7
Everything posted by rdweninger
Good one, G. Not only would that work, but would be a great conversation piece. Make sure it is NGK. Subaru's new 5-cyl.
OP, Joe... take your intake gaskets down to the Subaru dealer in town. Compare them to the Subaru OEM intake gaskets. You will see why not to use them. Don't forget your cam seals and orings at the dealer. Looks like the kit has the cam seals... there's an oring behind the seal. Also, the reinforced oring inside the cam case is dealer item.
how does this newer gas effect our older engines?
rdweninger replied to Hsoj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We have a few stations in town that offer ethynol free fuel. Check all your stations in town. Marinas should all carry it. -
Head lapping with sandpaper
rdweninger replied to dltrial's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dee2, that's like saying you should only take your car to Midas to have the brakes done... because they are 'professionals'. And honing a cylinder is quite simple as well. However, re-boring a cylinder should be done at a machine shop. And why not lap your own heads... it's easy. Tip- Start with 100 or 120 grit. I spray some wd-40 on the wet/dry sandpaper for lube. Finish with 200 or 220 grit. Don't worry too much about slight discoloration about the fire ring. Use Felpro permatorque head gaskets. I use half inch glass as my base. -
Long ea82 road trip opinions please?
rdweninger replied to LoyaleSmith's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Finally, MilesFox mentions the radiator hoses. For some reason, they always blow in the middle of a long road trip. Also, replace the 2 heater hoses at the firewall.... or be ready with the parts. Always have drinking water (a lot) in the rig. You can use it for coolant, windshield cleaner and personal hydration. I remember heading east on I90 a few years back... we hit a super swarm of bugs (caddis flies?) around Moses Lake. Late at night... no exit... middle of nowhere... could not see thru the windscreen. Had to 'clean' the windshield with water from my canteen. -
As you pull the fuses, check your multimeter to see if there was a drop in draw from that circuit. That would be where your battery drain is coming from. I'm not sure how many should be hot w/o ignition. I could test my 85 ea82 tonight.
Water Pump 89 GL O-Ring question
rdweninger replied to RedSasha's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My o-ring developed a leak back in 2001. I coated it with some black rtv for a quick fix. Now, 13 years later, Tom reminds me that I need to order one. 806927010.... 806927010... call dealer now... 806927010 -
Distributor Rotor Hitting Cap?
rdweninger replied to jj421's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Distys came as Hitachie and NipponDenso. Make sure your cap/rotor is compatible with your disty. Nice job with the multimeter... I told you it would be your friend... ha!- 17 replies
- distributor
- cap
- (and 5 more)
Tie rod ends and ball joins, 1993 Loyale 2wd.
rdweninger replied to Sandrion's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did my '85 wagon recently. New tie rods, ball joints, steering boots, wheel bearings and seals, struts and mounts, brake pads, turned the rotors, rebuilt the calipers and rebooted the axles. I sourced all the parts at rockauto except the steering boots. Car had 220,000 on it. All original parts... even the brake pads. You need to determine how many miles are on the vehicle, any parts recently replaced, and how long you intend to own the vehicle. I will probably be buried in my Subie... it's cheaper than a coffin. -
CLUTCH PROBLEMS EA81 1985 Brat
rdweninger replied to tdodge41's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tru 'dat. Pre 1983 was 200mm 21 spline 7/8" shaft. 1983 + was 225mm 21 spline 7/8" shaft Watch out for EA82 parts when ordering for EA81... Yes... tell the parts guy it's for an 84. EA82 4wd is 225mm with 24 spline 1" shaft EA82 Frontwheel Drive is 200mm with 21 spline 7/8" shaft..... yep... same as the pre 1983 EA81 ... like Gloyale says. The guy is usually, almost always, mostly correct alot of the time. How's that for a compliment? OP - replace your throwout bearing now... otherwise, you will be pulling the motor AGAIN in the near future. Also replace the pilot bearing...fer sure. -
84 GL Wagon - Ignition/Starter/Battery problem
rdweninger replied to JustGo_GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Disconnect battery. Remove starter from vehicle. The contacts are accessible by removing the 3 small bolts holding the endcap on. You will see the copper contacts will have deep grooves in them. the one on the battery side will have deeper grooves. Replace both contacts. I wrote up a post about a year ago. Google search Subaru replace starter contacts... you might watch a youtube video. Hope this helps. I've fixed several starters this way. -
ea82 timing covers???
