ccrinc
9
Everything posted by ccrinc
Will this timing belt/water pump kit fit my 93?
ccrinc replied to __CJ__'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
What ^^ he ^^ said. -
If the engine has been run low on oil, replace those internal tensioners too: they're lubricated by the engine oil. One has to be careful about how much is taken off the heads of EZ30 engines. Take too much and the chains won't line up properly. SOA claims that you can't take any off, but that's BS. We build these engines and always surface the heads, just not too much. Emily
- 12 replies
- H6
- head gasket
(and 2 more)
Tagged with:
Fwd Fuse
ccrinc replied to BigRed93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
15 amp is the recommended. What is does is make the car front wheel drive while the fuse is in. -
Rebuilt EA82, low oil pressure and ticking.
ccrinc replied to djellum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When the rebuild was done, did you replace the lifters, or bleed down the old ones and reuse them? Either way, it's going to take at least 30 mins. of idling for them to pump up again. Until you put a manual pressure gauge on it, you aren't going to know for sure what your pressure is, but even with good pressure the lifters take awhile to pump up. (the only engine which I remember having a metal/rubber o-ring on the cam towers is the ER27...are you positive you got the correct ones?) Emily -
1985 GL Wagon blowing blue smoke
ccrinc replied to ednalor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You guys who are talking about the sweeping turns are thinking of the SPFI engine which wasn't made in 1985. Start with the PCV and hoses, and go from there. There are so many possible culprits that I'm not even going to speculate. Emily -
Subaru dealers have never admitted to the DOHC engine head gasket problems. They were ordered not to by SOA. Those prices are outrageous. Definitely take it to a reputable independent shop! Valve cover gaskets for $470? Holy crap! And reboot an axle for $393? A really good reman'd axle runs about $120 plus 1 hour labor (max.) At that price, it should be a new axle, not a "fix". I will also add to the comment that your daughter needs to learn and be conscientious about keeping an eye on fluids, getting the oil changed at proper intervals, etc. Daddy can't be there to do it for her forever.
- 26 replies
- 1
- knock sensor
- valve cover gasket
(and 3 more)
Tagged with:
Skip does not have to take it to either shop which I suggested. I just happen to know and have respect for both of them. There are a lot of Subaru shops around the Seattle area, some with good reviews and some with very bad reviews. We're leaning toward fuel system as well, as in charcoal canister, purge solenoid, etc. Unfortunately, we cannot diagnose this from this distance. IF the issue does turn out to be our fault, we will indeed pay for the diagnostic time. The dollar amount of labor we pay per hour is clearly stated on our warranty paperwork.
This isn't my thread. Mr. Allen started it because he is on a self-stated mission to tell every Subaru forum that we don't stand behind our work as per his emails which is why I offered to reply. He may never check back here again. Briefly: Has P0303 and P0304 misfires (opposite sides: I believe this is what is causing the "imbalance") Runs "ok" cold and with full gas tank. The misfire doesn't start until the engine is hot, and gets worse with lower fuel. Dealer checked cyls. 1 and 3, not 3 and 4. 160lbs compression on both. Dealer says "may be a valve sticks open when hot". It would far more likely to stick when cold than hot. Sorry, I don't have much faith in the diagnostic abilities of most dealer techs. That's not how they're trained. He has replaced all kinds of stuff, some of it (like the coil) with aftermarket. It is worthy noting that the dealer replicated the problem using an OE test coil, AFTER the engine warmed up. BUT, he never contacted us about any kind of problem for 6 months even though he said the problems started after 100 miles. When he did finally contact us, it was to demand a new engine. And no, I don't see any way we could test the problem after shipping the engine back to us (1,000 miles away). It would need to be in the vehicle for us to diagnose it. This is a complex issue. I suggested 2 good shops to take it to who are extremely capable of diagnosing complicated issues. (The internet reference was to a similar anomalous situation involving other, older vehicles, not his specifically.) What we do is purely mechanical. Something outside of the engine is causing the problem. This is our sincere belief. As I told him, an engine can be on the verge of throwing a rod, or the timing belt tensioner will break with no CEL beforehand because those are mechanical issues, not electrical. So, there are a lot of good minds on here. FairTax, Gary, anybody with real experience care to comment? Not to be too rude, but no half-assed guessing if you don't have experience. So far, there's been too much of that already. Emily
Go to kennedyeng.com and look under the "Vanagon" link. This will tell you the conversion parts you will need outside of the Subaru stuff. Our website, ccrengines.com has a list of stuff under the "VW Conversion" link. Just be sure all the electronics (wiring harnesses, ECU, sensors, etc.) all come from the same vehicle. Not looking to sell anything here, just give information. Emily
FWIW, we use only Ultra Gray 599 in our shop. For over 20 years now. It works. Don't glob it on, and don't make the layer TOO thin. That's the only tricky part. A consistent, even layer that has enough to "squish out" only slightly, but not so much that you have globs coming out of the seams. I realize this may be too technical a description.
The power light is telling you that you have a problem with (duh) your transmission. The rattling noise could very likely be a broken or cracked flex plate, but that alone wouldn't put it in safe mode and a bad torque converter (very common) wouldn't give you warning lights because it's purely mechanical. We used to rebuild transmissions as well as engines, so I've seen the job and I don't want it. I think you need to find either a reputable transmission shop that will do a Subaru transmission (not all will...they're rather complex) or a decent low mileage replacement. (Don't forget to match the gear ratios!)
