bertherr
Location
Bowie, MD 20715
bertherr's Achievements
Member (2/11)
10
I would clean the engine, transmission, & underside of the car real good. Then, I would have a fluorescent die added to the engine & transmission fluids. You drive the car for a while & then search for the source of the leak with a black light. My mechanic has the ability to look for leaks this way. This method is even used for the a/c system. I hope this helps. Bert
My car is a 1995 Legacy AWD LS wagon, auto trans, 105k miles. I have had to replace the passenger side drive axel seal twice in the last year. I also have a leaking auto trans rear output seal. Could there be a common cause here? I was just reading some other posts about clutch packs and it got me thinking. Thanks, Bert
This shaft seal can not be replace without first removing the toothed looking piece in the photo. It screws out after removing the locking tab. It has an o-ring you should replace, too. I would suggest replacing the inner boot while the shaft is removed. It is common for this inner boot to tear. I have had it tear on two different Legacy's. Bert.
Do a search for "why do my antilock brakes activate when they should not". Or something very close to that. You will see that I had a similar problem. Read the post find out all of the possible causes. I also had a mechanic tell me that it is not uncommon for your type of symptom to arise after doing brake work. They find that debris from doing the work gets on the sensor and causes the problem. In my situation it is possible that metal shavings from drilling out a busted bolt got on my sensor and messed it up. Good luck, Bert
Go to the link I will put below and read the messages. Specifically the fith one from Chap. I had my 95 legacy wagon totaled this past March. I used the advice from this guy and I received about $1,500 more than the insurance company originally offered. The starter of this post is someone I used to work with. I replaced my car with a twin I found thanks to the insurance company that paid for my old one. I asked for the listings that they used to help determine the value of my car. I live between DC & Baltimore. The car was in Philly. I would have never looked in classifieds up there. I ended up with a car with more options and 100,000 less miles for $1000.00 less than the insurance company gave me. http://www.practicalmachinist.com/ubb/Forum1/HTML/004410.html I hope this helps you, Bert
Three weeks have passed without any symptoms at all. I even went up and down a dirt mountain road that took about 45 minutes to go a few miles. Another Subaru was the only other vehicle I saw besides 4wd trucks. Anyway, there are two things I did that may have had an effect on the ABS: I did find metal shavings all over the right front sensor and removed them (a bolt had broken off that had to be drilled out nearby). I also rotated my tires. I measured their loaded diameter with a Pi Tape. The set that had been on the rear were .118" larger than the ones from the front. The next time I go to my mechanic for preventative maintenance I will have him read the codes and see what they tell us. I do not want to try to read them myself now that the problem has gone away. Thanks, Bert
