Not exactly true, open diffs are torque balancing devices, the two axels are always outputting the same torque (not the same speed or power). As long as no wheels are slipping both axels get half the available torque, and in the case of the Ej 5MT with the center diff, all 4 wheels get the same torque, 25% at each wheel… until a wheel starts to slip. When slip occurs in an open diff the output is still balanced, but is equal to the wheel with the least grip. So worst case, one wheel gets no traction (think one wheel off the ground), its outputting no torque and so is the other one that’s stopped on the ground. But in a LSD diff the VC (or clutch packs) use the speed difference from axel to axel to apply torque across the diff. The free spinning wheel still applies no torque, but the wheel with traction does (equal to the torque created across the VC) and starts to turn. And since “power” is a function of speed (RPM) and torque, the Subaru AWD system in the 5MT with its center VLSD does in fact “transfer power from the wheels that slip to the wheels that grip”.
Gary
