ccrinc
9
Everything posted by ccrinc
I recently acquired a '97 OBW, 5 speed Limited (really nice!) and am using it as my daily driver. Naturally, it has a freshly reman'd EJ25 in it. From day one, the CEL has been doing exactly what you describe. But the car runs perfectly, even with the 1&3 misfire. For a few days, I had very high rpms at idle (both cold and warm), and we replaced the IAC. That cured that problem, but didn't help the 1&3 misfire. I have "heard" that there is/was a recall on this vehicle for the neutral safety switch which "could" cause these issues, but due to personal conflicts, I haven't had a chance to look into it. As soon as we find out a reason and cure for this, I'll post it up here. (The owner's wife's car...you can be sure the issue will be resolved! ) Emily http://www.ccrengines.com
Brembos are an excellent product. Probably the one aftermarket I would use on any of my Subarus. I would still recommend the Subaru pads with them however. In fact, there are a couple of newer Sub models on which Brembo is the "Stock OEM" part. (Don't remember which however...old age is setting in ) Emily http://www.ccrengines.com
Not to beat a dead horse, but NEVER, EVER use any of those seal-a-leak products in a Subaru! EVER!!! They will do nothing except totally screw up what's left of your cooling system and plug up the new water pump. Also, Subaru radiators are famous for corroding from the inside-out. Have it pressure/flow checked thoroughly. A bad radiator has caused more problems for Subarus than all the water pumps put together. Emily http://www.ccrengines.com
A Subaru is the perfect "first car"! I taught both of my stepdaughters, my grandson and 2 other teens how to drive in Subarus. They handle great, they're fun, they're cheap to insure, and they are very reliable. Most of those "kids" still drive a Subaru because they just love the cars so much. Look on the back of the car: does it say Legacy or Loyale, or something like GL10? That will help us figure out which one you have. Good luck and have fun (safely) with your first car!
As GD pointed out, it's not about the size, it's about the quality. If you have a big filter, but the media inside is crap (which many Purolator and other brands are), then you've just wasted your money. A smaller, correct filter with good media is better than a larger, incorrect filter with cheap, thin media. Subaru Genuine filters or Napa Gold (made by Wix) are the only ones we will allow on our engines for warranty purposes. Men, it's all about the quality, not the size! Emily http://www.ccrengines.com
SVX lives?
ccrinc replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Can't compare with the personality of the original SVX. IMO. -
svx in outback
ccrinc replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Are you positive? The EG33 is too long to fit that body without substantial metal work. -
SVX Research
ccrinc replied to 9098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
As for replacing the windshield, I recommend glass replacement insurance coverage. It's cheap and will cover the $1200 replacement cost with a $50-100 deductible. Anyway, it's what I did with mine. A Transgo shift kit will make the transmission much more reliable, and incredibly responsive as well. Also have that on mine. If you want to look at the one I have for sale, go to the Vehicles for Sale on this forum. Lots of info there too. Emily http://www.ccrengines.com -
SVX tranny?
ccrinc replied to bratman18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Adding a transmission cooler helps a lot. Also, there is a kit made by Transgo for the valve body which pretty much eliminates the shift issues for SVX trannies. They were made to shift smooth and easy, but that increases the wear and tear on them. The kit makes them shift quickly and firmly. I've had both on my SVX for about 4 years now, and the tranny is perfect. The only transmission which is a direct swap is a Legacy Turbo model.
