tjxtreme
About tjxtreme
- Birthday 01/05/1982
Location
New Orleans
Vehicles
a
tjxtreme's Achievements
Advanced Member (3/11)
10
Thanks for all the replies folks. I appreciate the suggestion of an experimental approach... however in this case my girlfriend was coming to town and I just needed the rain gone. Under the front sunroof there was quite a bit of rust. I don't use the sunroof so I didn't really know the extent of this. It has begun flaking off, and the flakes had found their way to rest on top of what appeared to be the drain tubes. There was also a good bit of soil that had formed (from a decade of outdoor parking) at the base of the windshield. I put the Shop Vac on that too. Problem solved for now.
Hi folks, I've been getting some water in my front passenger carpet during the big rains we've had. I have read the other posts on this topic, but still have questions. I can't find the tube outlet at the fender, can someone describe its location? It is not where it is shown in the other thread (http://farm6.static.flickr.com/5283/5206933287_73db66c816.jpg http://farm5.static.flickr.com/4085/5206932687_b0a819f7fa.jpg) I have the dual sunroof. Is this water likely coming from the sunroof drain or off the windshield? Where is the water coming into the carpet? (i.e. is there a way I can intercept it before it gets on the carpet until I can actually fix it?) Sorry for so many questions, we're getting 3" of rain tomorrow and its been leaking pretty bad in as little as 0.5". Thanks! '99 OBW w dual sunroof and rust
Thanks for the speedy replies. I will try removing some of the corrosion with the next brake job. Fortunately, I have changed the pads and rotors in the past few years, so none of the bolts are too seized. The two (17mm?) that hold on the caliper were a huge pain the first time I tried... a huge pain.
I have some squeaking/rubbing noise coming from all four wheels. I once thought it was bearings, then I thought it was the parking brake. Upon further inspection (wheel/caliper/rotor removal) I realize that the brake shield (not sure if this is the correct term... it is the sheet metal disc behind rotor) has corroded to the point where it is very lightly chafing the outer edge of the rotor. 1. Has anyone experienced this? 2. I plan on very lightly grinding/sanding off the oxidation... is there any reason I should not attempt this? 99 OBW w 180k miles
Thanks for the advice everybody. I'll ask around for some other mechanic recommendations for future repairs. I'm in Baton Rouge, so I wouldn't think it should be inflated... unless they just don't like Subies. I torqued it to the right setting, according to my manual... but it didn't say anything about angle. I just put it back (more or less) how it was. Thanks Andrew
My '99 outback had the CEL come on, I took it to Autozone to have it read and it was the knock sensor. I took it to my mechanic and they quoted me a whopping $285: $85 labor, $125 part, $75 computer reset. I didn't get it fixed there. $75 to reset the computer!?! really? I went back to Autozone, bought a knock sensor for $46 and a 10" extension and put it on in 30 minutes. 200 miles and the light hasn't come back. Those prices seem way steep- should I find another mechanic?
A long time ago I came to terms with the fact that my rough idle wasn't going away. So many mechanics, no identifiable problems, so many miles. It was all the same. I now find it interesting to note that after getting both half shafts replaced and an entire long block (and no, I didn't get these done for the idle) it is still rough as ever. I'm not much of a mechanic, but this led me to suspect that since the idle was only rough while sitting still, but in gear, it must be something in the rear drivetrain.... unless the new engine had this problem too. I'm not sure if this is conclusive, but I popped in the 2wd fuse to see if the idle was still rough. And yes, it was. Must be a poltergeist or something.
I have a '99 with dual sunroof thats spent most of its life in the hot sun... I never use either sunroof. On the highway, I noticed the front one was becoming louder and louder to the point where it sounds like a window cracked about a half inch. Looking up at it, the glass and foam rubber seal are separated and there is a brown crust... which I presume is dry rotten seal. No water leaking, even in downpours. From the outside, the rubber seal is working its way away from the car, and there is a smaller groove in the seal that is now exposed... it looks like this groove would fit on either side of the roof metal. My first instinct is to just use a nice caulk all around it, but I wanted to see if anyone has had this problem. Thanks, Andrew
I need a new rear bearing on my '99 Leg Outback. From reading around, I see that it can be easier and cheaper to change the whole knuckle assembly. I asked an online vendor if they had them, and they replied saying "yes, a right rear stub axle would be $50 incl. shipping." Is this just a different term or did the guy think I wanted something different? Thanks, Andrew PS any comments on pricing or where to get them online would be great.
'99 Leg outback AWD, 146k miles Its definitely something right inside the rear wheel, because I jacked it up, took off the caliper and rotor. When I rotated the remaining wheel parts, I could hear the shrieking coming from inside all of that stuff.... sorry I don't know the proper terms for that (whatever's left of the wheel assembly after the wheel, caliper, and rotor are removed). Thanks, Andrew
I have some rear wheel squeaking and have ruled out the brake and parking brake systems (took caliper and disc off, still squeaked from further inside). When jacked up, the wheel doesn't wobble at all... just the horror movie shrieking noise. Seeing as I just spent a lot on this car, how long can I wait on this? I don't mind the noise too much, but when does it become a safety issue? Thanks, Andrew
Thanks for the input. There is no VIN that I can find... just a series of 10 or so #s imprinted in the driv-rear side, also some numbers printed on what looks like a label maker back there. I had them put in a new timing belt- a little early, but I figured they might as well while its out. They said everything else looked good behind the timing cover, and that the engine seller does a whole round of testing before they sell. It runs well too, so I guess I can't complain... just cost me an arm and a leg. And all from a dry-rotted crank pulley... be warned! I've read a lot about timing belts on this site and haven't seen anything that mentions the possibility of drive belt problems leading to timing problems and wrecking engines... so here it is! In retrospect, I would have treated my drive belt/pulleys like a timing belt and had them changed preventatively. Andrew
