About AK_Kev_007
- Birthday 10/04/1988
Gender
Male
Location
Anchorage
Occupation
Delivery driver
Vehicles
1990 Legacy
AK_Kev_007's Achievements
Advanced Member (3/11)
0
It's a wagon 5 speed with manual shift for AWD. EA82 vin 4 Part one: It's time to change out my clutch on my 85' GL. When I look up the parts on website it asks me if I have a clutch diameter of 7 or 8 inches. Also it asks if it's a 21 or 24 spline (looking up clutch sets). I'll probably go with OEM parts cause I've been having bad luck with after market clutch cables(broke 4 of them in 6 months). What should I set the clutch diameter and splines at? Part two: It's wintertime here in AK. Also known as drifting time! I noticed the engine starts to load up with oil in the cylinders between 3k-4k RPM's. I lose power and she starts to smoke real bad. (It sucks when I'm showing off for the new girlfriend by doing a continuous circle) The car will also load up on the highway in 5th around the same RPM's. Any ideas of what I can do to stop this?
I don't mean to steal the thread but what kinda motors do you have? I'm also in 99515. I drive the flat black '85 wagon with a glass pack and a stock red '87 wagon.
'87 GL Wagon with Low oil pressure
AK_Kev_007 replied to AK_Kev_007's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks Miles. As for how low the needle is right above the bottom mark when it is warmed up. And when I'm driving around at regular operating temps the needle moves to "45psi" which is right in the middle -
So on my '87 EA82 at idle I have low oil pressure at idle according to the dash gauge. I believe that this has also caused a lifter tick on the passenger side. I think my oil pump is worn out but I'm not to sure. I was hoping for other suggestions before I set out on the wild goose chase.
My grandfather picked up a 1990 Loyale about a year ago. It has a turbo but I'm not sure what engine class it is. But when we go to put coolant in the radiator it litterally runs out the tail pipe with out even cranking the engine over. He said he had it running once but it didn't run very well. Any ideas of why the coolant is coming out the tail pipe?
Got this gem off of CL for $350 EA82. It's an auto :-\ but that will be good for the wife. It runs, not perfect but it made a 20 mile trip without incident. The exhaust studs need to be replaced and the power steering seems to leak. The idle was really low until I went to park it the last time. Push button 4x4. Rear washer fluid pump isn't turning on. The dash clock isn't showing anything. The air conditioning hoses have been removed but the compressor is still in loop. zzz It has a fan off the water pump instead of electric fans. Tires are shot but it came with studded winter tires that are in great shape, just need to be de-studded. The carpet is going to be ripped out. Stained beyond repair. And last the clearcoat on the roof is peeling. It still runs and drives!! CL Pic So the 85' i going to modded into a trailing rig and the 87' is going to be the around town/ delivery car.
Not really. There is an emisions test in select cities/towns. My IM test is good until Jan 2013. Hopfully the IM testing will be done and over with by the end of this year. Atleast for Anchorage.
The only real bad rust spots I have is a football(soccer in some countrys) sized hole in the driver foot board. The driver seat is being held by 2.5 bolts so with the recline all the way up I still do the gangster lean. And both of the rear quarter panels where the jack and other junk went had to be seal off with foam. My sub frame is in good shape and she runs like a champ. 80 mph down Minnesota Highway all day long. I did however find an 87' wagon for $250 but I gotta wait for the cash to get it, rent sucks!
I'll start will bigger rims and tires. The suspension is already maxxed out. But the car does have cancer. Not from salt though more from sitting outside all winter long. Sucks but she was free
