ccrinc
9
Everything posted by ccrinc
I have a 2009 Forester. EVERY time it is driven under a load (like going up hill, over 42-4500rpm for over 2 minutes), this condition manifests itself. EVERY time. Cruise light flashing and cruise disabled, check engine light on, traction control light on (if you have that). When I put my scanner on it, it always comes up with the PO420 code. Always. But the car runs fine. Both O2 sensors have been checked, cat's ok, no other issues. I have come to the conclusion that there is something about that that thinks the car is being overstressed so I simply don't drive it like that. (My grandson, however,...) So, I clear the code and go on my way. And it will run fine for months, or until grandson drives it again.
Thanks everyone! (Didn't mean to start any arguments! ) My daughter and I are taking a road trip next month: Rapid City, SD to Monterey, CA. Through SD, WY, UT and NV there's a lot of empty highway...well, empty except for all those damn deer. I keep my headlight lenses "serviced" so that's not an issue. I'm just not impressed with the stock bulbs in my Forester. My last trip to Denver just confirmed that. I'm only doing the high beams. I don't like being blasted by those new HID lights either. But when it's the issue of me vs. the deer, bright is what I want. I also have to say that I'm sorry I don't check in here more often. Since we closed our shop in 2016 and I'm retired, I just don't get around like I used to. I also fault the 2 spine surgeries I had for that! But y'all are always in my thoughts. Best group of people ever!
Yes, I know I asked this before. And somebody gave me an answer. And I can't find it. Sue me: I know engines, not headlights. What bulbs are good to upgrade mine (low beam) on my 2009 Forester Premium? Trying not to fry the electrical system here. Thanks in advance! (Oh, and hi, guys. Been around some, just not commenting. Hope everyone is well.) Emily
If you check out Google, you will see thousands of posts for this same problem, most of them starting in 2009. My 09 Forester has the same thing on a reman'd. engine with less than 3,000 miles on it. I did replace the exhaust manifold and the upstream O2 sensor, but it needed those anyway. If you have a code reader, you can clear/turn the code off. It will stay off until you drive the car fairly hard, like 2nd gear uphill for about a mile. Nobody (especially not the dealers) really know what's going on. The engine runs great, the mileage is about 24mpg (pretty standard) and it's great except that I think the exhaust smells too strong. Note that during the rebuild it got new plugs, wires, etc. and the injectors are good. Meh. Every Subaru "generation" seems to have its own idiosyncrasy. It's part of their charm. Emily
Agree with everything GD said. Frankly, the Justy was a POS. They were fun and economical while they lasted, but they didn't last very long. They had an annoying habit of throwing the #3 rod due to people treating them like the cheapo car they were and not changing oil as they should have, or letting it get low. The last time we did a Justy engine (for someone who was a friend and colleague), we found the parts to be expensive and dealer-only availability IF they could even get them. Nothing on this car changes over from any other model Subaru. Seriously, just walk away. That $5-600 is going to become a few thousand real quick. Emily
I bought a cheap Autel off Amazon. It's just for reading codes (and clearing them). I can get what the codes are off my computer. It works for me on my 2009 Forester.
- 14 replies
- obdii
- testing equipment
(and 3 more)
Tagged with:
Super Rupair. Ask for Trent (only!) and tell him Emily sent you. He'll know who you mean right away. 303-442-6508. Biggest independent Subaru repair shop in the area. They aren't cheap, but they do know their Subarus. Boulder maintains the main roads very well. Anywhere in CO, side roads are an afterthought. Emily
No, We may have a few laying around though. Automatic or manual?
Why does nobody ever think about the torque converter? On the later 4EATs, that is their weakest point. The earlier models were not as sturdy, but Subaru improved the internals a lot in the late '90s. However, the torque converter can (and does) wear out. As long as you're going to be getting the engine out (trust me: on this car you want to take it out to do headgaskets), get a rebuilt torque converter. If the trans. fluid looks and smells good, it's quite possible that's your main issue there. Emily
We used to use all ACL rod and main bearings, but they began outsourcing their "regular" ones to Japan. Bye-bye, ACL! We'll still get their race bearings "when they're available"., which isn't often. So, in looking around for another decent (and decently priced) alternative, we started using King race bearings instead. Made in Israel. The first time we tried them, we didn't like them. Now, they're pretty much state of the art. These days when I see "made in China", I just go "so what else is new?" Remember when people used to say that about Japan? ps: for timing belts on zero tolerance engines, it's Subaru Genuine all the way, IMO!
Jseabolt: what is your altitude? Something I've discovered many people don't take into account is how "high" they are, although the local gasoline companies do. (Like in Colorado, "regular" is 85, while mid-grade is 87, premium is 89 or 91.) What Subaru recommends as preferred octane is based on the car being at sea level. Higher altitude requires lower octane. In your case, it seems that you're experiencing the reverse however. But, it made me curious about it. Just a thought, but you may be on to something. Emily
1) Do you not check your oil regularly? All newer cars can/do use oil (and sometimes coolant). At any rate, you need to get into the habit of checking your oil. 2) That engine only holds a little over 4 qts. of oil. You are down by about 3 qts. DO NOT DRIVE IT without adding more oil. In fact, I wouldn't drive it at all. Have it towed to the dealer. You probably already have bearing damage. 3) Knowing it had run low at least once before, why would you drive over 4500 miles without checking it? What kind of oil are you using? Dino, part synthetic, full synthetic? Even with full syn, I never let my car go over 5,000 miles at the very most without an oil change. Subaru's "7500 between changes" is BS. Sorry, but the oil usage on this generation of Subarus is well documented. Good luck with the dealer. Emily
