ccrinc
9
Everything posted by ccrinc
Mitsu also makes practically all the internals for all the automatic transmissions out there, just different style cases. (At least for the Japanese cars). Wouldn't be surprised at how many are running around in US cars either, not counting the rebadged stuff like Dodge Neons, etc. Emily http://www.ccrengines.com
How do you lift a 1979 wagon?
ccrinc replied to cricket's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A BF forklift?? Emily http://www.ccrengines.com -
removing rust from chrome trim rings
ccrinc replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Boy, don't you guys ever scrub pots and pans? Scotchbrite has several no-scratch fake steel wool pads that will do the trick and won't scratch the metal much, if at all. You can find them in grocery stores, Home Biggies, Walmart, etc. Doesn't have to be the Scotch brand: just look in the home stuff section for non-scratch pads. Incidentally, we use them at the shop for taking the final little bit of sealer off aluminum mating surfaces like block halves. Emily http://www.ccrengines.com -
I bought me a beautiful '92 SVX, black with grey leather interior. A perfect match for my '92 Legacy Turbo Touring Wagon LE (also black). Sweeet!! Of course, I now also own the two most difficult, hair tearing, ratchet throwing, sailor swearing cars to work on. Good thing my other half is the Subaru Genius, eh? As of today, the SVX came in to not only get the transmission rebuilt (shift kid modification, of course) but a complete engine rebuild too! Why not? It needs a tuneup, and a rebuild isn't that much more trouble. So, watch out there guys! I'm on a roll!! Emily http://www.ccrengines.com
Just heard about this recently, and from the amount of misfire problems I'm seeing here, want to pass it on. Seems there is a "phantom" problem with the later model EJ25 ECUs. Most consistent symptom is an engine which runs perfectly, but will throw a cylinder 3 or 4 misfire code every couple of weeks, usually right after doing 65-70mph and letting off gas. Disconnect battery, reset ECU, runs fine for couple of weeks and poof! suddenly you have a misfire code and a flashing CEL. Here's what I've been told by one of the best diagnostic/electronic guys in the business, Greg at Strictly Automotive in Denver, CO. Nobody, especially Subaru, knows why this is happening. The only permanent cure he knows of is to have the ECU reprogrammed. I understand that there is a company or 2 in California that do this, but I have no idea who they are. The other possibly less expensive and maybe easier cure would be to find a used ECU with the same part number. The only problem is: how do you know that the "new" doesn't have the same "phantom"? You can throw money at it, try to diagnose it, but if you've addressed the obvious problems and it's still happening, then you have the "phantom gremlin" in your ECU. Not sure if this is a help or another monkey wrench to throw into you guys who are having this problem. :-\ Emily http://www.ccrengines.com
Kellie, That's sweet! You rock!!! (btw, you comin' home any time soon? I gotta Hawaii souvenir for ya! ) Emily http://www.ccrengines.com
New motor in and running, in a crappy way
ccrinc replied to singletrack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Joel, We'll be back Monday and we'll be in touch to figure out what's going on here. Is it still idling rough? Or is the lifter ticking the only problem now? Sometimes a lifter will not want to pump up. If that's the problem, driving it is the best thing for it. Either way, we'll contact you. Emily http://www.ccrengines.com -
OK, first, by your description of how you set up timing, you're one tooth off on the distributor (practically guaranteed). Second, drain out that synthetic immediately and replace with regular oil! (I thought we discussed that). The engine parts will NOT seat properly and your lifters will not pump up using synthetic oil. Wait until you have about 10,000 miles on it before going back to synthetic. I know the stuff is expensive, but you're hurting the engine by using it at this point. (Didn't read your break in tips, did you? ) Emily http://www.ccrengines.com -
1600 pistons if you want some speek now...
ccrinc replied to tailgatewagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We could use 8 or 12 if you have the time. Some idiot former employee trashed most of ours . We'll be on vacation until March 21. Email me if you can do this. And thanks! Emily http://www.ccrengines.com -
Are you pointless and stupid?? Sorry man...couldn't resist. It's been one of those days. People who badmouth aren't worth paying attention to. (ooops, dangling participle) If that's the only way they can feel like they're worth anything, just keep beating them and tick them off! Besides, they can only make you feel like that if you let them. Emily http://www.ccrengines.com
There is a part in the '99-up 4EAT transmission that I believe is called a piston. I couldn't believe the first one I saw! The dang thing is made of aluminum, not steel! These have a lot of stress put on them, and definitely effect the shifting. We decided to stock new ones as a matter of course. Emily http://www.ccrengines.com
