glennda5id
About glennda5id
- Birthday 12/09/1979
Location
Redondo Beach CA
Occupation
Programmer
Vehicles
I Love My Subaru
glennda5id's Achievements
Member (2/11)
0
Subaru officially recommends 105k or 7 years! If this car has not had a timing belt done then it is well past due. That being said, the 1.8L motor was not interference so you can just drive the car until it breaks and then replace it and not worry about engine damange. However you will need to tow the car to where ever you are going to work on it. I think the car is a bit over priced especially without AWD. The AWD's manuals are super fun to drive. With the default 50/50 split they feel like driving a RWD car. I own a 93 Legacy but its 2WD Auto. There is not a day that goes by that I don't think about swapping it to AWD w/stick.
I don't want to put a lot of money into the car. My only concern with buying and having it shipped is if there is an issue I am out $300 for initial and return shipping on my $300 transmission....lol. If shipping is $100 it is better. I see two at this yard in SD for $300 and $350 and they want $150 to ship which is reasonable just worried if there is an issue and I need to return it.
The long and short of it is that I have been unable to source a reasonably priced trans locally so I am going to get a junk yard to ship me one. I found one with low miles from a 95 Impreza. Think that's a good idea? My only concern is if there is an issue then I am out the shipping I believe. Gary, I currently live in SoCal. My folks live in Bowie, MD and I used to live in College Park and then DC. Moved out to CA about a year ago.
If I take option 2, basically leave everything alone, is there going to be any loss in power or efficiency to the front wheels. Is it bad to just leave the rear output shaft. If I leave it, it shouldn't leak as there is a seal there already. This would be the equivalent of having an AWD car and removing the rear drive shaft. Also, one of the posters mentioned different different mount locations for the two transmissions. I have heard of folks putting a 2WD 4EAT into a AWD Subaru, I assume I can do the reverse.
So my legacy is a 2WD and I need a new trans and have access to a low miles AWD trans for a great price. I'm trying to figure out if this AWD trans will work and if I can remove the rear drive shaft or if its okay to leave it in there. I have access to a 2WD 4EAT that I can swap parts from. Could I take parts from my 2WD to turn my 4EAT AWD into a 2WD. My other question is, with no power to the duty C, my understanding is that the center diff will be locked at 50/50. Does this matter with nothing hooked up to the rear output shaft? I would love more than anything to turn that car into AWD, but that is a lot of work and cost.
So it sounds like removing the AWD part of it is sort of out of the question. If I use this transmission. Is it bad on the transmission to just run it as is with no rear driveshaft attached? The trans will be hooked up to a TCU that won't have any wiring for the duty C solenoid so the duty solenoid will not be energized. Is this an issue?
Is it possible and/or advisable to take a 4EAT set up for AWD and configure it for 2WD by removing the center diff and rear output shaft and covering up the hole? I ask this question because I need to replace the trans on my 2WD Legacy, however it might be of interest to folks who are doing special applications like building a mid engine car. This is one of those special projects and I think they do it, but I don't know how. http://www.factoryfive.com/kits/project-818/
