WAWalker
Everything posted by WAWalker
The viscous coupler is a sealed unit. Changing trans fluid will not effect it. Matter of fact if gear lube got into the viscous coupler you would lose your AWD. Another thing to keep in mind on a 186k mile tranny, that may have had a hard life, infrequent fluid changes........................torque bind is going to take a toll on the rest of the breaings in the trans. Just saying, how much $ do you want to invest in this tranny. Putting a used coupler in is always an option. Specialy if you are doing the work yourself. As I said the early model couplers have had a lower failure rate than the late model units.
I guess I don't always clearly type what I mean. If the DTC was set before the battery was replaced. Then I would say. Yes a weak battery could have caused it. I would clear the code and drive on. That is what I have done every time I have seen that code in the past 11 years. There has never been a problem with the starter. It has always been something else that resulted in a no start. Not to say something hasn't changed since the invent of OBDII. If the DTC sets with the new battery in the car, and the cars starts and runs fine. Different story.
I was saying I have no input from experiance, due to never seeing this code set on an OBDII car. (Starter switch circuit low input) (I have been around enough to know that OBDI cars do not have P codes) But I do on an OBDI car, and simple crank but no start would set the code on OBDI cars (falsly). The starters really haven't changed. Has what the ECU is monitoring changed? I will step back, as I said, I have no experiance.
Would have been interesting to see what kinds of codes the TCU will throw after the spirited driving mentioned. Probably nothing was wrong, just that the TCU got a little confused:) I'm not suprized at the ABS codes afterward. Just running these cars with all four wheels off the ground illuminates the ABS light, and can set codes.
Just one of my experiances to back up my valve adjustment theory. Because it was after head gasket work, I find it to be relavant to your situation. Had been doing all the maintenance and repairs on one customers car starting at 59,999 miles. Head gaskets had external coolant leak. Dealership blew him off, did not repair. Buy the time the "campaign" letter about the head gasket leak came out, the car was at 97 some thousand miles. I showed him the letter told him he had better get to the dealer and "ride their a$$" to get them to fix it, as once he reached 100k, all bets would be off. So right around 100k they replaced his head gaskets (both sides) under warranty. He brings his car to me after another 3k miles for a regular oil change, complaining of a rough idle and CEL. Misfire code. I had been doing all the work on this car except the head gasket work. Plugs and wires were new as of the 90k mile service. Had never set a misfire code, had always idle fine. After checking the car out I told him that the only explanation I could give is that the valves were not adjusted properly during head gasket work. He said he had talked to the dealership and they had told him the problem was either ignition related or something with the valve train. I told him to go back to the dealer and have them check their work as far as the valve adjustment, as that is part of a head gasket job. He said "the dealer would never touch his car again", and how much would I charge to check/adjust the valves. Long story short, I got paid to fix the dealers mistake. I adjusted the valves. 80K miles later the car is still running like a top. I can't guarantee this is your problem (without looking at your car myself), but I've said it before and will say it again. Adjustable valves need adjusting. It should be done at Subarus recommendation of 105k miles and/or any time the heads are removed from the engine and reinstalled. If not done, and no problems arise as a resault, consider yourself lucky.
I forgot to put the word "But" in there. And I tend to over analize things and get real long winded. So I left out the movement of the motor and trans mounts vs. the other hangers on the body And that it still all works if you don't put the springs in, but you may get some rattles, stress on the exhaust pipe................................................I'll quit now:grin:
