studs almost to bottom of knurl & let torqued lugnuts square the studs to the hub. 87 GL wagon with 4" SJR lift, 27x8.5x14 Grabbers on Mazda PU whls. -
I had the same code on my 87 GL TBI when I first bought it in 2007 - 34 with intermittent CEL. Found the solenoid coil had infinite resistance when the CEL went continuous. Dealer wanted $150:eek: Found one @ local PAP for $5:banana:
My EA82 engine had a small leak from this "bypass" before I rebuilt it. Replaced the swaged tube with a 1/8" NPT 45*elbow & barbed fitting. The Edelmann # is for the elbow. Gotta be careful when you drill & tap the hole - keep the same angle as original & put a piece of hose over the drill bit for a stop to limit the depth. Maybe the purpose of this is to vent air from the coolant passages at the top of the block so there won't be any hot spots in the cylinder jackets.
Front struts for 89 GL turbo 4wd wagon
czny replied to methusalah's topic in Old Gen.: 80's GL/DL/XT/Loyales...
x3....Monroe 71876 front R & 71877 front L. -
Did you check some of the grounding points at the back of the car to see if they were corroded or loose? As long as you leave enough wire to service the fuel pump & the ground you add won't catch on anything. Be careful where you put your ground connection if you use a sheet metal screw to secure the ground to chassis.
On my 87 GL wagon the fuel pump & ignition relays are mounted to a bracket directly above the ECU. The small light blue w black stripe wire on the fuel pump relay goes to pin 47 of the ECU. Just to test the relay & pump take a 12v test light & ground the clip then touch the probe to the LB/Blk relay connector with the ignition on. You should hear the relay click & fuel pump running. I was under the dash to wire in driving lights anyway so I tested this - it works. Grounding this wire might be the solution for the ECU problem 86gl-10trbosdn mentioned. Hope this helps.
Just another thought - if the fuel lines are backward it won't start. Just tripped myself up on that one.;) The line from the fuel pump thru the fuel filter goes to fitting on the side of the throttle body. The return line goes to the pressure regulator. Hooked up backward & you won't have any fuel pressure to the injector. All this in the FSM under SPFI fuel injection(2-7, pg. 8, fig.10).
ea-82, coolant in head.. etched wall, any effect?
czny replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have 2 vehicles both running just fine with coolant stains in the cylinder walls - my 87 GL(EA82) & my 65 chevy p/u(sbc 350). I was told by my auto machinist that the etching effect of coolant is OK as long as there is no pitting. He told me that even after reboring cast iron blocks stains can still be seen. What matters is the piston to cylinder wall clearance & if high mileage that the piston skirts haven't collapsed. Scuffing up the stain with scotchbrite is OK - honing just to remove the stain is unnecessary. Always put a shop rag on top of piston before cleaning the bore. Have a great day! -
My 87 GL: Last Wednesday - rear diff LSD install, breather line in diff cover, modded hubs for 6 lug, rear disc convert w/SS braided lines, rear 4" SJR lift, Mazda PU wheels w/General 27x8.50x14s. Friday - pulled EA82 engine, took FW in for resurface. Replaced FW seal. Saturday - removed wheels, disc brakes, axles, struts. control arms, fender well plastic, spare tire rod. Installed EA81 washer bottle in engine compartment. Replaced left side inner & outer tie rod ends & boot.
I was at a friends auto machine shop last week. Some young guy had dropped his ej20t engine off for repair because it had developed a "ticking noise". The engine had been torn down to the short block with nothing apparent to cause the "ticking noise" - until they pulled the oil pan. #4 rod bearing had been destroyed - there were all kinds of metal flakes in the oil filter when they cut it open. So I get asked for a 14mm allen wrench & a piston pin puller for Subaru. Didn't expect that the turbo pins would be so heavy with small through holes like this one. The holes are about 8mm leaving little to grip because of the taper on in insides. Somewhere I seem to remembered reading about using concrete anchors with a slide hammer to pull the pins. Home Depot carries Hilti 5/16" x 3 1/2" anchors with 1/4-20 threaded studs in the center. Body dent slide hammer tool from local auto parts had a 1/4-20 adapter in the package. Had to grind down the head of the center stud to slip freely though the piston pin & thin the expanding shell to get a snug fit inside. Gently tap the modified anchor into the piston pin, grab the anchor shell with pliers, tighten down the 1/4-20 nut until about 1/4" of thread is exposed, screw on the slide hammer & a few light taps pull the piston pin. The piston pins had been hammering the pin clips, raising a ridge inside the piston pin bores. A bag of five 5/16 Hilti anchors - $3.56 w/tax.
