weldersd
About weldersd
- Birthday 01/19/1979
Location
san diego
Vehicles
I Love My Subaru
weldersd's Achievements
Advanced Member (3/11)
0
OK, I think i'm on to something. the service manual shows the speedo gear ratio for non-outback at .83 and .76 for outback model, so I just went on a approx 6mi trip with my garmin gpsmap 76 and I got the following readings: when the car speedo shows 60mph I was traveling approx 63.5 mph according to gps. after a 6 mile trip the car odom read 5.5 mi I divided 200/6=33.3, then .5x33.3=16.65 so at 200mi my car odometer should read approx 16-17 more miles than it is, this would bring us back to pretty close to our original pre-trans swap numbers. so that's good, now the only question remains why the extra clutch plate in the low/reverse clutch brake? I wonder if it has to do with the increased stall speed on the TC? Now that I found out the TC on the new trans has a lower stall speed, I now notice it, definitely engages much sooner.
ok, so I have the service manual, it's showing some differences with the outback version vs the legacy, it's in pdf so this forum won't let me attach it. here's the differences I see, (legacy 2500cc vs outback 2500cc) TC: Stall torque ratio 1.8-2.0 vs 2.2-2.4 stall speed: 2200-2600 vs 2400-2800 Transmission: clutch number for reverse and low 6 vs 5 that's the only differences I can see per the legacy 1996 service manual. -one more clutch in the low clutch pack, why? stall speeds for TC different, Can I just put the old TC in?
update: I replaced the upstream o2 sensor, knock sensor, and I removed the cat's I plugged one end of the pipe and poured detergent in the pipe, let it sit for a while, then rinsed, the cats seem free flowing and clean, I cleaned the pcv valve, it seems to be working just fine (blow test) all vacuum lines are attached and look ok. Mileage got a little better, but still around 20 ish city, when before the trans swap I was getting 23 city. here is the number off the new (used) transmission: TZ102Z2AAA-CG another sticker below that number showing: 933685, can anybody tell me EXACTLY what trans this is and if I need another TCU?
Thanks guys, I already wrapped the "y" with thin gauge aluminum, it helped a little, I also recently replaced my knock sensor and front o2, to try to improve mpgs, seems to be running smoother, we'll see how it goes, I mean come on is 250 miles too much to ask for?? I gotta do the alignment too, when I swapped trannys I must have not got the camber alignment quite right, it now pulls alittle, I love everything about the car all but the smell at a stop light, we had a brat back in the day, it leaked and smoked too, guess it's just a subie thing.
Separator plate replaced, still leaks:banghead: I changed the main seal and the small o-ring seal, I used ultra grey on the plate, lightly snug, wait hour then tighten a little more. on the main, I had a block of aluminum i used to square the seal flush with the block. oiled the inside lip. i'm thinking it's the main, should I use a additive to try to stop the leak? I have removed the engine for HG's/timingbelt, last time I removed for the seporator plate fix, on re assembly I stacked the pump, I found a junkyard match and it seems to be working fine, the car runs great, but i'm still getting that smell with the defrost on at a stop light, I hate it, I'm thinking of even making my own exsaust to move the "y" back so it's not right below the drip, dumb design. the leak is way better though, in 3000 miles I don't need to add any oil, whereas before, I had to add 1 qt every 1200 miles.
