mercuryrising17
About mercuryrising17
- Birthday 01/11/1985
Location
Idaho Falls
Occupation
Postmaster
Vehicles
2002 Legacy GT
mercuryrising17's Achievements
Advanced Member (3/11)
0
Sorry If this is in the wrong spot. I'm working on my GFs 07 Tribeca, and it has been one head scratcher. She was driving the other day and all of her instrument lights came on (or almost all) and had an error code ER HC code above the odometer. I had her park it and when I got to it and restarted it all that was still on was the Brake, Battery, and Rear Diff Temp lights plus none of the headlights worked. I knew her alternator was going out so I figured that was most likely the cause since the battery was also really low on voltage and had just been replaced a few months ago. Bought and changed the alternator and belt, started the car and still the same 3 lights on and headlights did not work. I thought maybe the alternator ruined the battery, so I bought a new one and still no luck, same lights and no headlights. A couple cigarettes later I checked the headlights and every one of them was blown(Probably bad voltage regulator in the alternator). Replaced all of the headlights and they now work, but my warning lights are still on. I do not have fog lights working but I believe they have been burned out for a while now. I'm going to replace them now to see if that is possibly whats happening with the warning lights but I highly doubt it. Does anyone have any suggestions to try out to get the warning lights off? I'm at a loss right now and have to idea what to check. If the headlights all blew out at the same time I can only imagine what else might have gone with them. Any Ideas on this would be greatly appreciated. Ill do a full right up if/when I get this figured out since I cant find anything out there with these specific problems. Thanks a million!
Thanks you guys, I'm going to replace the hose and see if that works and make sure it's not hitting the bottom. I had a bad thermostat that was sticking open and shut while driving so I replaced that but it was an aftermarket from napa. Fixed the issue that caused but I was hoping it would help this one also. This is one of those pain in the rump roast things that you can throw part after part at it to figure out what's causing it. Then at the end you find out its a 2 dollar easy fix.
Working on a 02 legacy gt. my coolant will not flow from the tank back into the radiator when it cools. I'm confident it's not the head gasket they are fairly new and I have also replaced the radiator cap still no fix. Any ideas on what to try next? Can overflow tanks go bad and cause for a loss of vacuum at the cap? Or if the hose connecting the two aren't completely a snug fit could that cause my issue. The car runs fine other than not draining so I have to empty it out manually after a long drive and top the system off. Any one else ever run into this problem? Any ideas? Could a radiator going bad cause this issue? I just flushed my system out and that didn't help but water didn't flow through it great, seemed like it could have run through a bit better. Thanks guys and gals!
I haven't bought it yet, it is a one owner lease return and is in great condition from what I can tell. The small vibration could just be normal it is barley noticeable and could just be the road and tires. Vargas is clear on it and it does have warranty left on it. Previous owner was in is 40's and kept the car stock something that will change of I buy it (how can I say no to an intake and exhaust when it sounds so much better lol)
So I'm breaking down and getting a newer car. I have found an 09 legacy gtl and I love it! I've got it home tonight checking it out and just want to know if there are any typical or common problems with this model that I should look for. The only thing I have noticed is a very slight vibration in the steering wheel on the interstate. It isn't bad but is noticeable. I'm guessing its tires out of balance a little or maybe needs an alignment. The car only has 38 k miles on it so I can't imagine running into many problems, just wanted to see if anyone had any input on the model. Thanks!
I did surface them by hand and had them completely clean and looked like they would be all right so I decided to chance it since I couldn't get it to a shop for 3 weeks and had to have the car back ASAP. I had the torque sequence correct but I did not re torque them. This probably has a lot to do with it but at the time I had advice that it was not needed. Do any of you re torque the head bolts after it has been ran for a while? This was my first ever HG job so I could have just not had everything quite correct but it was a great learning exp and should not be difficult this time around. Either way it got me by for over a year and now I have something to do for a few days
I am trying to decide what I should do at this point. My head gasket seems to be out again. I replaced them last year but didn't do anything to the heads. The heads looked a little worn but I re used them and never re surfaces them, I just cleaned them up really really good. Now that I have to replace them again I'm wondering if I should just buy a new set of heads ( o'reily has the for 316 a piece the cheapest I have found) or if I should just get a rebuilt engine for it and get it all out of the way at once. The car has 205k on it and I just can't decide if I should buy new heads and risk losing a piston or something soon and wasting the money and the time on the heads. My mpg has gone down lately but that could just be sticky valves I'm guessing. Either way what is a great trustable place to buy rebuilt heads and engines. From what I've seen so far the net is full of empty promises on them and can be misleading about the parts. Thanks guys you have been so much help over the years!
I keep blowing the cap off of my coolant overflow tank and loosing antifreeze. I hot glues the cap down and it still blew off. It is on an 02 legacy 2.5. Any ideas on what may be going on. I changed the head gaskets last year but didn't machine or replace the heads. Could a head gasket going out again cause the high pressure? I would think that a leak would cause a loss on pressure. Could it be the thermostat stuck open possibly? Thanks in advance for any input.
I will change the plugs tonight, my wife just took it to a local mechanic that she knows while i was at work and he thinks it might be that my timing belt jumped a tooth and is now off timing, anyone think that this is possible. I just changed the belt in december and did a new water pump and new pulley system with a new tensioner. Seems unlikely to me that it would work fine for so long and then one day it would get me to work fine but have problems on when i left to go home, nothing happened it just started acting up. My problem solving thought process says that for it to get off timing all of a sudden is not likely. he's thinking i should pull the heads off and re-time it and put new heads on it.
