Sabaroo
Everything posted by Sabaroo
You came to the right place!
So last fall I had my heads done, installed them (EJ22), during the instalation I broke a tooth off on the back of the crank sprocket would this cause the engine to backfire and no run properly at all & eventually stall? I have checked the timing about 12x and did compression check on cyl 155 to 165 for all 4. No check engine light. Checked the plugs 2 front ones were carboned up back ones looked like they didnt even fire.... I checked the sparkwires for proper connection.
Helllllppp!
Sabaroo replied to Sabaroo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yeah last week I left an email at that site no answer yet. -
Helllllppp!
Thanks Fairtax, I sure it's just the timing as it runs but sputters and occasional backfire. I re check and test thanks again. -
Helllllppp!
Anyone know where I can get a crank timing pulley cheap I noticed I have a broke tooth on mine. -
Helllllppp!
FYI I went .008" on the intake and .010" on the exhaust -
Helllllppp!
So if I spin the crank 360 the way it is now (with the belt on) it looks good? -
Helllllppp!
Ok I removed timing cover and could you guys validate that these are the right marks to line up. -
Helllllppp!
Well I set the valve gaps as per my Chilton manual, so I figure I musta messed up my timing marks by a tooth......hmm but which way??? Also it souds like the backfires are coming thru intake. -
Helllllppp!
I'm just going to move the cam sprockets 1 tooth. -
Helllllppp!
I thought I was on with the marks, how far can you be off until you damage the valves? I guess I am saying what if I reset it to 1 tooth the wrong way. -
Helllllppp!
Okay the connector in the picture went to a block on top of the engine under the intake (had to see it with a mirror). Now I started it up and it runs extremely rough and backfires and sometimes revs hi and races. -
Helllllppp!
I used Felpro, funny I am a designer by profession and I did alot of work for Gates and I would say nowadays 90% of their stuff is manufactured in China as far as tensioners and idlers. -
Helllllppp!
Holy crap do I fell like an idiot! I did the clutch cable about 4 months ago and threw the old end in my hatch back and thats where I put the rest opf my parts..............doh. Thanks Guys you guys are the best with out you guys I'm sure this Subie wouldnt see the the road again. -
Helllllppp!
Yeah I bought the car (impreza brighton stationwagon) about a year ago not knowing the life left on the timing assy. Apparently an idler lost it's ball bearings and smoked the timing belt, smashed the valves you know the story. As you guys know these cars grow on you so it's hard to send them off to the junk yard. So I jacked the motor up about1 1/2 inches enough to access head bolts. Rebuilt the heads, put on Gates timing assy with water pump. Yeah that bushing thing it's got a needle sticking out of it if you look close. -
Bolts
Yep I guess I'll try the junk yard & the parts section of forum thanks!
