Everything posted by ferret
Low idle
ferret replied to 2007imp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If your problem returns, here's a link to a problem I just fixed. Only applies if you have the newer electronic EGR valve as the thread shows. Something else to consider if your problem returns. http://www.subaruforester.org/vbulletin/f88/low-idle-stuttering-erratic-jerking-various-rpms-76450/index3.html#post887065 -
I have used these guys out of Toronto. Their Y pipes and Catalytic converters go right on with no problems, are made well, and reasonable. http://cgi.ebay.com/ebaymotors/Subaru-Forester-resonator-mid-pipe-99-02-FAST-SHIPPING-_W0QQcmdZViewItemQQhashZitem2ea81a85b6QQitemZ200388806070QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
When it is acting up, shut it off, then unplug the front O2 sensor. It will set a code, but if it runs, the front sensor is your problem. This has happened to quite a few people I know. When cold, the engine runs in 'open loop' mode. But when it gets warm, it switches to 'closed loop' and the sensors output becomes more critical. Easy test to try.
In 06 Subaru SOHC added Advance valve timing. You CAN use the engine in an older car and just ignore it. It has been done a few times on other boards with great success. If you really want it to work, you have to change the wiring harness and get a newer ECU, but there are other obstacles to overcome also. IIRC, the 06's also used the key immobilizer which was also part of the ECU. So you may be better off just leaving it alone.
The above picture is for the 2001 and earlier. Starting in 2002, the PCV valve was moved to the OTHER end of that hose down in the engine block rear. On the 2002 and newer, that picture is just an orifice where the upper end of the PCV valve attached to the throttle body. Follow that hose down and you will find yours. Also note, it IS a different valve and part number from the one that was mounted on the throttle body as shown.
Yup, I agree here ... misfires and fuel trim lean .... front O2 sensor. No MAF on his, he has a MAP. 00-02 Subarus are known for this behavior. Easy way to check, when it's acting up, unplug the front O2 sensor. This WILL set a code, but the ECU will run in open loop mode. And if the hesitation goes away, you confirmed your culprit. Usually happens AFTER it warms up, and the engine goes into Closed-Loop mode.
I would replace the thermostat with a Subaru one from a dealer AND ensure it's installed properly. More than once I have seen this. Here's a link to similiar thread, albeit a Forester, but the engines are the same ..... and so were his symptoms. http://www.subaruforester.org/vbulletin/f88/2001-forester-running-hot-after-timing-belt-wp-replacement-61858/
What kind of thermostat did you use? I hope it was a SUBARU brand. The OEM and aftermarkets have been known to cause overheating problems. Also they have to be installed in the correct direction. The Subaru thermostat is not expensive from the dealer, and you will see the spring/heat end is longer and sets deeper into the waterpump. This way it opens sooner and all the way when necessary. You may have any of the other problems discussed here, but I have come across an OEM thermostat causing problems in boxer engines more than once.
Clutch help
ferret replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The Endwrench article mentions up to 2002 Legacy. http://endwrench.com/images/pdfs/ClutchInfoWin04.pdf -
I'll bet this was an aftermarket belt ( Gates,Dayco, etc ). This is common on the right sprocket of any of the SOHC EJ engines. The toothed belt to mark on the right side is always a 1/2 tooth off, for example 45 1/2 teeth. The aftermarket mfgrs mark it at the NEXT full tooth, in the example 46 teeth. So when an UNEXPERIENCED mechanic replaces the belt, they have a 50/50 chance of getting it correct. This is a common problem for misfires ( cyl 1 & 3 ) and rough idles after a belt replacement.
With the advent of all the electronics stuffed under the hood since the mid - late 80's, the basic of jump starting have changed. Whenever possible, use a portable starter kit. These are the jumpstart units most tow trucks use these days when dispatched. They are separate and have little chance of overvoltage or frying the 'jumped' vehicle electronics. In the event one is not available, attach the cables to the donor vehicle's battery positive, then the dead vehicle positive, the donor negative at the battery, then last the dead vehicle motor for ground. Start the donor and let it run for 20-30 minutes to charge the dead battery. Shut off the donor vehicle and try to start the dead vehicle. In the even it does NOT start, you should not go further. Having the donor run while attempting to start the dead vehicle can damage the donor's Alternator or cause a voltage spike which can damage electronics in either vehicle. It's a wonderful thing to be a good Samaritan, but at what cost.
H6 water pump is Chain Driven. Foresters didn't have that rotation sensor. They used the Zexel only compressor. ( 98 may be different as it was in many ways ) The Calsonic clutches , IIRC, were the systems that used that sensor. And the clutch plate face has 3 or 4 tabs that stick up to pass by the sensor when the clutch engages. Similiar as most automobile A/C systems are, but one of the differences between them. Early 90 legacy's I think also used the Zexel compressor as did the SVX.
