Scar3Cr0w0nFir3
Everything posted by Scar3Cr0w0nFir3
  1. I have a 98 Subaru Outback w/ a EJ25 non Turbo, and it has a 5-Speed Manual Trans. Can anyone tell me what type of trans it is and wich one is the best or where this one stands among the other Manual Trans. of the new gens. Please and Thank you all
  2. Thanks, one more thing, with the 98 2.5l tran. will i need to take the flywheel off the 2.5l for the 2.2l ? Since the 2.2l in it alrdy has the bolt for the torque converter? and will i have to use the manual tran support bracket? and there both AWD so the transfer case will bolt up also along with the drive shaft? Thanks and Thank you agian for you help so far Very much appreciated:banana: O and 1 other thing can i keep the auto tran computer or will i need the manual computer
  3. Were working with a 1995 Legacy LSi Auto EJ22. First I had a 1996 Impreza LX Auto w/ EJ22, then I bought this 95 LSi w/ a blown engine. So I pulled the EJ22 out of my Impreza and dropped it into the LSi. Only the engine the trans. in the Legacy is still the original Auto. Well little time passes and my RWD wont work, so I have only FWD (there is no fuse in the FWD box, and with the back jacked up I can spin the rear tires and the drive shaft does turn and is attached to the Trans) and now I have lost Reverse. So I have a 98 Outback w/ a 2.5l and Manual 5-Speed Trans. the car has been stripped and the engine is blown but still there. Now finally to my question, and of course I know I will have to do alot of work to transfer auto to manual but can I take the 98 5-speed trans. and bolt it up to the 96 EJ22 engine from the impreza that is now in my 95 Legacy LSi??? If so can you please tell me what all I will need off of the donor car in order for this to work... I realy need this help its my only drivable car for now anyway... Please and Thank you so much
