bhazard
Everything posted by bhazard
Drain tubes are clear. Water appears to be leaking in under the tracks/rails. I found this guide (http://caverpilot.com/cars/how-to-remove-replace-sunroof-in-1991-subaru-legacy-and-stop-leaking-roof-or-headliner/) and proceeded to pull the entire assembly but the tracks appear to be riveted and spot welded to the pan instead of attached with screws like in the writeup. Is this a matter of drilling it all out or should I just silicone around the tracks? Has anyone else dealt with this issue?
Not looking for a big lift. Just a slight raise over stock. Main thing I *don't* want to do is crawl around in a muddy junkyard finding trailing arm brackets because I lifted too high and now my wheels are pulled too far forward.
Okay, basically my question was something like "How much can I lift it without needing to change more than just struts". I'll probably just retain stock ride height then.
97 Impreza L sedan. 127k miles, struts are all bad. Car bounces down the road. Car is bone stock, if I use 98-02 Forester struts instead of the ones that "belong" on the car, and otherwise keep stock springs and such, how much lift am I looking at? I've already used forester struts AND springs before to lift a 97 OBS. That also necessitated changing trailing arm brackets and such. I'd rather avoid all that work on this L if I can. If it gets me a small 1 or maybe 2 inch lift, cool.
So far this winter I've pulled a full size 4wd suburban off a snow bank, and a Chevy Aveo back on the road, it was probably 10 yards off the road in a foot of snow. This morning I happened across a Cobalt that was stuck on a huge drift in the middle of a side road. Couldnt find anything to hook onto. Everything underneath was covered by plastic panels. Ended up giving them a ride home a half mile or so.
Uhh the current Impreza is rated at 36 mpg highway, I'd say thats pretty efficient for a modern car with AWD standard. I'm sure 40 mpg on a highway trip is easy with the 5 speed. Only thing I dont understand is why does the legacy now have a 6 speed standard, while the impreza and forester are still stuck with 5 gears? The main drawback of the EJ25 over the (older) 22 is the interference design...
They actually called them Merkur there? I figured they were Ford Sierra just like the rest of Europe. Sweet van, and your English is better than most Americans.
Impossible to tell a direct difference in MPG, but .4L less may be good for a couple mpg. Too many variables. If hes looking for mpg, and it has to be subaru, and has to be awd, why an auto? Ive managed 34mpg on a 55mph highway trip according to my ultragauge, but I'm sure I could have done better with a 5 speed. An EJ18, 5 speed fwd could probably manage 40mpg if driven right. Especially in a coupe.
I wouldnt even try, I was told it had a knock and gambled on it being piston slap, and I dont really wanna go back to that place, it made me wish I had my concealed carry permit. I bought it for pennies compared to the "good" junkyard engines out there. Im probably looking at spending 3-4 times as much now for one thats guaranteed to be good/low miles.
Anyone want to get a FREE VIN check?
bhazard replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Found out that my new-to-me forester has spent its whole life in WI, I'm the 3rd owner, and had an animal collision in November 09.
