Phillip
Everything posted by Phillip
Thanks to those of you assisting me in diagnosing a rear end noise in my 1999 Outback Wagon. Just as a few of you guessed, it's the rear differential. I found a few used ones on craigslist; one out of a 2001 Outback and a few out of WRX's (my ratio is 4.44/1). Can anyone tell me what other models will interchange with a 1999 Outback Wagon with an automatic trans? Many thanks! Phillip
Maybe a very slight vibration, but not sure. I manage a large municipal fleet shop and have access to a press, etc. Even though the service manual said the shaft wasn't servicable, I planned to give it a try. Nipper thinks it may be the rear diff. I didn't hear any noise when I listened with a stethascope, but it's pretty hard to tell. My center bearing is shielded with a tin cover that I'll need to remove before checkin it out. Whatever it is, the noise inside the car is getting louder. Sooner or later something will break. Hope I figure it out before then. Thanks for the tips. I'll let everyone know what I found (when I figure it out!). Thanks again. Phillip
No, I'm not sure it's the center bearing, but I just replaced both rear wheel bearings and that didn't change the noise. It's definately a bearing noise that gets louder as the speed increases. I planned to drop the shield and listen to the center bearing housing tonight. I listened for noise on the rear differential housing a few weeks ago, but couldn't hear any roughness or vibration. My service manual says the center bearing is serviced with a new driveshaft. Sure hope it's not the differential as I'm sure it will be expensive.
I just bought a tent trailer that weighs 1850 pounds and plan to tow it with my 1999 Outback Wagon. My owners manual states towing up to 2000 pounds is acceptable. I'm a little concerned about pulling that much weight. Has anyone here towed this much? Did you have any issues? Any recommendations? Thanks
Good Morning All - my 1999 Outback (2.5/automatic) has developed a stumble at idle I'm having trouble finding. With the engine warm, transmission in drive, foot on brake (car stopped), the engine will intermittently stumble for a second or two, then clear up and run fine. The check engine light is not illuminated. I can't make it happen, but it does occur often. Other than that, it has good power and runs great. Any suggestions on items to look at will be greatly appreciated.
The attaching nut is tight, the wipers are the correct size, and the problem is only on the drivers side (more pronounced when the glass is very wet). I suspect the linkage is worn, but have not disassembled it yet. I assume there are bushings on the ball joints (?); if so, do you know it they are serviced seperately, or must I replace the wiper transmission assembly. Thanks for your response.
The wiper (driver side only) hits both the stop on the bottom and the molding on the top, more so when the windshield is wet. It is not an adjustment issue. I suspect the linkage is worn, but haven't taken it apart yet. Are there bushings? If so, are they servicable, or must I replace the wiper transmission. Thanks for the replies>
