About Raindrop
- Birthday 08/23/1994
Location
Boise
Vehicles
1991 Legacy L
Raindrop's Achievements
Member (2/11)
0
It took probably somewhere close to 2/3rds of a gallon of fluid? Maybe just a bit more. Hard to say as I put some in, ran out of what I had on hand and then put some more in later. I put it in until it started coming out of the left side thing that unscrews (don't remember what it's called). I filled the radiator then I put enough in the overflow to see if there were bubbles coming out. I only drove it a few miles after doing these things, but it would have overheated by now yesterday. Temp gauge didn't move after warming up. The smell is very faint. Like I said I haven't actually smelt the exhaust but just sometimes over the past year as I get out of my car I can smell it. Well, I guess I think I can. Hard to say exactly what it smells like since I'm not too experienced. But it's what I would expect it to smell like. So now I need to burp it and get all the air out from filling it? This car had a problem overheating a couple years ago. Seemed to just leak water/coolant pretty bad. After I replaced the radiator cap around a year ago it still is leaking slowly but it has become reliable as long as I check the radiator every now and then. Thanks!:cool:
My '91 Legacy is acting strange. On my way to work the past few mornings the speedo needle has been pretty shaky past ~20 mph. It's been 5-10 degrees F outside as I leave for work in the morning the past few days. This morning it made a really strange sound that sounded like it was coming from the instrument panel. I think this problem is separate from my more concerning issue, and might just be a problem with the cable. On my way to work the heater didn't ever blow hot air, just freezing air. The temp gauge was working and normal, sitting just a hair below half way after it warmed up. On my way home from work after it had warmed up the temp gauge started to go up past the normal. Still no heat coming from the air vents either. I pulled over, the radiator cap was cold and when I unscrewed it a bit of coolant gushed out with what sounded like bubbles of air too. I drove the last couple miles home making sure it didn't over heat too much past the middle. Except the last time I pulled over, letting it rest and cool down, I started driving again and the heater started blasting out hot air and it the temp gauge didn't go past op temp for the last mile home. I'm a little puzzled as to what is going on... :-\ I'm thinking maybe coolant temp sensor or air in my system or a blockage? If I didn't provide enough information let me know. Or if I missed something in my searches that has my answer please let me know what to look for.
Thanks for the pictures I love seeing what it might look like. Especially with the same wheels! I thought it wouldn't be a problem as long as there was clearance but I just wanted to make sure there wasn't something I was missing, since I've never done this before. Sounds like I should find some outback struts and then get some 205/70R15's and I'll be sitting pretty. :cool: Thanks for the help! (Sick Legacy btw)
So I recently picked up some "new" wheels (from a ~98 outback) for my 91 Legacy after getting some "new" struts from the junk yard. The rear struts were pulled off a FWD 90 Legacy Wagon, and definitely are much better than the old ones, but as you can see give it an unintended lift. The tire size the new wheels have on them is 215/60/R15 and they barely fit. The almost rub the strut in the back and they are close to the spring perch in the front. So I'm looking for recommendations here... My front struts also need replaced, I want to get some kind of lift but nothing intense. Just something to lift it up a bit so it matches the back. I'm also looking for recommendations about tire size. Right now I'm thinking 205/60/R15. I'm not looking to get massive tires but I want ones that look good for the new height of the car. I could get taller tires for the back but the front won't fit more than a 215/60/R15 without different struts. One more thing: I might have put the struts on opposites because I think they were on opposite on the car I pulled them off. Unless the L and R strut is the same and just the top hats are different. I know the top hats are on right sides but the brake line holder ended up on the wrong side of the strut when we put the new ones in. Thanks! Always enjoy seeing the forums' ideas. Here are some pics to show the proximity of tire to strut. Sorry it's hard to get pics up in there. Front: Rear:
Sorry for a second thread about struts. So I pulled a pair of rear struts from a '90 Legacy Wagon and the top hats of the struts seem to be slightly different from the ones I saw on a '92 Legacy earlier, and look closer to the old ones I just pulled off, but slightly... bent or angled on the top. Both top hats of the new struts we pulled of the '90 Legacy Wagon appear to have this "bent" or slightly angled top where one side of the top hat is above the other two very slightly. Just want to see if anyone knows anything about this before I put the new struts on, possibly find out they don't work, and have to swap in different ones. The ones being pulled off are the factory ones, and the ones I am replacing them with are the "KYB GR-2" ones. Cheers
So, we replaced a caper on the right side of the car (front) because it was leaking break fluid everywhere. In the process I've realized that the rotor is not on very tight, what I mean it is has lots of play after its bolted on. I think its a bad hub/bearing. Here is a video of the rotor: I just want to make sure its the bearing before i rip it out and replace it. thanks.
No brakes!!
Raindrop replied to Raindrop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Well I changed the front pads last year. I always use anti-seize on the caliper pins. I'll pull it up and take a look and also I'll change the break fluid. The grinding noise isn't like a rock in the disk. I think the rotors might need to be resurfaced. But I changed the pads last year. Ill make sure the Bearing isn't shot. I have changed the bearings on my BMW. I'm sure the rotors aren't rusty as well. I'll go though tomorrow and check through and see what we got under that wheel. it would be sweet if someone has a DIY on break fluid replacent as i've never done it. I'll search for one as well. I remember when I purchased the car something about not towing it too far with the 4wd fuse in? Any know what I'm talking about?
