About mons72
- Birthday 12/22/1972
Contact Methods
MSN
karstein72@hotmail.com
Location
mo i rana
Interests
my subaru touring wagon 1.8 gl
mons72's Achievements
Advanced Member (3/11)
10
a search on google sendt me too this site. http://forums.nasioc.com/forums/archive/index.php/t-1028171.html looks like you have been there and postet.
as you see below, 11 records. i havent gona trusted the seller of the car. good luck VIN2G4WB52L8S1457750Year/Make/Model:1995 BUICK REGAL CUSTOMBody Style:SEDAN 4 DREngine Type: 3.8L V6 TPI OHV 12VManufactured In: CANADASearch Results: 11 records found in our database What is a Record? IMPORTANT! The 11 records on this 1995 BUICK REGAL CUSTOM may confirm a clean title history or uncover potential problems. Find out by ordering the complete CARFAX Vehicle History Report.
i have had that problem my self, and i replaced the +cabel from battery too starter. and the problem is solved. try it and your car will fire up like nothing has happend.
i have had a bearing on my car that hold for only 300-400 km. only because of bad quality on the bearing. i recomend a total check on bearing, hub and so on. good luck
+1. d/r 5sp swap
check the cv's, it maybe there the problem is. i have had that problem my self.
thanks guys. i let you now how it's going with all the swaping i'm gona do. and i'm should try to get some photos before and after swaping also. what i'm gona swap. fenders, doors tailgate, bumpers and the hood. + more on. i think it will take a couple of month's to do it, because of the cold wheater up here in norway.
i need too pull out the dashes because i need too switch the heatcore. if it hasnt been for the heatcore i havent been thinking about it. but as i say, the heatcore need replacement becaus it's a hole in it. and it's leakin some coolingfluid.
the plan is the entire dash. i'm gona part out the 87 sub and move it over to the 86.
does anyone have a wiringdiagram to the dash for 86-87 sub, it would be nice if somone could post it.
ok thanks guys.
pictures are not from my cars, but they are identical and have redline at 6500 rpm. and both cars are carbed.
i have a 86 gl 5sp d/r and i have just bought a 87 gl 5sp d/r, the 87 does not have the same dash as the 86. and i'm thinking about swaping the dash from 87 to the 86. but the big question is, do i need to take wiring harness and swap that to, and how hard is that. and is there anything else i need. those dash is not digi dash. i have searched usmb and usrm for info about swaping dash. but nothing found. i have attached som pictures of the dashes. and does the steeringwheel from a 87 fit right on in a 86. or do i need to replace the steering axel. all info is helpful and very welcome. sorry for my bad english mons72
ok. i think i'm geting it now. i just have to say thanks for the reply friend's:) :) karstein
ok. but explain why my car spins on 3 wheel in 4 wd hi and not in 4 wd lo. i dont understand it. its a parttime 4wd i have.
