Hi. 2005 Subaru Impreza Outback Sport.
When I first had the car, the pedal was exactly the right firmness and exactly the right travel to engage the brakes. One day, after a routine service (at this point, I don't recall what they were doing), there was excessive travel before the brakes would engage. The car would still stop just fine, but a noticable extra amount of travel. While one gets used to this, when switchin back and forth between cars, especially, the extra travel becomes quite obvious. For a few years after that, whenever the car was serviced, the brakes would be back exactly where they were supposed to be, but only for a few days. Then back to excessive pedal travel, again.
And now, as of about a year ago, I'd say, the brake pedal sometimes (not always... might do it many times in a row, etc) will sink a bit as I'm pressing it down. Especially in the case of trying to brake gradually, this makes where the brakes grab a moving target. You migtht be slowing then the pedal will sink a bit causing you to press further then the brakes suddenly grab hold. There will also sometimes be a slight sinking when sitting at a stop light. It's almost as if the bit that decides how much pressure should be in the brakes isn't working right.
The claim from the dealer is that this bit of sinking is a normal function of the system to keep the brake system from overpressurizing and blowing out. And while that might be true, the brakes did not used to do this.
Any thoughts? Thanks.
