My father has an '02 Outback with the H6 3.0 (automatic), about 145k on the car, 130k or so on the motor. When it works, it's great, although he's had a few issues with it. The most recent issue is as follows:
About a week ago, he started the car, put it in reverse to back out of a parking stall, backed up about 15 feet, and it stalled. Nothing dramatic, it just shut off. It had been running just fine before that. He tried to start it again; it would crank like a champ, but not fire.
He called a mechanic friend who came and looked at it, and when he cranked it, he could get it to sputter a little, but not start. He thought it sounded like a failing fuel pump. Soooooo... we replaced the fuel pump yesterday. Cranked it a few times. It would still sputter and try to start, but still no luck. Could definitely hear the fuel pump working. We tried cranking it (giving it plenty of time between tries) for about a half hour. Sometimes it would get close to starting, but just couldn't make it all the way, except once.......
It did start once, and it was quite odd. It would run smooth for a couple of seconds, and then start missing and sputtering. If I pumped the pedal a little it would sometimes "catch up" and start running smooth again, even up over 3k rpms it would purr like a kitten (albeit only for a couple of seconds). It would idle okay for a couple seconds, then miss and nearly stall. I would pump the pedal, it might or might not smooth out. After about 3 or 4 minutes of this, it stalled again and wouldn't start.
Electrical? Injectors? Plugs? Coils (the H6 is coil on plug, right?)? Timing? Something else? I can't imagine it's any sort of catastrophic mechanical failure, since it did run intermittently smoothly yesterday.
Any thoughts would be greatly appreciated. He is supposed to be making a 500 mile trip in it on Tuesday, so time is unfortunately of the essence. I'll probably check on getting it into a a local shop tomorrow, but the likelihood of same-day call, diagnosis, and service is probably not great!