rdweninger replied to OREchipmunk78's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ditch the covers... front and back. Now you can see your cam seals. Change belts in 20 minutes. Check tension easily. Change water pump. -
TomRhere, my notes indicate same... with exception of the condenser.... which notes say goes to the positive side of coil. I'll get a visual on my Hatch tonight and report back tomorrow. The yellow from the harness is the tach signal wire. Beings that was hooked to the same side as B/W from harness which is 12v ignition... the fuel pump ran constant with key on.
What? Nobody else wants to field this question? First of all, what you have here is a complete mess. If it were mine, I would unhook everything from it's power source... ie., battery. Then start from scratch. Hook up one circuit at a time. Be prepared to install new fuseable links, new ignition switch, maybe a fuse block, several relays and such. By the time you get this Brat fixed... you will be an expert on Subaru Brat wiring. Or maybe your dash will look like the cockpit of a fighter jet... with independent switchs/fuses for all new circuits. Or... drop it off at Shawn's shop in Denver... he'll fix it. Ha! Sorry Shawn. Best of luck to you... buy a multimeter and 12v test light today.
- 22 replies
- ignition coil
- battery
(and 3 more)
Tagged with:
The ea82 heads are interchangeable... just might have to delete the egr and plug the egr port. (if the right side ends up on the left side)
a manual fuel pump? I'm guessing this is an electric fuel pump? with a manual switch. Check your timing. Install fuel pressure regulator before the Weber. The backfire is unburnt/extra fuel in your exhaust, that then ignites when it gets hot enough or finds a 'spark'...
I have never heard of loosen axle nuts to 'fix' a problem. You best torque them back to the 145-150 lbs as required by Subaru law. That's where your wheel shudder is coming from... and a whole bunch of other problems if you don't get them torqued up soon ! make sure all tires are the same size and have approximately the same tread depth to prevent what you call torque binding.
- 23 replies
ea81 removing valve rocker bolts.
rdweninger replied to mfa_mad_pig's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice one, El Presidente. Cracking me up. Looks like the breaker bar worked for the mad pig. I just picked up my 3/4" breaker bar, extension, sliding t-handle and ratchet set. An old Williams set... USA. So nice to have. Am so glad I broke my 1/2" breaker bar. It was a cheapo. Now I need to find a tractor to work on. -
Looks good. I have considered painting my engine bay... but I don't seem to have the dedication that you have when it comes to de-greasing. Did you finish it with one can? How many coats?
I could handle slightly inferior... if that was my only choice for aftermarket. Sounds like the window weld eats rubber... does that sound like an accurate statement? I should post Wanted... new or slightly used OEM tranny mount for ea82.
Back on subject... how do you know all the aftermarket motor mounts come from India? What about the aftermarket tranny mounts? I pulled 2 ea82 motors in the past year with 200k + miles. The motor mounts looked good. I didn't check the tranny mounts... other than noticing they seemed all 'lubed' up. What is there, just the one tranny mount?
Ticking coming from from axles?
rdweninger replied to nick1208's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Aftermarket axles are mostly crap... as you will find out. I 'heard' that there is a new company that makes 'new' axles that are reliable... can't remember the name. I know MWE in Denver rebuilds axles for a lot of Subaru's... good quality. Personally, I clean, grease and reboot my own. Although, I do so when I first see a torn boot. Not after it has been grinding for 6 weeks. -
Brake rotor model question
rdweninger replied to thesmith's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you offer free shipping? Sorry, I had to ask. What part of Seattle? I have a brother up there who could pick them up... meet you somewhere.
