Any new ideas for the old intake manifold stuck bolt problem?
Just like @idosubaru says; Turn the bolt a little bit, spray the bolt head with PB Blaster or other penetrant fluid. Then torch the area of the head where the bolt is stuck with a map gas torch (handheld) Turn the bolt back and forth just a couple degrees again. Torch the area, spray with PB Blaster or dab on some candle wax while it's still hot. It will make the lubricant soak down to where it's needed. Keep repeating the process until the bolt frees up
How to replace EA82 head gaskets without taking the engine out.
Welcome to the Forum Although not impossible, it does make the job a lot harder to do in-car. Lots of bending over the fenders, or reaching up from under the car. Murphy's Law states that if one head gasket goes, the other side is not far behind... you may be doing the other side in the near future!
Could I put a ea71 in a 2nd gen brat
Hey @el_freddocan it be done? I'm not sure of the bolt pattern
Depending on what year the EA71 is from, the bell housing could be different. Earlier EA71s had a top mounted starter position. Later EA71s had a side mounted starter. The EA81s (what your 2nd gen brat would have) would use a side mounted starter
- '86 GL Wagon, Not Getting Fuel Pump Signal
Thanks for the reply Bennie, I will have to do some more tests; but the fuel pump does still work when direct power is applied to it. (I take a 12v battery and use jumper wires directly to the connector at the pump.) If I prime the pump long enough it will send enough fuel up to the carb to run the engine for 30 seconds to a minute or so. During that time I'll listen to the Fuel Pump (which I hooked back up to the harness) however the pump is silent and not pumping, and the engine will shut down once out of fuel. I could try an ohms (resistance) test on the coil, however it seems to produce enough spark to run the engine... In the past I traded out my distributor for one from a parts vehicle, because the car would randomly die once warmed up. It was probably also related to the ignition module in the distributor. The "new" distributor cured that problem for the years since then, however now this one must be acting up now too. More testing to come!
Vehicle: 1986 Subaru GL Wagon, Dual Range 5 Speed, Carbureted, Weber 32/36 Converted Issue: No longer getting Fuel Pump Signal to the Pump. It would be intermittent, but now seems to be consistent with getting no Signal. I've heard from @Gloyale that the 6 pin Fuel Pump Controller (Relay) only sends power to the pump when there is a Tachometer Pulse on the yellow wire... Is that Signal originated from the Distributor? Also I've heard from @GeneralDisorderin regards to the Controller, that: "The wire going to the pump is usually a blue with red stripe. The control unit will also have a yellow tach signal, black ground wire, and an ignition hot supply (white I think)." Background: The problem began intermittently... if I had an issue with the pump, I could either add Fuel directly to the carburetor to prime the system. Or, I could apply power directly to the Fuel Pump to also Prime the system. Occasionally I would have to do both in order to get the vehicle to run. Once the pump was working, it would not cut-out mid-trip. Not until the vehicle was turned off and then tried to be re-started later; would an issue happen, where I would have to do one off the pre-mentioned priming methods. Now the pre-mentioned priming methods no longer work... What kind of tests can I do to see what needs replacing? I'd like to have the wiring stay this way it was from the factory... however if not I could wire the fuel pump to a switch, racecar style... I'm not sure though; does the tach Signal increase/decrease pump speed based on engine speed? Thanks for reading, hope to keep my Wagon on the Road!
89 GL wagon on Ebay went for $1375
It was an automatic...
1980 Brat Tire Size
Could also check the door jam Vin tag. Sometimes that info will be there
83 GL Carter Weber carb help
Correct, you will need the EA81 Hitachi Intake Manifold to run the aftermarket Weber 32/36 Carburetor. There are many people out there that have them available... have you tried any of the Facebook forums? There is a lot more traffic there... I could list some of them here if you would like to try those avenues. Is your Subaru a 4WD? FWD? Manual or Auto Transmission? It is rare to find these cars in decent shape in your part of the country. Would definitely be worth taking the time to fix her up if not for you to enjoy but to sell later on to another enthusiast
EA81: need oversized pistons .020
@torpedo51 I spoke with Ivan over on one of the Facebook Subaru forums. He says he used the 2.0 pistons in one of his EA71 engines, the sister engine of the EA81. If it works in that application it should work in yours. It may not be the news you want to hear; but you will have to do more homework, sourcing, and more machine work if you go that route. Or if this is a side project, put it on the back burner until you can find the correct size pistons and rings for EA81... You already put the short block together... you determined with feeler gages that the pistons are now too small? Or the shop told you that they went .020 over? Also more news you may not want to hear; you may want to try a different machine shop next time... somewhere along the line there was miscommunication on someone's part, either you or them or both were unsure what was going on. And you said that they lost parts of yours, sounds like somebody was unorganized... I wish you the best in this project and hope you don't have too much $$ sunk into this or need this vehicle as primary transport
Keep an eye on Flea-Bay and the other parts cites. You may get lucky and see come up for sale. I've heard of people boring up these EA81 engines to accept the 2.0 pistons from the EJ20 engines. Those piston and ring sets would be easier to find... hopefully someone more we'll versed will chime in on that... @ivans imports @el_freddo @GeneralDisorder
