16
Everything posted by 6 Star
Wanting a brat, need some info...
6 Star replied to race_to_live's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Everyone has their own prefferences... I think it just comes down to finding one in good condition in your area. Try finding ones that are as rust-free as possible. A Brat is a Brat. If you find a good base you can always add a cyclops light or jumpseats later. Have you started hunting yet? -
6 Star replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its UberScoober. lol Sweet build. You have a build thread up yet? Would like to see all the progress you have made and the finishing up you will do. -
Awesome indeed. More Subaru humor -
Finally picked it up 1976 Subaru Coupe
6 Star replied to Legacy RallyGuy's topic in Historic Subaru Forum: 50's thru 70's
My mistake. Anywho I'm subscribed now, interested to see where this goes. Looks like a lot of fun. -
Thats a pretty friggin awesome sedan. What kind of engine upgrades? EJ swap? -
I've had similar symptoms in my Brat before. First it was the left front wheel shaking violently. No noise, just shaking. Replaced that CV axle and problem solved. Then the passenger side front wheel did the same thing on a longer trip on the highway. (this wheel I knew also had a bad wheel bearing) Had to limp it all the way home like this, so I ended up replacing the ball joint as well from all the shaking. When I took the axle off it was evident that the bearing had gotten very hot because it left a heat mark on the axle. I replaced the bearings and axle in that side. Now, no more shakes or worries at all.
Yeah, its made out of bondo. He said so in the other thread before he picked up the car. -
She looks great! Does it run?
Welcome. Are you the original owner of the car?
If you're looking for tranny/parts themselves, you can go to the for sale section of the forum and look around or post in the "parts wanted section". If you want to know how to do it, you can search for past swaps people have done or look in the Ultimate Subaru Repair Manual. Best of luck.
If you can get your hands on a Haynes "SUBARU 1600 & 1800", make sure to get the 1980 thru 1989 edition. It is geared more towards ea81's. The 1980 thru 1994 edition is the re-publish and is geared toward ea82's, which will be very unhelpful to you.
^^^ +1!! So what if its fwd. :cool: Make it nostalgic.
Ah... The Japanese and their attempts to make things seem American. -
The yard stick trick only works if one of the windows is left down slightly. The angle is too great when the windows are all the way up, and will result in a broken window or not opening the door.
Put a shim through the top of the window to pull it away from the jam. Slide a long, thin metal object (like a tong/poker/campfire hotdog roaster stick) down through the gap you made and tap at the unlock switch until it flicks over. Just be careful.
