About c0r3f1ght3r
- Birthday 07/09/1989
Gender
Male
Location
San Marcos, Texas
Interests
Computers, cars, music, and the great out doors.
Occupation
Computer Tech
Vehicles
1995 Subaru Legacy
c0r3f1ght3r's Achievements
Advanced Member (3/11)
Hey all I've found myself in quite a predicament once again. I just bought this 96 OBS with 122k. I noticed broken exhaust studs during the first oil change so I inspected the area and noticed there was a good bit of metal sticking out from each stud and decieded I would go ahead and replace the gaskets since I just completed this job on my 95 legacy which sold a couple weeks ago. I sprayed some pb blaster on the night before, then again about an hour before attempting removal. Now I'm not sure if its because I've been lifting weights lately but just a small turn with a big 1/2" bar broke another stud off so I tried the other side going as slow as I could wiggling back and forth but still it broke off as well. So now I'm left with this after a mobile mechanic attempted to drill one out and gave up: I know I have a few options here: Remove the heads Attempt to drill them myself Have a shop do all the work for me which I really don't want to do.. I live in San Marcos Texas and have tried a few shops around here, but none of them will touch this inside the car.. I want to try drilling them out using a carbide bit, and then a big easy out, but would I be wasting my time? If I go with removing the heads myself. What is the fastest way to go about doing this engine in car? I figure I can unbolt the intake from the heads, remove the timing belt, and then the head bolts and they should drop? I know this situation as a mess and I can't expect a solid answer here but any feedback will be greatly appreciated!
The battery cables are very tight, clean, and the car gets power. Here are some things I've found while messing around with it. The key cylinder works because the car beeps as soon as start to turn the key even with the ignition wiriing disconnected so I know the key detector works. When I turn on the 4 ways this relay or whatever it is circled in the picture below starts buzzing. I've tried replacing this part with another one from a RUNNING subaru and nothing changed. At one point two days ago I was able to get everything working, but this was after the key was in the ON position for about 15min so something is either burnt in the wiring harness and manages to get a current through after some point or there is a bad ground some where. Can someone link me a wiring diagram or a diagram showing all the ground points? I'm at wits end with this car and I'm acutally thinking about selling it now..
Hey all! 95 Legacy won't start and I believe it's either a ground or relay issue but I'm not sure. When I put in the key and turn it to ACC the car beeps, the oil light comes on, but no other lights, turn key over and oil light goes off. The door indicators work as well until I turn the key.. Car did this yesterday at the grocery store but then started after trying for about a half hour, and also couple months ago but started after an hour or so as well. I tried taking the ignition apart and turning the plastic portion with a screw driver but the results are the same so I believe the cylinder can be ruled out, any ideas? Thanks!
The alternator looks fairly new, but the starter and maf I'm pretty sure are stock. The car starts fine though and thankfully it is a manual so I don't worry about the starter too much. The car has only had two owners and the original owner sold it after a hail storm, second owner only had it for a couple months and they sold it because they were given a newer car. I took a good look underneath before I bought it and its virtually rust free, all the bushings, sway bars, etc are all very clean and doesn't make any noise even when driving down some bumpy gravel. All the axles were replaced at some point, but it seems they never touced the tie rods so I want to replace them soon since the boots are damaged. I may also do something with the exhaust because I'm pretty sure the CAT isn't helping at this point and it also makes this whistle sound at high rpm which I've read is caused by the muffler.
Yes I agree. I'm going to replace the wheel stud this weekend along with the bent rim. The AC was missing the drier can so I installed a new one and tried to refill it with one of those freon refill cans but the compressor wouldn't kick on so by next summer I'll take it into an AC shop and have them service it. Thankfully its nice dry heat down here!
So I just picked this little beater up and I have to say I'm impressed by it. This is my 4th Subaru and by far my favorite since its the first time having a 5 speed with AWD before this I had a 84 Subaru Brat 4spd dr 4wd, then a 93 Impreza fwd auto, and then a 98 Subaru Impreza Auto AWD. Here's some pics! It has 177,000 miles and ss far as I know the clutch, timing belt were done about 2 years ago. It has fairly new tires all around, service records all the way back to purchase date, and the only issues I've noticed is the ac doesn't work, theres some vibration coming from the front driver side when you get to about 50mph which the last owner said is from the wheel being bent, and a broken wheel stud on the back driver side which I discovered when I was attempting to rotate the tires to isolate the vibration. Anyway I'm glad to own a Subaru again!
