![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
ccrinc
9
Everything posted by ccrinc
Sorry, but Bwahahahaha!!! I know it's frustrating and a pain, but to us city folk, that's damn funny!
Yes. They all have oiling issues which is what causes the bearing failures. In fact, the older ones are worse than the newer models. Ringland failures are usually the fault of the owner: too aggressive on the tuning, stupid tuning, running too rich or too lean, constant redlining, etc. We can hardly build these fast enough! Emily
GREAT engine. BUT...faithful oil changes are a MUST. But they are very reliable when maintained properly, which includes the cooling system. Changing the timing chains is not for the faint of heart. Over 100 bolts just to take off the front timing cover. To replace the tensioners, you must also take off the inner timing cover: another 100+ bolts! And, they must be removed/reinstalled in a specific order, then torqued in a specific order. I've seen the job and I don't want it. Emily
"Left" and "right" are always noted as if you're sitting in the driver's seat. Therefore, left is always driver's side, right is always passenger's side. The belt guard is to protect the belt from skipping time. An automatic won't roll backward when the car is stopped and in park. A manual will, unless the E-brake is set. You know...that little backward roll for a few feet...it's enough to jump time and cause problems in these zero tolerance engines because the engine actually rotates backward when that happens. Recuperation. HA! If anyone ever says they want to fuse your entire spine AND put titanium screws and rods in you from your neck to your butt, tell them to go to hell! I did it for good reasons but I still wish I hadn't. I work from home, I haven't driven in 2 1/2 years, I'll never be able to bend ever again and I have constant spasms unless I'm lying flat on my back. I may just be the most badass woman you will ever know, because I've gone through it TWICE. Otherwise, I'm good. How about you? Or, as they say in New York, "how's by you?" Emily
I remember one time when we bought the last EA71 head gaskets available in the country. They came from the only Subaru dealer in Wichita, KS. The packaging looked like it had been on the shelf since 1977! Ya never know.
Check your coolant temperature sensor, located on the coolant crossover pipe beneath the main intake manifold. When they go bad, or get dirty/corroded, you get a run rich condition like you have (which is really bad for your engine bearings, BTW). In general, remember that if it's rubber, it's going to deteriorate sooner than later. Emily
There is a difference you should be aware of: the engine from an automatic does not have the bracket on the oil pump which keeps the timing belt from jumping if the car rolls back a bit like one out of a manual does. You know how a manual car does: it rolls back slightly when you stop if you don't have the E-brake set. Plus the EGR setup Matt noted. Also, '98 is the year that Subaru went from a center thrust to rear thrust crank and 4 bolt to 8 bolt bell housing. 6/98 to be precise. That said, the rear of the crank bolting to your transmission is identical on both. Emily
bad knock
ccrinc replied to legacy603's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Are we assuming you checked the oil level? Emily -
We use Permatex Ultra Grey 599. Just don't get any gobs floating around and clean the surfaces very well before applying. Also, it can't sit and wait: it must be joined quickly. Emily
FYI, that oil pan is supposed to have a gasket, not RTV (which is a royal PITA). They are available at NAPA for a moderate price. Make sure you get one for the right year, they are famous for trying to give EA81 pan gaskets instead.
You're going to hate me, but that tiny o-ring is for the oil pick up tube in the oil pan. If the one you have now (assuming you have one) has even a nick in it, oil won't suction up into the engine. 4 thick ones - fuel injectors I'm not sure why you have MPFI intake and exhaust manifold gaskets for an SPFI, but that's what you have. I "think" the blue ones are for carburetor mounting: I don't "do" carburetors. That's a French word meaning "leave it alone". Emily
I have to respectfully disagree with you on the warping. Subaru heads are notorious for warping, and the tolerances have gotten to ridiculously low limits. The EJ25 DOHC heads had very little in the way of coolant passages and therefore, warped very easily. It is critical that both the heads and block need to be absolutely flat for any gaskets to adhere properly. Emily
