About 95legwagon
- Birthday 11/25/1988
Location
west hartford
Occupation
salvage yard driver
Vehicles
95 subaru leggy wagon
95legwagon's Achievements
USMB is life! (4/11)
4
the windshield will be the only thing to crack.....other than that, youll break the hatch hinges or wear the hatch latch til it breaks im BIG into car audio and have yet to see a broken back window.....specially in a soob. Plenty of subarus out there with a couple 18"s to like 4-6 12"s or 15"s on gobs of power. i wouldnt worry about it
indeed it is but it is also more money than i spent lol i got this alt free so pretty much i just had to buy bolts and lock washers..... but these alts can be had used for pretty cheap from the right junkyard.... but you are 100% correct. just thought id share what ive found and the reason im doing it this way is to have an alt for engine and stock accessories and the other 140a alt for my stereo hobby.... but could be used for other things too like a TON of lights or maybe other neat electrical hogs
so i have a 140 amp internally regulated alt. 14 volt set point from a 2002-03 volvo s60. and guess what??? it totally lines up with the bottom a/c brackets and the pulley matches up too.... oh yea!!! this i also a 95 ej22. i have to still switch out the clutched pulley as it is clutched the wrong way ( yes this alt will charge if spun backwards) and maybe find a way to attach the top mounting ear to the top of the bracket..... its a pain in the rump roast to mount to the A/C bracket but would be worth if if your didnt want a/c and wanted a greater amp alt. im using the stock alt ( 85 amp) for running the engine and am gunna use the 140 amp alt for my accessory's ( lights, amps, stereo in general) i will have them on separate charging circuits..... i also have a battery bank in the back of the car that this other alt will charge.... they will use a common ground though. thought i would share this with the community as a possible alt upgrade -Jarrid
Greetings from CT!
95legwagon replied to DOHCEJ22E's topic in Meet n' Greet. Your USMB Welcome Center
lol yea we have a couple older soobs here like ours one came in a few months back with piston slap but the car was almost immaculate! also a 97 leg wagon gt a couple outbacks -late 90's a new ( 07 ) legacy theres even an old subaru rim sittin around somewhere..... maybe for a brat? yea you should stop by or you could go to http://www.southwindsorauto.com and search our inventory before you call or stop by..... youll see my legacy as soon as you pull in lol -
i have always wanted to see what my soob would be like with a huge lift and an sti swap...... you beat me to it and boy oh boy does that look fun!!!!! nice job!
that looks just like mine...... except i dont have a hillholder like you....or that spring.... but mine was a 5 speed swap lol. if the clutch doesnt engage when the pedal is to the floor you have to tighten the nuts to adjust the cable tighter on the clutch fork....i did mine by hand tightening them to the fork and snugging them....it worked for me. then i just adjusted to my own comfort - so my clutch engages closer to the floor than other cars.... i also have a bahnhof stage 1 clutch so its a lil different
Greetings from CT!
dude....awesome. im from west hartford and i grew up in manchester.... in fact i work in east windsor @ south windsor auto parts! nice to see another person from ct here. nice build and i love the look of your car i have a 95 legacy wagon in which i am going to turbo at some point.... i have 2 turbos sitting around waiting to be rebuilt lol we have subaru parts at my job so in case your looking for something let me know -
with the driveshaft out the car should move..... if its an auto put in the 2wd fuse......if its 5 speed itll move....but it will put wear and tear on the front diff. usually to get the driveshaft out you hafta remove the exhaust and the heatshield.... my 95 legacy its like that at least ( and ive had the driveshaft out WAYYYYY too many times now lol) although you dont have enough jackstands you could alternatively jack up each side and place cinder blocks under the tires..... wouldnt recommend it BUT i would do it if i was in a pinch..... just make sure they are solid cinderblocks.... not the hollow ones
