Everything posted by 95legwagon
i was thinking about doing a guide on how to replace the "duty c" or clutch transfer valve ( i think its called). this is on a 95 legacy wagon. well first you are gunna need parts and tools. 1. aa0061 transfer valve assy. picked up @ dealer for $127 2. the 2 gaskets that go with it. $4 a piece 3. tailshaft housing gasket. $8 4. Basic mechanics toolset 5. pb blaster (recommended!) 6. hammer ( i used framing hammer) 7. lube of some sort ( i used pb blaster silicon lube) 8. anti-sieze $5 i think 9. drain pan 10. a lift or jackstands or wheel ramps like i used. 11. jack ( if using jackstands or wheel ramps) 12. patience!!!! 1st i laid out a giant tarp so as not to leave a oil spot on grams driveway. then i lined up wheel ramps and backed the car up them. you can drive up forwards if u want but i chose to back up it. 1st thing to remove: exhaust system. you can get it off in one piece with a helper. they are just needed to help move it once disconnected. first i sprayed the rubber exhaust hangers with silicon spray lube. then used adjustable pliers to slip them partially off (so they are 90% off but still supporting it a lil bit) theres 4 of them ( 2 on the muffler, 1 behind the muffler, and one a lil further towards the front of the car) Then i unbolted the transmission mount exhaust hanger (1 bolt) may have to pb blaster it). !!LEAVE IT ON THE HANGER!! itll help later and may prevent damage to header bolts! Now unhook both o2 sensors. (located on top of the catalytic converters. One harness under the car by the side of transmission. One under the hood behind the engine. Next Remove exhaust flange bolts on head ( 6 bolts 3 on each side) **be very careful not to snap off the bolts here as they ARE going to be rusty***PB BLASTER*** i didnt have to use blaster on this car but ive snapped them off before! Not hard to do! Once all bolts are out make sure the headers are free from the engine. Then go back to the rubber mounts and remove them all the way ( support the pipe so it doesnt hit you on the way down) Its pretty heavy! Once its dismounted from hangers go back to the transmission mounted hanger and push it upward and off that hanger and let it rest on the ground. The total exhaust system should be off the car now and lying on the ground. pull it out from under the car and move it to the side. Next to remove is the heatshield located below the driveshaft. Should be 4 bolts and two nuts. I used a wrench and a hammer to help tap them loose. this one is pretty straight forward. Just take off the nuts and bolts and put it to the side. now its gunna get a lil more difficult if your using wheel ramps like i did. Time to remove the driveshaft! Use this @ your own risk! i did it this way cuz the ramps is all i had and i was already way to far in to stop. First chuck the front tires!!!! Just in case! What i did was remove the 2 bolts you can get to easily from the driveshaft. i used a hammer and wrench to break them free. Then i put a jack by the pass. side back tire and jacked the car up just enough so the tire was not touching the ramp anymore. Get in the car and turn the key to "on" dont start. Then hold the brake and put it in neutral. release brake slowly to make sure it doesnt roll. its ok if it does but make sure the front wheels are chucked!!!! Now the dangerous part: get under the car and spin the driveshaft til you can get to the other 2 bolts.( bout half a turn). Put the car in park, pull the ebrake, and remove keys. Also let the jack down! You will need it for the next step. Remove the other 2 bolts the same as you did the first 2. Then remove the 2 bolts holdin the center support. Support the shaft!!! it will hit you if you dont. Once those two bolts are out, Slide the driveshaft towards the back of the car GENTLY. You will see it slide out of the tailshaft housing. ok now that thats done..... NEXT! Now what i did was use a jack to support the tranny under the transmission oil pan. use a block of wood between the jack and the pan so you dont damage it. YOU NEED TO SUPPORT THE TRANSMISSION! Unbolt the mounts from either the transmission or from the bottom of the crossmember ( either way its 4 bolts) .....if you choose the crossmember...now would be a good time to use **PB BLASTER** i broke off two bolts not using it. they break off super easy! Once those bolts are off, start removing the 6 bolts ( 3 on each side) from the crossmember. Once thats off put to the side out of your way. Transmission mount broken bolts... DONT DO THIS! lol it costs more! crossmember out OK now before we go any further..... remove the speed sensor! It has one bolt and its the only thing with a wire going to it in the tailshaft housing! Now that thats out lets remove the tailshaft housing. ( the hard part) . There should be 11 bolts. break them all free first. Again i used a hammer and wrench to aid this. i lowered the jack a little bit so i could reach the 2 on the top. ( theyre a pita!) also i removed the two bolts holding the shifter linkage in place. ( again be careful they do get rusty) now the linkage moves out of your way to get a ratchet up to the top bolts. Its a pain but have patience! Next if it is stuck as bad as mine was. i used a 1/4'' extension and put it on the guide pins and smacked it with a hammer just to break it free. ( NOT HARD) you can and will knock the pins out of the case. They will move a little bit when you hit them though. Thats ok. Then i took a small piece of 2 x 4 and beat on each side of the housing with a hammer. keep workin @ it til you start seeing transmission fluid start to form @ the bottom. If you cant get it that far then you can try what i did but be VERY careful. i DONT recommend this. Take a 3 inch wide chisel and put it inbetween the tranny and the housing and smack it on both sides of the housing just to split the gasket a little bit. It may take a little while to get this housing off so be patient! Once you start seeing Fluid come out the bottom 3 bolt holes you should be able to fit a small prybar in where you had the chisel and LIGHTLY tap it between the tranny and housing till it sinks in bout an inch or two. wiggle it back and forth til the whole case breaks free from the transmission. When i did this i didnt score the gasket area and i considered myself lucky! When its ready to slide off. slide it off and disconnect the wire for the valve. should be an orange harness. tailshaft housing. transmission without housing Next clean the gasket area on the housing before you put the new transfer valve in. take out the old transfer valve ( 4 bolts and a small pipe which comes out with a little persuasion) and clean the case where it was mounted. also clean the plate between the valve and case. install New valve assembly. it goes on like this. Gasket,plate,gasket, valve assembly. make sure you connect ground wire to a bolt. also remember to connect small pipe back to the center hole on it. Now Put the new gasket on the transmission guide pins. hook up the solenoid wire and slide the housing back on. MAKE SURE YOU DONT PINCH THE WIRES WHEN BOLTING THE HOUSING BACK ON!!!! Torque the bolts to about 22 ft lbs. everything goes on the way it came off.... in this order ( in case you forgot) Transmission housing, Speed sensor, Shifter linkage, Transmission mounts, crossmember, driveshaft, heat shield, exhaust, use anti sieze for exhaust bolts on head and on tranny mount exhaust hanger. reverse removal procedure on exhaust for ease of installation. i pulled the car off the ramps before adding tranny fluid so i could get an accurate reading. when i first started the car i still had the light blink but thats because there wasnt any fluid in it yet. i started off with 2 quarts then drove around the block and topped off once it was operating temp. i left plywood under transmission over night to check for leaks. no leaks as of yet. did this last night. ......while i was under there i noticed my next repair.... Can you spot it? maybe ill make a thread on that repair too when i do it. hopefully this will get stickied seeing as how ALOT of people have to do this and no one has done this tutorial yet. (if anybody has done this tutorial sry for not seeing it) _Jarrid_
lol i wish i had found that yesterday .....i did the duty c replacement yesterday......8 hours later! the tailshaft housing was stuck bad. but all is fixed now. i can post pics if u want them and if u wanna know the order everything has to come off ill tell ya. you can check out the guide i made for doing this @ http://www.ultimatesubaru.org/forum/showthread.php?t=124754&highlight=duty+solenoid with pics!
2marrow im fixing the duty c solenoid issue on my 95 legacy wagon....ugh. ive done a full stereo, blacked out taillights, eyelids on the headlights, custom cold air intake right into the front bumper cover, removed tow hitch lol. porting header from a ej25 to put on my ej22.....got a magnaflow muffler from work free...gunna put that on soon. 3" inlet 4" outlet....should be decent sounding. i also painted the interior trim blue. looks good though.....will post pics or check out cardomain- http://www.cardomain.com/ride/3924038/1995-subaru-legacy-ls-wagon-4d ....all the pics are there except for the stereo pics i think......
i got everything but the plate because i shouldnt need to replace that....it was special order but i got it yesterday (3 days after i ordered) n i liked that it was genuine. cant beat that! and yes you are correct it is a valve assembly..... thats why they had a hard time finding it in their computer.....i told them it was a duty c solenoid lol....the guy was like huh? but if that part is genuine good job on finding it online! i had a hard time finding anything.....and i didnt want to wait a week or two for it and possibly shear off that tailshaft......:-\
What's your wrenching experience?
95legwagon replied to mcbrat's topic in Meet n' Greet. Your USMB Welcome Center
what type: shadetree/maintanance what: anything really....from 4 wheelers to bikes to cars to trucks how long: since i was 7. first thing i ever did was a tune up n oil change to an 86 f150 that was sittin for bout 3 years untouched. started right up. what else: my main thing is stereos and car electrical. i can fix and biuld computers. im a j.o.a.t. master of none....sadly. work @ a salvage yard deliverin parts. (we got suby parts new n old). -
hey whats up! names jarrid. i live in ct and i own a 95 subaru legacy wagon. ive got alot of experience in automotive but these subarus are different for sure! well take it easy everyone!
if u wanna get in contact with me email jarridcrandlemire@yahoo.com .... also check out my cardomain to see my ride..... its under user name : scoobydoobiedoo
hey get them right from subaru .... im goin through this currently and im gunna make a post about it. with pics and parts list and prices. i went to the dealer and got the duty c which was hard for them to locate cuz its not called that. the part # is 31942aa061 ( this was for a 95 legacy wagon) i got that the 2 small gaskets for it and the tailshaft housing gasket for $150. FROM THE DEALER! i think thats a good price considering usually u get screwed @ the dealer oh i have the problem and i only have 109,000...... i got the car with the problem @ 98,000 miles and didnt know what it was til i read it on here. well good luck!! :cool:
